How do I re-install a spring
There are two springs under the cover. One on the left one on the right. One came out. I have it. How do I get it back in? I didn't try to fix it. I was afraid to make it worse.
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
when you open the lid, the back of the front lid there are 2 spring loaded levers on each side. put the bottom in then the spring then push the top in place
Chad
Bu yanıt yardımcı oldu mu?
my lever is broke and there is no bottom portion to put in first. Ideas for replacing
We need a drawing or picture as I do not see where the level and spring 'go in'.
My spring is missing, where can I get a replacement?
Tried that and lost spring in machine. Now what do i do?
where can i take my neat machine for repairs? 5/1/2017
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 752
2 Yorum
what if the lever broke and there is no bottom
Lauri Berzins tarafından
No helpful for the NeatD 1000. I do not see where to insert the level / spring. How about a drawing or a picture ?
David Culver tarafından
