Ana içeriğe geç
Bose QuietComfort 35 Battery Replacement
Neye ihtiyacın var
  1. Bose QuietComfort 35 Battery Replacement, Battery: adım 1, 3 resimden 1. Bose QuietComfort 35 Battery Replacement, Battery: adım 1, 3 resimden 2. Bose QuietComfort 35 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • The earcup cushions of the Bose QC 35 are held in place by small plastic clips.
    • Grab the cushion of the left earcup and gently pull it to the center of the earcup to free it from the plastic clip holding it in place.
    • Repeat this procedure for all clips that hold the cushion in place.
    • Remove the left earcup cushion.
    gibts irgendjemand der dies als service anbietet?
    no name - Yanıt
  2. Bose QuietComfort 35 Battery Replacement: adım 2, 3 resimden 1. Bose QuietComfort 35 Battery Replacement: adım 2, 3 resimden 2. Bose QuietComfort 35 Battery Replacement: adım 2, 3 resimden 3.
    • Carefully peel off the protective cloth which covers the inside of the earcup.
    • The protective cloth is held in place by mild adhesive. If the cloth starts to rip during the removal, apply an heated iOpener to the cloth or use a hairdryer/heatgun at the lowest setting to loosen the adhesive.
  3. Bose QuietComfort 35 Battery Replacement: adım 3, 1 resimden 1.
    • Remove the two Phillips #00 screws (6.2 mm length).
  4. Bose QuietComfort 35 Battery Replacement: adım 4, 3 resimden 1. Bose QuietComfort 35 Battery Replacement: adım 4, 3 resimden 2. Bose QuietComfort 35 Battery Replacement: adım 4, 3 resimden 3.
    • Turn the headphones over.
    • Insert an opening pick into the gap between the plastic cover and the earcup frame.
    • Use the opening pick to pry up the plastic cover of the left earcup.
    • Remove the plastic cover.
  5. Bose QuietComfort 35 Battery Replacement: adım 5, 3 resimden 1. Bose QuietComfort 35 Battery Replacement: adım 5, 3 resimden 2. Bose QuietComfort 35 Battery Replacement: adım 5, 3 resimden 3.
    • To avoid melting the speaker diaphragm by exposing it to too much heat in the next steps we advise preparing a protection.
    • Cut a cardboard as shown in the pictures so it covers everything inside the earcup but the battery cover.
    • Place the cover inside the left earcup.
  6. Bose QuietComfort 35 Battery Replacement: adım 6, 1 resimden 1.
    • Even with a heat protector in use we highly recommend to start with low heat to loosen the adhesive of the battery cover and to raise it slowly (maximum of 100°C) if the adhesive doesn't soften.
    • Do not aim your heat gun vertically onto the battery cover but only in a flat angle facing the straight edge of it.
    • Use your heat gun to loosen the adhesive underneath the edge of the battery cover.
    This is absolutely futile. I have a rework station, and I set the blower to 99 C. I heated this edge for 5-10 minutes straight, which had no discernible effect on the glue. Harsh prying at the edge with a small screwdriver after heating didn't budge it.
    Raunchy Butts - Yanıt
    I second this, 100C is useless here. I went to 150C around all edges at an angle, 90 degree corner loosened first then slowy worked around it.
    Samuel Stanaitis - Yanıt
  7. Bose QuietComfort 35 Battery Replacement: adım 7, 2 resimden 1. Bose QuietComfort 35 Battery Replacement: adım 7, 2 resimden 2.
    • Avoid puncturing the battery during the following process. Do not use metal tools or excessive force when working near the battery.
    • Insert the edge of an opening tool underneath the bottom corner of the battery cover. This requires some force.
  8. Bose QuietComfort 35 Battery Replacement: adım 8, 2 resimden 1. Bose QuietComfort 35 Battery Replacement: adım 8, 2 resimden 2.
    • Slide the opening tool along the edge of the battery cover to loosen the adhesive underneath and create a small gap.
  9. Bose QuietComfort 35 Battery Replacement: adım 9, 3 resimden 1. Bose QuietComfort 35 Battery Replacement: adım 9, 3 resimden 2. Bose QuietComfort 35 Battery Replacement: adım 9, 3 resimden 3.
    • Insert the flat end of a spudger between the battery cover and the battery.
    • Avoid to use the spudger as a lever when working close to the battery.
    • Use to spudger to carefully separate the plastic cover from the earcup. Avoid excessive force to the battery.
    What's that white part…I accidentally push it and it's bent down a little bit…is it gonna be a problem?…please help me
    Buvisuru Bandara - Yanıt
  10. Bose QuietComfort 35 Battery Replacement: adım 10, 2 resimden 1. Bose QuietComfort 35 Battery Replacement: adım 10, 2 resimden 2.
    • Remove the plastic cover from the left earpiece.
  11. Bose QuietComfort 35 Battery Replacement: adım 11, 1 resimden 1.
    • In the next step you will desolder the battery cables.
    • Use this picture as reference for resoldering during re-assembly or make your own photo if the cable order differs in your model.
    The iFixit battery does not have a white wire, which the original does. In addition to red and black, it has a blue one.
  12. Bose QuietComfort 35 Battery Replacement: adım 12, 3 resimden 1. Bose QuietComfort 35 Battery Replacement: adım 12, 3 resimden 2. Bose QuietComfort 35 Battery Replacement: adım 12, 3 resimden 3.
    • Use a soldering iron to desolder the three battery cables from the circuitboard.
    I didn't feel comfortable soldering in such a tight space, so instead, I cut the wires tot he old battery leaving as long of a wire as possible, making sure to cut each wire individually so it wouldn't have any chance of shorting. Then I soldered the long ends of the wire with the long ends of the new battery. Capped it off with the black shrink wrap stuff.
    abu hajar - Yanıt
  13. Bose QuietComfort 35 Battery Replacement: adım 13, 3 resimden 1. Bose QuietComfort 35 Battery Replacement: adım 13, 3 resimden 2. Bose QuietComfort 35 Battery Replacement: adım 13, 3 resimden 3.
    • Try not to deform or puncture the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged.
    • Insert the flat end of a spudger between the battery and the battery well.
    • Carefully pry the battery out of its recess.
    • You might want to change the position of the spudger a couple of times during this process to avoid excessive force to a single point of the battery.
  14. Bose QuietComfort 35 Battery Replacement: adım 14, 3 resimden 1. Bose QuietComfort 35 Battery Replacement: adım 14, 3 resimden 2. Bose QuietComfort 35 Battery Replacement: adım 14, 3 resimden 3.
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard. Replace it with a new battery.
    • Before installing a new battery remove any remaining adhesive from the headphones, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Make sure the battery cables are long enough to solder them onto the circuit board before installing new adhesive into the battery well.
    Hey, its circuit board not curcuit board.
    TimedIn - Yanıt
    Really Bruno? Then I could say that your comment has also mistakes!:
    "Hey, its circuit board not curcuit board." is not, it is: "Hey, it's circuit board, not curcuit board."
    Thanks Dominik Schnabelrauch, Scott Head and Jeff Stephens for this guide.
    Jesus Areso -
    Waste of $37, headphones show the battery fault white and amber flashing light. I can only assume the blue wire replaces the white wire since the instructions didn’t mention the color difference.
    WL270 - Yanıt
Sonuç
If possible, turn on your device and test your repair before installing new adhesive and resealing.
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%
63 farklı kişi bu kılavuzu tamamladı.
231.085 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
120 Üyeler
19.661 adet Kılavuz yazıldı
50Kılavuz Yorumları
спасибо ! будет полезно на будующее
Komar - Yanıt
Hallo, tolle Beschreibung. Vielen Dank dafür.
kann man bei den Bose 700 NC auch den Akku tauschen ?
Würde mich sehr freuen, wenn das so wäre. Hat da jemand evtl bereits schon Erfahrungen gemacht. Könnte mir vorstellen, dass viele 700 NC jetzt auch in das Alter kommen, in dem der Akku schwach wird.
Jens Nußbaum - Yanıt
Fk Bose for making it so difficult! They all care about the environment so much, don’t they?!
Batteries should be easily replaceable by any customer by themselves! Ear pads as well. Bose makes it harder so you would throw away your $300 headphones when battery dies. So much waste, plastic and other harmful stuff.
EU mandated to use USB-C on all devices to reduce the waste. Batteries are more harmful. They should make it mandatory for batteries to be user replaceable on tech like headphones. Manufacturers are making disposable headphones in purpose, obviously. Like AirPods and other similar earbuds. 18-24 months and you’re forced to throw them away. They should offer cheap battery replacement for AirPods and like earbuds as well. Maybe trade in deals. $70-$90 a bud isn’t cheap replacement.
Companies are lying about the love for the environment to make us buy more and add more harmful waste to it.
Usern@me - Yanıt
Actually, you can buy the earpads separately, even from BOSE themselves. I’ve replaced mine 3 or 4 times already and it’s pretty straight forward
Florian Wendelborn -
Thanks. Replaced my bose qc35 headphone battery. Works perfectly!
Thomas Maher - Yanıt
Wastage and ‘the environment’ are not quite the same thing. Most, if not all, of the material used to make the device is recyclable. It’s not an issue of damage to the environment for companies to make it difficult, or really, to not make it easy to replace a battery. You’ll find many companies do this in order to make their devices more water-resistant and dust-resistant. It’s not just because the big bad rich guys hate the planet.
If you’ve an issue with waste, contribute your waste to recycling. It’s your fault, not the company who made the product’s fault, if you don’t.
Great guide.
Harry Grade - Yanıt
Of course it is. Recycling needs energy. And recycling needs to seperate all the parts and composites. If you really think this earphone can get completly recycled you also think the the Santa Claus who brought this to you is real. Just use Google to see where all this electronic parts are “getting recycled”. Poorest African childs are burning it to get at least the rare materials of it for a tiny bit of money. Leave your beautyful and peaceful bubble where for every problem comes a great technological solution.
Felix Kallenbach -
"its your fault the product is wasteful, not the company's". oh wonderful, a corporate stooge.
never mind the fact that even if all parts are recyclable, theyre often too uneconomical for anyone to bother. or that companies specifically design for them to poorly repairable, which means theyll end up being thrown away or be damaged while trying to do so.
its reuse, reduce, and then recycle.
and recycling your tech is hardly a solution when the battery needs replacing. what an absolutely braindead take.
SBN -
Sir do you have tutorial to repair bose quitecomfort earbuds with left side not working? thank you
densus88 densus89 - Yanıt
Hi! Is this process needed to be done only for the left ear?
Andrei Verdes - Yanıt
Hi Andrei,
if you want to replace the battery there is only one in the left side of the headphones you need to replace.
Dominik Schnabelrauch -
that's really important to know as the right ear as well has a shut glued battery compartment.
Florian -
Dit ziet er lastig uit, dat gaat mij niet lukken. Weet iemand een bedrijf die dit doet? Bvd, Hans
Hans Wiltink - Yanıt
Did you find someone to fix your headphones for you?
David V. -
Unfortunately the battery is not available from reputable sources. I found a seller on ebay which sells compatible batteries from the brand vhbw. They look decent, however are available in 350mAh and 600mAh. If I see it correctly on the pictures above, the original battery has 495mAh.
Does anyone have a clue if those are legit and I can just use the 600mAh type?
Florian - Yanıt
I just installed the 600mAh from vhbw. It works fine so far.
350mAh, 495mAh and 600mAh are different capacities and the higher is better. What's important is the voltage (3.7V) which should not differ too much.
If vhbw is not lying on its numbers, with the 600mAh you should get more music on a single charge than with the original battery, that's it 😉
Quentin H. -
Centralsound.co carries the battery
Michael H -
If vhbw is not lying on its numbers, you should get more music on a single charge than with the original battery, that's it 😉
Quentin H. - Yanıt
I didn't need to use any heat to lift the battery cover.
I used a thin blade / knife to cut the adhesive between the lid and the headphones on the exposed sides and then managed to carefully pry it open with my fingers.
The adhesive, in my case, was a bit rubbery and thus not too difficult to remove.
Obviously, be very careful with sharp objects around batteries, as stated in the guide also.
To put it back on, I just cut a couple of very tiny pieces of double sided tape. We'll see if that holds up well.
Also, I was wondering if the glue is there to somehow protect the wearer in case the battery does break down and catch on fire.
And thus if you should glue the battery lid shut properly after replacing the battery. Any ideas?
Albert Einstein - Yanıt
The glue maintains the airtight integrity of the speaker and enhances bass response and noise canceling. You MUST maintain the seal or else sound can leak out. You can get feedback squeal if it leaks where it shouldn't.
Peter Wilson -
I want to know how to do QC45
Please write about QC45
Ifixit is best!
woojae0128 - Yanıt
So I surmise that the headphones come with one battery from factory. In the left cup. But there is space for anotherin the right ear cup... any reason i cant have a battery each side and double the life? I guess I'm the guinea pig..
DVS - Yanıt
How are you going to run the wires over? you do realize there are 2 folding joints and then the headband to worry about?
abu hajar -
Thank you, this was extremely helpful! If anyone is struggling to soften the glue, be patient. Even if it seems like it isn't doing anything, the cap will lift much more easily if you evenly pre-heat the glue as described here. The rest was comparatively easy. Keep in mind that the battery is also glued to the bottom of the case, so be patient and persevere, it'll come off!
Chris - Yanıt
OT: I use my BOSE 700 wired. Problem is I still have to charge them for NC and during charging they don't work. Is the a mod to charge and have NC at the same time? ??
Tom George - Yanıt
There is a way that only developers of the headphones can use to run the headphones while they are still charging. It requires sending a special command I think over serial but you would need to know exactly the protocol used. But the product owners in their infinite wisdom decided against this option because it would be too confusing to the customer.
The only way is to somehow hunt down and make friends with a QA person at Bose who still has access to all the knowledge and hardware to actually enable and send that command.
source: I was there when they made that decision.
abu hajar -
Easier than I thought. I had never done soldering before.
Samuel - Yanıt
Where can you find replacement #00 (6.2mm) screws (step 3)?
Jeff - Yanıt
Cannibalize an old cell phone, or remote control, or other obsolete electronic waste. Maybe some small electronic device. Maybe use tape around the edges of the aluminum cap, if all else fails
Peter Wilson -
I'm step 3, what is the silver looking ribbon. My dog eat the top cushion, side ear muffs, and took off the silver looking ribbon. I'm able to hear sound and everything else appears to work. I can find replacement parts for everything except for the silver stuf. Anyone have an idea?
christopher a avery - Yanıt
Has anyone had any luck with these instructions for the Bose AE2W? Can't find a guide but believe the design is fundamentally the same between these models with the exception of circuitry for noise cancellation, extra switches mics, etc.
Mine appear to have two allen shaped security headed screws in alongside a small Philips head.
George “G” Mullis - Yanıt
I always test the voltage present at the battery wires to confirm that the battery is dead or not holding a charge. It's no fun to replace a good battery with a new one just to have a dead headphones in the end. Sometimes the charging port in the OTHER side or associated flexible circuit boards used as conductors fail.
Peter Wilson - Yanıt
Thank you! It was easier than I thought :)
Peter - Yanıt
J'ai remplacé la batterie d'origine SYNERGY AHB110520CPS, 495 mAh, 3.7Vdc, par une batterie vhbw de 600 mAh, elle fonctionne parfaitement.
https://www.amazon.fr/dp/B09L5H4JDH?psc=....
Conseil, éviter de chauffer la trappe de la batterie, il y a un risque d'endommager le haut parleur du casque, c'est plus long mais j'ai utilisé une spatule en acier et l'ai introduit sous la trappe puis j'ai fait levier. Ensuite je nettoie les traces de colle restant. Pour le remontage je colle avec Colle professionnelle B7000 en tube de 15ml et le tour est joué.
Jean-Claude MARIN - Yanıt
Any suggestions on appropriate glue(s) to stick things back together? I would want to use two part plastic glues since that would bond them forever. But I don’t know what else is suitable
Aaron Lawrence - Yanıt
%#*!^@, I meant would NOT want to use two part plastic glues…
Aaron Lawrence -
What glue/ adhesive should I use for this repair?
Spag Tortellini - Yanıt
just some tips after i did this... if you are bad at soldering/ only have cheap soldering equipment, snip the old wires on old battery (negative first (black wire), closer to the battery to have as much available wire) and solder the new battery wires to it. it is much easier to solder 2 wires together (albeit very small and delicate, make sure to use general soldering practices like tinning the wire first, and using as least heat time as possible) than to risk damaging the pcb if you don't know what you're doing. also heat gun is not necessary, you can separate the battery panel with a razor if you're being careful. it is a rubber like adhesive, just go around the perimeter carefully and it will separate cleanly.
as someone else said, it is wise to clean up the old adhesive and use a light adhesive to glue the panel back in place to get a full seal.
wagwan yute - Yanıt
First time I've seen a 'Red' Charging light on my Bose QC35's. Gonna fully charge then fully drain, hopefully, I'll have a longer battery life again. Great guide. When re-applying the battery cover, I heated it up sections then pressed and held it down to allow the original glue to set it shut again.
Martin Erskine - Yanıt
Hello I replaced the battery in my bose quiet confort q35 II, but it still doesn't work, do you have any suggestion , it would upset me to throw them away since I also paid 32€ and lots of work to replace it. Thank you to anyone that would answer me with a good advice.
MrBean - Yanıt
Hello, Perfect ;:)
Marcel Michalski - Yanıt
Excellent instructions. This worked well. My QC 35 II is as good as new.
Thilo Gross - Yanıt
Muchas gracias por el manual. He reemplazado la batería de mis Bose QuietComfort 35 II y vuelven a funcionar a la perfección.
Miguel Ángel Ortiz - Yanıt
Bei mir ist leider durch die Wärme von einem Haarföhn das Gummi um die Ohrmuschel weich geworden und abgebröckelt, was die Ohrpolster festhält. Gibt es das irgendwo als Ersatzteil?
Riverside Wren - Yanıt
It was really difficult getting the metal front cover off and back on(dont why this guide says plastic). I ripped speaker cables off print board in the process(was able to solder it back). I would instead suggest cutting the wires to the old battery and soldering the new battery to the old wires because in that case the battery can be replaced by opening the head phones up from one side only(the easy side) with a much higher chance of success
Esben Skov Pedersen - Yanıt
There should be a warning in here to not short the red and black wires in the battery and be careful soldering to not short the pads.
tscharf - Yanıt
Hallo zusammen.
Habe den ganzen Reperatur-Prozess nach der Anleitung gemacht. Leider bekomme ich jetzt ein dauerhaftes rythmisches Piepen auf dem linken Kopfhörer. Der Kopfhörer verbindet sich und funktioniert an sich. Das Piepen ist aber sehr nervig. Habt ihr eine Idee?
Christoph Redl Privat - Yanıt
Despues de cambiar la bateria zumba fuerte el lado izquierdo, como lo soluciono?
lenin cuevas - Yanıt
Despues de cambiar la bateria, el lado izquierdo pita, tengo que desactivar la cancelación de ruido para que se deje de oír ese pitido, alguna solución?
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 104
Son 7 gün: 595
Son 30 gün: 2,875
Her zaman: 168,202
