Ana içeriğe geç
Yardım
HP Chromebook 11 G5 EE Teardown/Disassembly
Adım 9 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
Now with the display assembly exposed, you the webcam (top board) and LCD itself can be seen.
The LCD can be detached by removing 4 PH1 screws, one in each corner.
Do not immediately yank the LDC out, it is still connected to the main display assembly via a cable.
This cable can be disconnected by peeling off the clear tape and pulling the cable out.
While not as blatantly stupid and reckless as dismantling a battery, I pulled off the tape on the LCD controller board. You shouldn't do this yourself, as there can be high voltages as well as the fact their are no replaceable parts under the cover.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
