Ana içeriğe geç
Yardım
Alliums LED projector AP-020 Teardown
Adım 3 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
Turn it over to the bottom.
Unscrew 1*PH1 screw. (RED)
Unscrew 6*PH0 screws. (BLUE)
Remove the top cover. (be careful not to break the FPC cable)
Release the 2*ZIF connectors (YELLOW) and remove the FPC cable.
The top cover is now removed.
Component Description (top cover): The module is made of ABS plastic injection molding (excluding touch buttons and circuit board parts), with dimensions of 297mm in length, 232mm in width, and 40mm in height. The module weighs 243g.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
