Ana içeriğe geç
Acer Aspire E5 serisi, merkezi Yeni Taipei Şehri, Tayvan'da bulunan bir elektronik şirketi olan Acer, Inc. tarafından üretilen ve satılan bir dizüstü bilgisayar serisidir. Acer Aspire E5 serisi 2015 yılında tanıtılmıştır.
Your DIMM1 and DIMM2 Module Organization is not the same
How do I fix the error "Your DIMM1 and DIMM2 Module Organization is not the same?"
my acer is a E5-510
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
1 Yorum
what to do 2001 i am buy
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @rosemarylouise
Have you recently upgraded the memory in the laptop?
The message is saying that there's a problem with the memory modules in the laptop e.g. they're not the same or perhaps one is faulty.
First try a power refresh and check if that resolves the problem.
  • Turn off the laptop if on and then disconnect the charger if connected.
  • Remove the battery from the laptop
  • Press and hold the laptop's Power button for a full 30 seconds and then release it.
  • Reinsert the battery, reconnect the charger and turn on the laptop and check.
If still no good, try reseating (remove/replace) the memory modules and then check.
Here's a video that may help. I realize that it is not your model but it should be the same as far as the location of the memory slots. Not the easiest as they're on the underside of the motherboard.
If it still fails after doing this then most probably there's a faulty memory module or memory slot on the motherboard. Try starting the laptop, using only one module at a time to see if you can isolate which module or perhaps which memory slot is the problem.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Meu Acer E5 estava assim, troquei o diodo duplo da CMOS no meu caso o d22, algumas placas é o d23 ou d5, ele é o responsável por chavear os 3.3v da bateria da bios (data/hora) e da tensão primária, aparentemente medindo parecia não estar com problema mas alguma pequena variação nele pode dar esse tipo de defeito. Troquei e sanou o problema.
Google translate:
My Acer E5 was like this, I changed the double CMOS diode in my case the d22, some boards are the d23 or d5, it is responsible for switching the 3.3v of the bios battery (date/time) and the primary voltage, apparently Measuring it didn't seem to be a problem but a little variation in it can give this type of defect. I replaced it and it fixed the problem.
Puan 0
Yorum Ekle
Yanıtını ekle
Rosemary Allan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 33
Son 30 gün: 170
Her zaman: 22,818
