Ana içeriğe geç
Google's 2nd-generation Pixel XL sports a 6-inch P-OLED display with rounded corners. Available in 64 and 128 GB storage configurations, and in two colors: Just Black and Black & White. Released October 19, 2017.
Is my screen fixable?
Hello,
I recently smashed my phone on concrete when I slipped while running. The top left corner of my Pixel took the most damage.
Is my phone repairable? I’m assuming I’ll need to get a front camera replacement and a full screen + digitizer. I can’t tell if the frame is damaged beyond repair… Any advice/comments would be appreciated!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
if price is a concern and the phone still functions..looks like it's just the glass over the camera and may not involve the actual camera at all/touchscreen functions intact, you could just apply sticky tape/contact adhesive to prevent further damage etc and keep on using the phone. you may have a few pieces of glass over the camera which may show up on photos, but seeing as this is the selfie camera, if you don't use it what does it matter?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
This link may be of some help.
They should give you a quote for the repair if nothing else.
Update (11/06/2018)
Here’s a link to the ifixit Google Pixel 2 XL Screen Replacement guide.
Once you have removed the old screen you should be able to determine what else, if anything, needs to be replaced. It may depend on how well the new screen sits back in.
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
I appreciate the link, but it doesn't answer my question. I'm trying to decide whether or not ifixit tools will suffice in repairing my Pixel device.
tarafından
The answer is yes. You should change the screen completely. Your screen has part of the LCD broken, so it is not possible to repair. You can change the glass, but the spot on the LCD has no repair.
The camera should try it to know if it should change or not, if it looks good I would change it. Due to the opening problem, you must first remove the screen to access the rest of the terminal, I advise you to be sure before sticking the screen to the chassis.
If the frame is damaged, it can be repaired with a sandpaper and patience. But it will not be like new.
tarafından
You will need additional stickers that may not come with the screen. Luck!
tarafından
Yorum Ekle
Yanıtını ekle
Timothy Lee sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 1,655
