Ana içeriğe geç
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
20 Soru Tümünü görüntüle
Soru Kapandı
changing to wd 1tb hdd
hi guys
i´ve heared that you can upgrade the hdd up to 1 tb now. the new wd do have 1tb 2,5 and a installation height of 12,5mm. as i readed on several blogs and forums it should be now possible to build in hdd´s with this height.
sdomebody experencies with it?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
9 Cevap
Filtre ölçütü:
Seçilen Çözüm
For the record here is a 1TB drive (12.5) that OWC states will fit in a MacBook Pro unibody. Ralph
http://eshop.macsales.com/item/Western%2...
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
DFM had it right. Ralph
tarafından
k +
tarafından
Yorum Ekle
iFixit doesn't seem to offer any 1TB drives for it, and says on both the mid and early 2009 version pages the max you can get is 500 gb.
Puan 1
Yorum Ekle
Go for it! I installed the WD10TPVT a couple of months ago in my 17" Unibody and it works perfectly! It fits perfectly and was an easy upgrade.
Puan 1
Yorum Ekle
This computer is compatible with 12.5mm drives. However, my recommendation would be to look for an AF (Advanced Format) drive to do the upgrade.
AF drives have larger per platter capacities, so these drives don't need to be as thick to have the capacity that is equal to a pre-AF 1TB drive. Many of the AF 1TB drives are 9.5mm, so these drives will fit in your computer without having to worry about the thickness of the drive.
Puan 1
Yorum Ekle
but thats not true you do get the first 1tb hdd´s.
Puan 0
Yorum Ekle
according to this article at TUAW, the 12.5mm high drives such as the WD 1TB Scorpio are too thick to fit in any of the unibody Mac laptops - although such a drive would fit in the previous generation 17" MBP. this info apparently comes from Other World Computing, a reliable vendor of Mac hardware upgrades
Puan 0
Yorum Ekle
Fitting 12.5mm hdd in 17 inch Unibody MBP is not a problem at all. I'm writing this from my MBP already upgraded with WD 750GB which is 12.5mm thick also. So, 'that article' is just not true.
Puan 0
Yorum Ekle
If you called the apple support they would tell you if you want to call the number is
U.S. iPod and Mac technical support:
(800) APL-CARE (800-275-2273)
Canada technical support:
(800) 263-3394
Puan 0
Yorum Ekle
Turns out it is
Puan 0
1 Yorum:
Editing this is great, but it's best to just delete your own answer when you realize it was incorrect.
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 7,156
