change the mini jack for headset
Like in the title, i would like to know how to change the headphone mini jack because mine is broken
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
Hi,
Here is a link that shows how to dis-assemble your laptop. At 4:05 minutes into the video, the headphone socket is visible. It appears to be mounted on the motherboard, so you will have to remove the motherboard to get good access to it. You will also need to have expertise in removing/replacing components on a PCB as well as the tools necessary to do the work.
https://www.youtube.com/watch?v=YhRgwvL7...
Hopefully this is of some help.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 255
