Maximum CPU for this laptop?
Does anyone know the fastest cpu I can put in this laptop and if it supports quad core?
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
The Inspiron 1545 can only accept dual-core Core 2 Duo or Core 2 Extreme chips. A Core i3, of any generation, is a no-go.
The good news is that it can take any Core 2 chip, which means you can install a 3.06 GHz T9900 or X9100 and it will work fine. A T9800 (2.93 GHz) will give it about a 40% performance boost as an example.
Bu yanıt yardımcı oldu mu?
Hi, I have a Dell Inspiron 1545.
I have found a Quad Core Socket P CPU on the internet would you say it is compatible.
My current Processor Socket is Socket P.
I have a dell inspiron 1525, 4gb ram, win7 ultimate, and just upgraded my cpu to a x9100s p socket now its not booting
actually it will work you just need to try booting a LOT a person did this look it up
can i use i3 in my laptop
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 52
Her zaman: 9,817
7 Yorum
T9900 is compatible with Dell Inspiron 1545.
I only know this because i have performed the upgrade on this laptop.
Omar Hussain tarafından
Hi Omar
I bought a T9900 on eBay, and it doesn't seem to work in my Inspiron 1545. I'm running Win10 Pro from an SSD and have 4GB RAM. From many forums I believe this processor should work. I've switched back to the T4500 and it works. I've swapped back and forth a number of times now, and all the machine will do with the T9900 installed is briefly flash the power light on the front when I press the power button. I don't get anything at all on the screen, no fan, nothing. Can't even get into the BIOS (which is on the latest version A14). Do you think I can safely complain that the processor I bought on eBay is faulty and ask for my money back?
BTW, I am good with practical electronic stuff. I take anti-static precautions, use MX-4 thermal paste, etc, so I don't think I've "damaged" the processor. I've recently replaced keyboards in two ASUS UX31E ultrabooks (complete dismantle and rebuild). Also just upgraded an ACER Veriton x270 from E5300 to a Core 2 Quad Q9650 sucessfully.
Woody tarafından
I have working T9800 on my 1545.. working like a charm with 8GB ram upgrade.. works fine on Arch linux & Windows 10
Mahesh tarafından
I am in the same situation. I tried a T9900 and it just flashes the light when you hit power. Is it DOA?
Rodney Barnes tarafından
Hi Rodney
I am begining to suspect that there may be more than one type of motherboard for the Inspiron 1545. I returned the T9900 processor I bought and got one from somewhere else, and it also didn't work!
Woody tarafından
2 tane daha yorum göster
