Ana içeriğe geç
The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
20 Soru Tümünü görüntüle
Strip screws? How to fix?
Hi i screwup my side console, by stripping one of the screws. ( i used a y00 instead of a y000). Rubber band and super glue didnt work. To remove glue i use a drill bit (1mm), now there is a counter sunk hole. Ideas?
Bu iyi bir soru mu?
Puan 8
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sounds like you already have drilled a hole there so I would just get the next biggest drill bit and drill it more. You might even need to use the next biggest bit after that. Once you drill the head off then you can usually take it apart more until you can get to the screw and use pliers to turn it out.
Hope this makes sense.
Bu yanıt yardımcı oldu mu?
Puan 7
Yorum Ekle
Try this
Precision Screw Extractor Set
Four different sized extractor tools to help remove fasteners or screws with stripped heads. Driver head is claw shaped for maximum grip. Sizes range from 1.1mm to 2.0mm. Görseli
Ürün
$24.99
Puan 3
Yorum Ekle
Welp.. Y00 is correct you might have presed a lot. Y00 works for me
Puan 1
Yorum Ekle
So how was this problem solved? I have the same situation. Please help.
Puan 1
1 Yorum:
Have you tried How to Remove a Stripped Screw already?
tarafından
Yorum Ekle
Needle nose pliers is what worked for me
Puan 0
Yorum Ekle
Yanıtını ekle
jonathan ambrose sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 21
Son 30 gün: 79
Her zaman: 33,264
