Ana içeriğe geç
Announced on October 16, 2014, identifiable by the model number A1347 and EMC 2840.
Flashing question mark folder on boot up
I was gifted a Mac Mini model A1347, I believe its a late 2014 model. 2.6GHz Intel Core i5 with 8gb of LPDDR3. I was told the Mac has only been used a handful of times since its been purchased. When I tried to boot, I got a flashing ? folder, and after research I've found that this is most likely because the mac no longer has a working operating system. I'm not familiar with Apple products at all, so I'm wondering what my next course of action should be. Attempt to boot from a USB with a current OS? Would Geek Squad possibly still work on it even though its outdated? Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If you have another Mac: https://macdaddy.io/install-disk-creator...
Download Your Desired MacOS (I recommend 10.14 Mojave) and Follow they're guide...
Otherwise Hold Down: https://support.apple.com/en-us/HT204904
When In MacOS recovery, Go to Disk Utility, Check for a Partition that could have MacOS.
If there isn't one, Try Partitioning it to MacOS Extended (Journaled). Then try to install MacOS.
IF THAT DOESN'T WORK, It's likely A failed Hard Drive/SSD.
Part: OWC Aura Pro X2 SSD or [bağlı ürün eksik veya kapalı: IF107-098] or [bağlı ürün eksik veya kapalı: IF107-142]
Guide: Mac mini Late 2014 Hard Drive Replacement or Mac mini Late 2014 SSD Replacement
Replace or upgrade the PCIe solid-state drive in a variety of Macs. Görseli
Ürün
OWC Aura Pro X2 SSD
$239.99
Mac mini Late 2014 SSD Görseli
Kılavuz
Zorluk:
Orta
15 minutes
Mac mini Late 2014 Hard Drive Görseli
Kılavuz
Zorluk:
Orta
30 minutes - 2 hours
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Lucky for you there's an entire page on this exact issue. It's for MacBook, but the concept is largely the same.
As a former Geek I can say with confidence, Geek Squad would also still work on this if you decide to go down this route. Although it's usually a pretty straight forward. Bear in mind your options may be somewhat limited depending on what they find. If it's a hardware issue, that isn't something they can take care of in store.
Puan 1
1 Yorum:
@flannelist - You Beat me to it! :-)
tarafından
Yorum Ekle
Yanıtını ekle
Christian Berent sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 472
