My sound touch was left outside in the rain ,when I initially plugged
Got wet how do I fix it ,won’t turn on?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi @msheard62
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the speaker's operating design and could damage the components.
First do not connect power to the speaker or attempt to turn it on so as to minimize any further damage
You will need to open the speaker and thoroughly clean away any corrosion (and any remaining water) and then check the components for obvious signs of electrical damage, e.g. burnt out components, heat stressed components, blown fuses etc.
If you have any doubts about some components etc, post some close up images back here and hopefully someone will be able to help. Here’s how to do that Adding images to an existing question
Clean all the affected parts using Isopropyl Alcohol 90%+ (available from most pharmacies) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is <70% IPA, can contain scents and is not as effective. If you do check the label to verify the amount
Here is a link that describes the process.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Here is a link to the ifixit BOSE SoundTouch 30 guides which may be of some help.
If this process seems too daunting, take your speaker to a reputable, professional electronics repair service and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 47
Her zaman: 5,101
