Ana içeriğe geç
Acer Chromebook CB3-532-C47C Battery Replacement
Neye ihtiyacın var
  1. Acer Chromebook CB3-532-C47C Battery Replacement, Back Panel: adım 1, 2 resimden 1. Acer Chromebook CB3-532-C47C Battery Replacement, Back Panel: adım 1, 2 resimden 2.
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Battery Replacement: adım 2, 2 resimden 1. Acer Chromebook CB3-532-C47C Battery Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Battery Replacement, Remove the battery cable: adım 3, 1 resimden 1.
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Battery Replacement, Battery: adım 4, 2 resimden 1. Acer Chromebook CB3-532-C47C Battery Replacement, Battery: adım 4, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the two black 5.5 mm screws securing the battery.
  5. Acer Chromebook CB3-532-C47C Battery Replacement: adım 5, 1 resimden 1.
    • Remove the battery from the laptop.
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
3 farklı kişi bu kılavuzu tamamladı.
Sadie Brown
967 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 üyesi
UMASSD-SINCLAIRE-F21S3G2
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 42
Her zaman: 1,718
