Giriş
This guide details how to replace the battery in a DualSense Edge PlayStation 5 controller. If your controller won't power on or is draining quickly, follow this guide for battery replacement.
A functional battery provides power to your controller. Unfortunately, all batteries will drain after going through a repeated amount of charge cycles. If you notice that your charged battery is draining more quickly than usual or, even worse, has ceased to hold a charge at all, you should replace your battery.
If your battery is swollen, take extra care and handle it with caution.
Make sure the controller is turned off before you begin.
Neye ihtiyacın var
Use the opening pick to push the release latch on the back of the controller.
Pull the lever to the left and lift up to detach it from the controller.
Be careful with the tiny spring attached to the lever, as it is easy to lose once detached.
Use a pair of tweezers or your fingers to lift the cover from the controller.
Slide the flat end of the cover under the plastic tab in the rear case.
Place your opening pick under the low profile connector and pull it upward toward you to disconnect the battery.
4 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Yeah that’s great and all but without a battery all I can really do is kick rocks so what’s a guy gotta do to get a new one of those? Preferably with increased capacity but I’ll take an original new one too.
