Ana içeriğe geç
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
Trying bootcamp can damage efi chip?
Not being able to install Bootcamp from a macbook catalina a1278 (mid 2012), I made a partition and installed windows from my other macbook (2011). In which both systems work perfectly.
Now when I installed the SSD disk in macbook 2012, at first it boots perfectly in mac os catalina. And from settings, select the bootcamp partition as the boot disk. and from there everything died.
When you turn on the macbook, "No bootable device" also appears:
The Alt (option) key does not work, it just turns gray and after a minute the text appears
I reset smc, pram and the same thing still appears
I tried to boot from online recovery mode but when the load is finished an x ​​appears
I disconnected all the connectors and peripherals and the text continues to appear
In the end I tried to boot without the flex and the SSD disk and that legend continues to appear
What else can I do?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
There are other hidden structures now within APFS file system which prevent you from copying Windows folder to another system.
As painful as it is you need to do a clean install.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Sergio Reales sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 30
