MacBook not charging. Works only when plugged in.
My MacBook Pro 13” (Early 2015) does not charge. It’s battery stays at 1%. It only works when plugged in And turns off as soon as I unplug.
- MagSafe connector LED is Amber.
- I have tried resetting SMC and PRAM.
- My battery has 715 cycles.
- System information says it has 25% battery health.
- Running Diagnostics says: “The battery may not be charging properly“ - “Disconnect the MagSafe power adapter from the computer and the power outlet, then reconnect. Run the test again.”
Does this look like a battery problem or MagSafe DC-in problem?
Edit 1:
Screenshot of CoconutBattery
Screenshot of System Information > Power
Edit 2:
I got my MacBook battery replaced and it’s working fine now :)
Bu iyi bir soru mu?
2 Yorum
Install this gem of an app! CoconutBattery with the MagSafe connected take a snapshot of the apps main window so we can see how things look more clearly. Post it here for us to see Adding images to an existing question
Dan tarafından
@danj I have edited the post with screenshot of CoconutBattery and an additional screenshot of System Information > Power.
Rahul Sharma tarafından
