Ana içeriğe geç
Originally released in 2006, the NeatDesk is a desktop document scanner with ADF and full-duplex features. The early revision has model number "ADF-070108" and the newer revision is model "ND-1000."
How do I re-install a spring
There are two springs under the cover. One on the left one on the right. One came out. I have it. How do I get it back in? I didn't try to fix it. I was afraid to make it worse.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
2 Yorum
what if the lever broke and there is no bottom
tarafından
No helpful for the NeatD 1000. I do not see where to insert the level / spring. How about a drawing or a picture ?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
when you open the lid, the back of the front lid there are 2 spring loaded levers on each side. put the bottom in then the spring then push the top in place
Chad
Bu yanıt yardımcı oldu mu?
Puan 1
5 Yorum:
my lever is broke and there is no bottom portion to put in first. Ideas for replacing
tarafından
We need a drawing or picture as I do not see where the level and spring 'go in'.
tarafından
My spring is missing, where can I get a replacement?
tarafından
Tried that and lost spring in machine. Now what do i do?
tarafından
where can i take my neat machine for repairs? 5/1/2017
tarafından
Yorum Ekle
Yanıtını ekle
Nita sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 752
