Ana içeriğe geç
Yardım
Alliums LED projector AP-020 Teardown
Adım 7 Düzenleniyor —
Adım Tipi:
Yeniden düzenlemek için sürükleyin
Remove the AC input connector (RED), remove the mainboard DC output connector (ORANGE), and remove the LED output connector (YELLOW).
Pull up to remove the power supply.
Pull up to remove the LED light source and heat sink module.
Component Description (power supply): A switching power supply is used to power the motherboard and LED. The module is 89mm long, 84mm wide, 35mm thick, and weighs 194g.
Component Description (LED): The LED uses COB packaging technology and has a 4-heat pipe single tower radiator. The radiator fins are stamped and bent from aluminum sheets and are connected to the copper heat pipes using the Fin process. The base that fixes the LED and heat pipe is made of extruded aluminum.
The LED with cooling module is 150mm long, 84.5mm wide and 35mm thick. The module weight is 241g.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
