Ana içeriğe geç
İçindekiler
Öğrenci Katkılı Viki
Bu vikiyi, eğitim programımızdan harika bir öğrenci ekibi yaptı.
Screen Won’t Turn On
The monitor on my laptop doesn’t show anything, and I know the computer is turned on.
Computer Powered On
Make sure that the device is fully charged and powered on correctly.
Disabled Display
You want to make sure the display has not been accidentally disabled. To do this, press the “Fn” key in the lower corner of the keyboard and then press “F2.”
Projector Mode
If the above step does not resolve the issue, repeat the action again while holding down the Windows key and pressing “P” twice. There is a chance the display is in projector mode. Once you follow this step it will convert the display back to “Computer Only.”
Laptop is Overheating
When using laptop, the laptop is too hot and shuts down without warning.
Dust in Vent or Fans
It’s possible for a device to overheat from dust in the vent or fan. Using a compressed air duster and effectively getting rid of the dust can solve this issue.
Fan Issues
If fan does not function properly after thorough cleaning, the fan may need to be replaced .
Battery Won't last long
Laptop battery doesn’t last as long as it used to.
Faulty Power Adapter
Plugging the adapter into an outlet should result in a charge light, which indicates its functionality and ability to charge. If the power adapter light is on when it’s plugged into the laptop, the adapter is not responsible for the short battery life.
Faulty Battery
The length of the charge should reflect the amount of time that the laptop is connected to the power adapter, so a disparity between charging time and battery life may indicate that your laptop needs a new battery.
Device Won’t Load Files
Files that used to be on laptop are no longer there.
Malfunctioning Hard Drive
It is possible your hard drive is not functioning properly and is causing data loss. In order to restore functionality to your laptop, you may need to replace the hard drive.
Recycling Bin
Check to make sure that no files were accidentally deleted and sent to the recycling bin. If the files are in the recycling bin, right click and click on “restore” to bring them back to where they were originally.
Incorrect or Unaccepted Keyboard Inputs
The keyboard on your laptop doesn't input the correct keys on command.
Check the NumLock Key to Ensure it's Enabled
Many laptops will convert the keyboard into a number pad if NumLock is enabled. Press NumLock or Fn+NumLock to make sure that it is disabled. The NumLock key will typically have a light that signifies whether it is enabled or not that. On most devices, this will be located above the NumLock key.
Switch Between Your Active Keyboard Layouts
If you have more than one keyboard layout installed, make sure that the correct layout is selected.
Dust/Crumbs Under Keys
Debris might be obstructing the keys, so cleaning beneath keys may yield a solution.
Using a New Keyboard
If none of the previous methods work for you, the keyboard itself could have a malfunction. Disconnect your wireless or USB keyboard, then try using a new one. You may want to use a different port as well.
Laura Tamayo
678 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G4, Leahy Spring 2019 USF Tampa, Team S1-G4, Leahy Spring 2019 üyesi
USFT-LEAHY-S19S1G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 11
Her zaman: 230
