Ana içeriğe geç
iPhone'un 5. jenerasyonu. Cihazın onarımı basittir; tornavidalar, kanırtma aletleri ve sabır gerektirir. GSM/CDMA / 16, 32 ya da 64 GB / Siyah ya da Beyaz.
2193 Soru Tümünü görüntüle
Why is the touch not responding after I removed the glass
Hello,
I am posting to ask why the touch isnt responding after taking the glass off to refurbish the screen, I have cleaned the screen thoroughly and it lights up okay. the touch kind of works up & down on the edges, the very edges. Apart from that its not responding, everything seems to be okay... what could be the issue? (I am talking about once the glass have been removed and youre testing the LCD/touch)
Is it fixable?
Bu iyi bir soru mu?
Puan 0
2 Yorum
OK, what did you clean it with?
tarafından
I used 100% cleaning alcohol ..
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hey Zachary,
hmmm...
My suspicion is that a connection is loose,
not seated right, or disconnected when you
took the screen assembly off.
I'm not sure what else you may have done
in the "refurbishing" process -but if you
accidentally got some of that 100% cleaning
alcohol inside the unit...well, it just wouldn't
play nice with that wonderful Apple tech.
Bu yanıt yardımcı oldu mu?
Puan 0
4 Yorum:
I can connect other screens and they still work... could it be to do with my process? I have done 3 iphone 4/4s screens and they all have the same out come... nice clean display, but the touch not working properly....
tarafından
The Touch displays are layered glass and electronic screens (layered sub-straits) that electronically detect pressure on the screens so if you sloshed too much cleaning solution the sub-straits would act like a candle wick and soak up the cleaning solution into the center of the glass filling up the empty layer where the electronic pressure is detected. Therefore the pressure of your finger cannot now be detected because the cleaning solution has filled the micro-miniture center. Sorry but you can test this by putting in an uncleaned touch screen to see if it works. You might be able to fix the screens if you could put then in a case of desiccant for a day or two.
tarafından
Okay thank you so much for your advice. Honestly you are a life saver. Could it have something to do with me using a razor blade to clean off the glue also? Although I am careful and it worked to clean the iphone 4/4s screens, iphone 5 and above and much more sensitive... what should i do to remove the glue if I cant use a sharp razor or cleaning agent?
tarafından
hello? :/ @oldturkey03
tarafından
Yorum Ekle
Yanıtını ekle
ZsTech sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 105
