Ana içeriğe geç
Yardım
Alliums LED projector AP-020 Teardown
Adım 5 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
Remove 10*PH0 screws. (RED)
Remove the right cover first.
Then remove the left cover.
Component Description (right cover): Injection molded from ABS plastic. Length 207mm, width 184mm, height 41.5mm. Weight 64g. Used to seal the light path to avoid light leakage and reduce dust entry.
Component Description (left cover): Injection molded from ABS plastic. Length 221mm, width 220mm, height 50mm. Weight 73g. Used to seal the light path to avoid light leakage and reduce dust entry. At the same time, fix 2 fans and build a cooling duct.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
