Ana içeriğe geç
Anker Soundcore Space One Battery Replacement
Neye ihtiyacın var
  1. Anker Soundcore Space One Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Flip over the device so you can see the Soundcore symbol on the back two ear pieces.
    FixBot'a Sor
    Yorum Ekle
  2. Anker Soundcore Space One Battery Replacement: adım 2, 2 resimden 1. Anker Soundcore Space One Battery Replacement: adım 2, 2 resimden 2.
    • Take a strong spudger (metal or plastic) and carefully insert it into the lining between the two back ear pieces.
    • Using a metal spudger (like the one pictured) can cut you if not used correctly. Please be mindful of where you insert it if you choose to use one
    • Removing the cover can take a couple of minutes. However, don't be aggressive while removing it, as you could damage the interior components under the back earpiece
    FixBot'a Sor
    Yorum Ekle
  3. Anker Soundcore Space One Battery Replacement: adım 3, 3 resimden 1. Anker Soundcore Space One Battery Replacement: adım 3, 3 resimden 2. Anker Soundcore Space One Battery Replacement: adım 3, 3 resimden 3.
    • Carefully remove the cover to reveal the battery.
    • Take a spudger and carefully lift the battery from the interior components.
    • Take care not to warp, bend, or puncture the battery.
    • The battery has a layer of adhesive under it. If necessary, use a hairdryer to lightly heat the battery to loosen the battery adhesive.
    FixBot'a Sor
    Yorum Ekle
  4. Anker Soundcore Space One Battery Replacement: adım 4, 1 resimden 1.
    • Lift out the battery.
    FixBot'a Sor
    Yorum Ekle
  5. Anker Soundcore Space One Battery Replacement: adım 5, 1 resimden 1.
    • Desolder the battery connections.
    FixBot'a Sor
    Yorum Ekle
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Malcolm Hewlett
433 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-3, Botvin Spring 2025 UMass Dartmouth, Team 2-3, Botvin Spring 2025 üyesi
UMASSD-BOTVIN-S25S2G3
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 46
Son 30 gün: 195
Her zaman: 1,979
