Ana içeriğe geç
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Soru Tümünü görüntüle
Dim screen after screen replacement - iPhone SE
Hi! I am new here and i don't have experience whn it comes to hardware replacement.
So, i recently replaced my iPhone SE screen with an OEM one and after finishing up i noticed that the screen brightness is lower than normal (although in settings it's at 100%). I know it isn't that big of an issue but i would like to fix it anyway.
Here are some pictures where I compared my iPhone with another one that is working normally: https://imgur.com/a/zZC1uIO
Sorry for the bad res. I had nothing else to take the pictures with :S
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum:
Where did you order the replacement screen from?
tarafından
@mikeyd123 I am from Romania and i bought it from an online shop here. I just want to know if it s something easy fixable or it requires some sort of soldering, in wich case i'll take my phone to a service.
tarafından
Sorry I took a while to get back to you. This is easily fixable. Just order a new replacement screen, the one you have now is most likely defective.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Order another part but from a different site and replace it again.
best part places I know of:
https://www.fixez.com/store/iphone/iphon...
[bağlı ürün eksik veya kapalı: IF124-049]
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
@touretteskey Nah. I want to know if i can fix it as it is. I don't want ti buy a new one as I can use it like this anyway.
tarafından
I understand, but to be completely honest with you, the LCD is not working properly and a new part is needed. This cannot be fixed as is.
tarafından
Yorum Ekle
Carol,
I suspect you did not get an OEM quality screen. I've seen low quality screens that are dim, off-color or have odd lines running through them when first replaced.
I recommend purchasing a replacement from iFixit: their screens are some of the best I've purchased.
iFixit sells a screen with everything attached (including a new speaker, etc.). Since you've already replaced the screen yourself you probably don't need the toolkit that comes with the full assembly so you can choose the lower-cost option.
iFixit also offers a replacement part that let's you swap the speaker and a few other tiny parts over (for a few $ less).
Choose the replacement part that matches your comfort level and be sure to follow the instructions here.
Good luck!
Craig
Puan 0
Yorum Ekle
Yanıtını ekle
Carol Tino sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 13
Her zaman: 1,308
