Ana içeriğe geç
Yardım
HP Chromebook 11 G5 EE Teardown/Disassembly
Adım 6 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
Starting with the removal of the battery, which appears to be made of 3 cells.
Disconnect the battery by pulling the cable out of the motherboard
The battery is held in with a single PH0 screw. Once removed, it can be pulled out.
Opening up the battery does, indeed, affirm it is made of 3 cells, as wekk as a controller.
Never ever EVER open a battery, even if you believe it is made of more cells. One slight mistake can result in a fireball of toxic gasses. Even if you do open it, no parts in the assembly can be individually replaced. This is due to how multi-cell lithium batteries are balanced and calibrated.
The battery appears to have an internal sensor for temperature, to protect against it exploding in unsafe environments.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
