ifixit battery replacement issues
So I replace the battery with the ifixit kit following this guide.
The laptop starts and recognized the battery and worked without the power cord. A couples of days ago the laptop won't start on battery only connected with the USB power adapter and also now have a blinking screen and the spacebar and keys have some troubles
Also, the OS says battery services recommended
Bu iyi bir soru mu?
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
I fear your battery is bad.
Dan tarafından
I've updated the question with the coconut screenshot as suggested by @danj . I gonna reset NVRAM/PRAM and SMC
Hector Sabillon tarafından
@hsabillon - I'm sorry to say your battery does look bad. It also looks like the charging logic is also damaged.
But before you get a new battery you'll need to get your systems charging logic fixed.
Dan tarafından
What are the odds that the replacement battery from iFixit also comes bad... @danj how can I fix the system charging logic?
@hsabillon - Looking bad is not the same as being bad when your charging logic is not working!
To get your system fixed will take some deeper skills and access to the parts. This is beyond most DIY folks.
Dan tarafından
6 tane daha yorum göster
