Hi @ shadow hunter
I don't know the keyboard and I don’t know music but since all the dead keys at one end of the keyboard are they all the same note (but different key) or maybe two notes only?
Electrically most keyboards are the same, i.e. Yamaha, Korg, Casio etc. That is they use two wires per note for two notes to signal the control board which sound to play. The notes are differentiated by diodes on the keyboard board
Most keyboards have a ribbon cable going from the control board to the keyboard boards which are under the keys. These boards are then connected to each other, so it may be as you say simply a loose connection between the boards.
Here’s an image from a Yamaha keyboard to show what I mean. It shows a layout how the 3 keyboard boards (GHL boards) connect to the control board (DM board)
(click on image to enlarge)
With the wiring you will notice that the C# and G notes on the GHL-88H board (upper or right end of keyboard) share the same two wires (17 & 11 on connector) throughout the multiple on the board shown and this is multipled to the other GHL boards (-88M & -88L) under the keyboard for the other C# and G notes and then all connect back to the control board. The same with the other notes i.e. D5 & G#, D# & A etc.
That is not to say that the cable pinout will be the same for your keyboard but the principle should be similar.
It could also be a board problem as described and fixed in this link Korg B1 - specific notes don't work, problem with circuitry In this keyboard three notes C, E & G# were affected and not just two but again the principle is the same
I couldn’t find a service manual for your model so hopefully this is of some help if you manage to open yours up.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
0
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
Can you take a picture? Adding images to an existing question
Andrew S tarafından
Hi,
Did you also clean the board that the rubber contacts come into contact with when pressed, you didn't say?
jayeff tarafından
Thanks for your response. Yes, i tried cleaning the board and rubber pads but nothing works. I am thinking the problem is something else.
I transported the piano during house move and that might have loosened up a wire?
But i am not sure how to open it up and where to even look.
Since all the keys are grouped and on the higher end of the keyboard my hypothesis is that it is some other problem.
shadow hunter tarafından
Hi, did you manage to find a solution? I have the same problem
Axel MN tarafından
