Ana içeriğe geç
The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
Need help identifying a capacitor
Hello,
I got my day one switch broken because of a malfunctioning charger.
when I plugged the charger I got an error similar to this one https://imgur.com/SDzL2ea
I did not capture it, but after that the switch would not start anymore.
After plugin the original charger, the switch can still charge the battery (I saw the battery voltage increase), but swill won't power on, event after hard reset, etc..
It will not enter rcm as well so I'd say the cpu doesn't start.
I did test all visible capacitors for shorts and only found one with both side grounded.
I can try replacing this capacitor but I need help to find its value.
Any idea on what other thing I should check would be appreciated.
Thanks!
Update (07/03/2022)
Here is another highres image of the board
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
have you checked to see if its grounded?
tarafından
It is indeed grounded (both side). Now I know it is a ferrite bead, does it matter?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This is a ferrite bead not a capacitor. It is used to filter out high frequency noise and it is meant to have a very low resistance and once it fails it tends to actually be an open circuit.
As for diagnosis attempt you would have to show some more detailed images and give us some voltage readings.
Good luck !
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Hello,
Thanks for the hint! (facepalm)
From visual inspection I don't see anything suspicous I can show you.
Where should I start about the voltages?
I found one check on the pin 5 of M92T36 and found 3.2V
tarafından
@Pierre Tardy M92T36 is a charging IC and as stated above we already know it charges.
Audio/video power ic could be a place to look as well.
From what I see the switch has not been taken fully apart so I would start by taking the board out and actually taking a good look at it, see if there is any blown components or discolorations
tarafından
Yorum Ekle
Yanıtını ekle
Pierre Tardy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 617
