Ana içeriğe geç
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
How could I upgrade to the maximum limit of each of parts inside iMac?
How could I upgrade to the maximum limit of each of parts inside this iMac?
  • Graphics Card?
  • DDR2 to SDRAM?
  • HD RPM?
  • Interface?
  • Modem?
  • Firewire?
  • Processor?
  • Cache Memory
… anymore?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
  • Graphics Card? - ATI Radeon X1600. Your system uses a built-in GPU so there is no options here.
  • DDR2 to SDRAM? - This is not possible. Your system has 200-pin PC2-5300 (667MHz) DDR2 SO-DIMM
  • HD RPM? - Replacing the HDD to a higher RPM drive will get you that. But you more likely want to get a SSHD drive like a [bağlı ürün eksik veya kapalı: IF107-129]
  • Interface? - The systems SATA port can’t be upgraded. Your system is limited to 1.5 Gb/s
  • Modem? - No built-in modem. Are you asking about the Ethernet port which offers 10/100/1000BASE-T connection
  • Firewire? - Not upgradable only offers 400 Mb/s
  • Processor? - Limited to Core 2 Duo CPU’s used by Apple
  • Cache Memory - L2 is part of the processor
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Here is what I would do if I were in your situation. @danj provides the answers to your questions of what you want to upgrade.
Upgrade the storage and improve boot time and read/write speed in your iMac Intel 17", 20", and 24" with this SSD upgrade kit. Görseli
Ürün
iMac Intel 17", 20", and 24" 2006 SSD Upgrade Kit
$82.99
Max your iMac Intel 20" EMC 2118 (Late 2006) with 4 GB RAM. Upgrade bundle includes all the parts and tools needed to mod your iMac. Görseli
Ürün
iMac Intel 20" EMC 2118 (Late 2006) Memory Maxxer RAM Upgrade Kit
$29.99
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier. Görseli
Ürün
Arctic Silver ArctiClean
$11.99
Electronics Skills Görseli
Kılavuz
How to Apply Thermal Paste
Zorluk:
Orta
5 - 20 minutes
iMac Intel 20" EMC 2105 and 2118 RAM Görseli
Kılavuz
iMac Intel 20" EMC 2105 and 2118 RAM Replacement
Zorluk:
Kolay
iMac Intel 20" EMC 2105 and 2118 PRAM Battery Görseli
Kılavuz
iMac Intel 20" EMC 2105 and 2118 PRAM Battery Replacement
Zorluk:
Orta
40 minutes - 1 hour
iMac Intel 20" EMC 2105 and 2118 Hard Drive Görseli
Kılavuz
iMac Intel 20" EMC 2105 and 2118 Hard Drive Replacement
Zorluk:
Orta
15 - 50 minutes
iMac Intel 20" EMC 2105 and 2118 Heat Sinks Görseli
Kılavuz
iMac Intel 20" EMC 2105 and 2118 Heat Sinks Replacement
Zorluk:
Çok zor
iMac Intel 20" EMC 2105 and 2118 CPU Fan Görseli
Kılavuz
iMac Intel 20" EMC 2105 and 2118 CPU Fan Replacement
Zorluk:
Zor
iMac Intel 20" EMC 2105 and 2118 Hard Drive Fan Görseli
Kılavuz
iMac Intel 20" EMC 2105 and 2118 Hard Drive Fan Replacement
Zorluk:
Zor
iMac Intel 20" EMC 2105 and 2118 Optical Drive Fan Görseli
Kılavuz
iMac Intel 20" EMC 2105 and 2118 Optical Drive Fan Replacement
Zorluk:
Orta
iMac Intel 20" EMC 2105 and 2118 Dual Hard Drive Görseli
Kılavuz
Installing iMac Intel 20" EMC 2105 and 2118 Dual Hard Drive
Zorluk:
Orta
iMac Intel 20" EMC 2105 and 2118 CPU Görseli
Kılavuz
iMac Intel 20" EMC 2105 and 2118 CPU Replacement
Zorluk:
Çok zor
10 hours
Puan 3
Yorum Ekle
Yanıtını ekle
Dave Bernard sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 178
