Replacing drive and yellow connecting (1210) ruined when removing
Part to connect to drive cable 1210 yellow cable is not fitting worried i ruined it removing?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Note that there is a locking tab on the connector that needs to be up when you insert it, then is pushed down to lock it into position. See step #14 of this guide
MacBook Pro 13" Unibody Mid 2012 Hard Drive Cable Replacement
Bu yanıt yardımcı oldu mu?
Yep that cable connected to a white box separate fron the drive cable ..connects to it
Heres the pic of part needed
It wont post but u had it pointed out in answer above
Here's the needed part MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable (with bracket)
@danj, it's not on the cable but on the bracket. It's the IR sensor.
@mayer - To quick with the link - Fixed
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 69
1 Yorum
Can you post a few pics so we can see what you are talking about Adding images to an existing question
Dan tarafından
