Ana içeriğe geç
The Galaxy Watch Active2 is a smartwatch from Samsung Electronics. Its model number is SM-R825, SM-R830, or SM-R835 and was released in August 2019. Repair your Samsung Galaxy Watch Active2 with these guides.
34 Soru Tümünü görüntüle
My watch does not power on, or charge
Watch will not power on anymore, will not charge either
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Have you tried a hard reset?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi Nazario,
You've got three main places to look if your watch isn't charging; the charger, the charging cord and the battery. Odds are it's one of those three things in most cases.
You'll want to try a different charger and/or a different charging cord to try and eliminate those as a suspect. If it still doesn't work, the next most likely source of a failure to charge would be the battery. Fortunately, iFixit has both a guide to replacing the battery available as well as selling the battery itself, so if that's the problem, they've got you covered. Here's a link to the guide you'll need to do the replacement.
Samsung Galaxy Watch Active2 Battery Replacement - iFixit Repair Guide
You'll need to order the correct battery for your watch; it appears they come in 40 and 44 mm models so pick the one that fits your watch. The guide has links to both where you can purchase them.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Nazario Arteaga sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 66
