Ana içeriğe geç
DualSense Edge Buttons Replacement
Neye ihtiyacın var
  1. DualSense Edge Buttons Replacement, Remove the front trim: adım 1, 3 resimden 1. DualSense Edge Buttons Replacement, Remove the front trim: adım 1, 3 resimden 2. DualSense Edge Buttons Replacement, Remove the front trim: adım 1, 3 resimden 3.
    • Place the controller on a work surface with the joysticks facing down.
    • Use a spudger or your finger to slide the Release tab to the left. The front trim should fall to the table.
    • If the front trim doesn't fall open, make sure the front trim has room to fall down and the Release tab is pushed all the way to the left.
    • Lift the controller up, leaving the front trim on the table.
    • During reassembly, insert the front trim at an angle so the top slots in first, then lower the trim into place and snap it onto the controller.
    FixBot'a Sor
    Yorum Ekle
  2. DualSense Edge Buttons Replacement, Remove the joysticks: adım 2, 3 resimden 1. DualSense Edge Buttons Replacement, Remove the joysticks: adım 2, 3 resimden 2. DualSense Edge Buttons Replacement, Remove the joysticks: adım 2, 3 resimden 3.
    • Flip the controller over so the joysticks are facing up.
    • Lift the metal lever that holds the joystick in place until the joystick slides out slightly.
    • Slide the joystick out from its slot.
    FixBot'a Sor
    Yorum Ekle
  3. DualSense Edge Buttons Replacement: adım 3, 1 resimden 1.
    • Repeat this process to remove the other joystick.
    FixBot'a Sor
    Yorum Ekle
  4. DualSense Edge Buttons Replacement, Insert an opening pick: adım 4, 3 resimden 1. DualSense Edge Buttons Replacement, Insert an opening pick: adım 4, 3 resimden 2. DualSense Edge Buttons Replacement, Insert an opening pick: adım 4, 3 resimden 3.
    • The rear trim is held in place by fragile plastic clips. Work slowly and gently to avoid breaking the clips.
    • If you installed the back button paddles included with your controller, remove them before beginning this process.
    • Insert the flat edge of an opening pick between the black portion of the rear trim and the top cover, near the joystick lever.
    • Slide the opening pick towards the bottom of the grip to release the clips.
    FixBot'a Sor
    Yorum Ekle
  5. DualSense Edge Buttons Replacement, Release the clips: adım 5, 2 resimden 1. DualSense Edge Buttons Replacement, Release the clips: adım 5, 2 resimden 2.
    • Slide the pick around to the rear of the controller and flip the controller over so the buttons are facing down.
    • Slide the opening pick around the edge of the rear trim to release the clips.
    FixBot'a Sor
    Yorum Ekle
  6. DualSense Edge Buttons Replacement, Remove the rear trim: adım 6, 3 resimden 1. DualSense Edge Buttons Replacement, Remove the rear trim: adım 6, 3 resimden 2. DualSense Edge Buttons Replacement, Remove the rear trim: adım 6, 3 resimden 3.
    • Slide the opening along the edge of the trim on the other grip.
    • Once all clips are released, remove the trim.
    • If at any point the trim feels stuck, stop and look for any clips that may have re-engaged and release them with the opening pick to avoid damaging them.
    FixBot'a Sor
    Yorum Ekle
  7. DualSense Edge Buttons Replacement, Remove the L1 and R1 buttons: adım 7, 3 resimden 1. DualSense Edge Buttons Replacement, Remove the L1 and R1 buttons: adım 7, 3 resimden 2. DualSense Edge Buttons Replacement, Remove the L1 and R1 buttons: adım 7, 3 resimden 3.
    • The L1 and R1 buttons are held in by two clips. If only one clip releases, move your spudger to the other side of the button to release the remaining clip. Don't continue prying on one side after a clip is released, or you risk breaking the other clip.
    • Insert the flat end of a spudger in the gap between the L1 and L2 buttons.
    • Use the spudger to pry out the L1 button.
    • The buttons tend to shoot out in this step. You can place your thumb over the button to prevent this.
    • Repeat this process to remove the R1 button.
    FixBot'a Sor
    Yorum Ekle
  8. DualSense Edge Buttons Replacement, Remove the screws: adım 8, 2 resimden 1. DualSense Edge Buttons Replacement, Remove the screws: adım 8, 2 resimden 2.
    • Remove the two 6.4 mm screws behind the L1 and R1 buttons.
    • Use a JIS J0 driver or an official iFixit Phillips PH0 driver, which is designed to be cross-compatible with JIS screws. Using a screwdriver other than an official iFixit driver or a JIS driver may result in stripped screws.
    FixBot'a Sor
    Yorum Ekle
  9. DualSense Edge Buttons Replacement, Lift the release bar spring: adım 9, 2 resimden 1. DualSense Edge Buttons Replacement, Lift the release bar spring: adım 9, 2 resimden 2.
    • Rotate the controller so the grips are pointing towards you.
    • Use a pair of angled tweezers to lift the right end of the release bar spring off of the white post.
    • The spring is located below the RB button.
    FixBot'a Sor
    Yorum Ekle
  10. DualSense Edge Buttons Replacement, Remove the trim release bar: adım 10, 3 resimden 1. DualSense Edge Buttons Replacement, Remove the trim release bar: adım 10, 3 resimden 2. DualSense Edge Buttons Replacement, Remove the trim release bar: adım 10, 3 resimden 3.
    • Use a pair of tweezers or your fingers to slide the release bar to the left.
    • Slide the release bar away from the controller to remove it.
    FixBot'a Sor
    Yorum Ekle
  11. DualSense Edge Buttons Replacement, Remove the rear case screws: adım 11, 1 resimden 1.
    • Remove the nine screws securing the rear case:
    • Seven 6.4 mm‑long screws
    • Two 10.5 mm‑long screws
    FixBot'a Sor
    Yorum Ekle
  12. DualSense Edge Buttons Replacement, Insert an opening pick: adım 12, 2 resimden 1. DualSense Edge Buttons Replacement, Insert an opening pick: adım 12, 2 resimden 2.
    • Insert the point an opening pick in the gap along the outside edge of one of the controller grips, near the bottom.
    FixBot'a Sor
    Yorum Ekle
  13. DualSense Edge Buttons Replacement, Separate the rear case: adım 13, 3 resimden 1. DualSense Edge Buttons Replacement, Separate the rear case: adım 13, 3 resimden 2. DualSense Edge Buttons Replacement, Separate the rear case: adım 13, 3 resimden 3.
    • Pry with the opening pick to separate the rear case from the front case by releasing the clips that hold them together.
    • Continue prying along the edge of the controller until one side is separated.
    FixBot'a Sor
    Yorum Ekle
  14. DualSense Edge Buttons Replacement: adım 14, 2 resimden 1. DualSense Edge Buttons Replacement: adım 14, 2 resimden 2.
    • Repeat this process to separate the other side of the rear case.
    FixBot'a Sor
    Yorum Ekle
  15. DualSense Edge Buttons Replacement, Remove the rear case: adım 15, 3 resimden 1. DualSense Edge Buttons Replacement, Remove the rear case: adım 15, 3 resimden 2. DualSense Edge Buttons Replacement, Remove the rear case: adım 15, 3 resimden 3.
    • If at any point the case feels stuck, stop and look for any clips that may have re-engaged and release them with the opening pick to avoid damaging them.
    • Hold the main body of the controller with one hand.
    • Lift the rear case with your other hand. It should lift at an angle.
    • Pushing slightly towards the L and R buttons, lift the rear case off of the controller and remove it.
    • During reassembly, make sure the plastic covers for the adaptive trigger assembly adjustment sliders are correctly installed over the sliders.
    FixBot'a Sor
    Yorum Ekle
  16. DualSense Edge Buttons Replacement, Replace the slider covers: adım 16, 3 resimden 1. DualSense Edge Buttons Replacement, Replace the slider covers: adım 16, 3 resimden 2. DualSense Edge Buttons Replacement, Replace the slider covers: adım 16, 3 resimden 3.
    • The rear case holds two small plastic covers for the adaptive trigger assembly adjustment sliders. These may have come off during removal. Place them back in the rear cover now to avoid losing them.
    • Use a pair of tweezers or your fingers to lift the cover from the controller.
    • Slide the flat end of the cover under the plastic tab in the rear case.
    • Make sure it is placed so it can move freely in its groove. The edge with the notch should be towards the middle of the controller.
    • If a cover got bent during the rear case removal or reassembly process, apply a small amount of heat with a hair dryer to restore it to its original shape.
    • During reassembly, you can use a small piece of painter's tape on the outside of the rear case to hold the covers in place.
    FixBot'a Sor
    Yorum Ekle
  17. DualSense Edge Buttons Replacement, Lift the battery: adım 17, 2 resimden 1. DualSense Edge Buttons Replacement, Lift the battery: adım 17, 2 resimden 2.
    • If your battery is swollen or deformed in any way, take appropriate precautions.
    • Lift the battery and move it to the right, so the connector underneath the battery is accessible.
    FixBot'a Sor
    Yorum Ekle
  18. DualSense Edge Buttons Replacement, Disconnect the battery: adım 18, 3 resimden 1. DualSense Edge Buttons Replacement, Disconnect the battery: adım 18, 3 resimden 2. DualSense Edge Buttons Replacement, Disconnect the battery: adım 18, 3 resimden 3.
    • Use the flat end of a spudger to pry up the low profile connector.
    • Only pry on the connector. Do not pry on the wires, as that may damage the wires.
    • Remove the battery.
    FixBot'a Sor
    Yorum Ekle
  19. DualSense Edge Buttons Replacement, Move the vibration motor cable: adım 19, 3 resimden 1. DualSense Edge Buttons Replacement, Move the vibration motor cable: adım 19, 3 resimden 2. DualSense Edge Buttons Replacement, Move the vibration motor cable: adım 19, 3 resimden 3.
    • This procedure is written using the R2 trigger assembly, which is on your left. The procedure to remove the L2 assembly is identical.
    • Use a pair of tweezers to disconnect the vibration motor cable by lifting the JST connector out of its socket.
    • This cable is connected to the back button board, between the RB or LB button and the vibration motor.
    • Continue lifting until the vibration motor cable is free of the clip on the trigger assembly.
    FixBot'a Sor
    Yorum Ekle
  20. DualSense Edge Buttons Replacement, Remove the trigger assembly screws: adım 20, 1 resimden 1.
    • Remove the two 6.4 mm‑long screws securing the trigger assembly.
    FixBot'a Sor
    Yorum Ekle
  21. DualSense Edge Buttons Replacement, Lift the trigger assembly: adım 21, 2 resimden 1. DualSense Edge Buttons Replacement, Lift the trigger assembly: adım 21, 2 resimden 2.
    • Lift the trigger assembly away from the controller and hold it so you can access the ribbon cable underneath it.
    • Do not try to fully remove the trigger assembly yet. It's still connected by a ribbon cable, which you'll disconnect in the next step
    FixBot'a Sor
    Yorum Ekle
  22. DualSense Edge Buttons Replacement, Disconnect the trigger assembly: adım 22, 3 resimden 1. DualSense Edge Buttons Replacement, Disconnect the trigger assembly: adım 22, 3 resimden 2. DualSense Edge Buttons Replacement, Disconnect the trigger assembly: adım 22, 3 resimden 3.
    • While holding the trigger assembly above the controller, use a pair of tweezers to disconnect the trigger assembly ribbon cable by gripping the pull tab and pulling away from the connector.
    • Remove the trigger assembly
    FixBot'a Sor
    Yorum Ekle
  23. DualSense Edge Buttons Replacement, Remove the R back button ribbon cable: adım 23, 2 resimden 1. DualSense Edge Buttons Replacement, Remove the R back button ribbon cable: adım 23, 2 resimden 2.
    • Make sure you removed both the L2 and the R2 adaptive trigger assemblies before continuing.
    • Use a pair of tweezers to disconnect the RB back button ribbon cable connector from the motherboard by griping the blue tab on the ribbon cable and pulling away from the connector.
    • The RB back button has an "R" engraved on the bracket and it's to your left.
    FixBot'a Sor
    Yorum Ekle
  24. DualSense Edge Buttons Replacement: adım 24, 2 resimden 1. DualSense Edge Buttons Replacement: adım 24, 2 resimden 2.
    • Use a pair of tweezers to move the RB back button ribbon cable out from its plastic clip.
    FixBot'a Sor
    Yorum Ekle
  25. DualSense Edge Buttons Replacement: adım 25, 2 resimden 1. DualSense Edge Buttons Replacement: adım 25, 2 resimden 2.
    • Use a pair of tweezers to disconnect the RB back button ribbon cable from the back button board.
    FixBot'a Sor
    Yorum Ekle
  26. DualSense Edge Buttons Replacement, Remove the rear microphone: adım 26, 2 resimden 1. DualSense Edge Buttons Replacement, Remove the rear microphone: adım 26, 2 resimden 2.
    • Use a pair of tweezers to disconnect the rear microphone ribbon cable from the motherboard.
    • Continue lifting to remove the microphone.
    • During reassembly, make sure to slot the plastic on the right edge of the microphone into the bracket on the microphone housing.
    FixBot'a Sor
    Yorum Ekle
  27. DualSense Edge Buttons Replacement, Disconnect the L back button: adım 27, 2 resimden 1. DualSense Edge Buttons Replacement, Disconnect the L back button: adım 27, 2 resimden 2.
    • Use a pair of tweezers to disconnect the LB back button ribbon cable from the motherboard by gripping the blue tab and pulling away from the connector.
    FixBot'a Sor
    Yorum Ekle
  28. DualSense Edge Buttons Replacement, Remove the battery bracket screws: adım 28, 1 resimden 1.
    • Remove the three screws securing the battery bracket:
    • Two 6.4 mm‑long screws near the middle of the left and right edges of the battery bracket
    • One 10.4 mm‑long screw near the center of the battery bracket
    FixBot'a Sor
    Yorum Ekle
  29. DualSense Edge Buttons Replacement, Remove the battery bracket: adım 29, 2 resimden 1. DualSense Edge Buttons Replacement, Remove the battery bracket: adım 29, 2 resimden 2.
    • Lift and remove the battery bracket.
    FixBot'a Sor
    Yorum Ekle
  30. DualSense Edge Buttons Replacement, Disconnect the front microphone ribbon cable: adım 30, 2 resimden 1. DualSense Edge Buttons Replacement, Disconnect the front microphone ribbon cable: adım 30, 2 resimden 2.
    • Use a pair of tweezers to disconnect the front microphone ribbon cable from the motherboard by gripping the blue pull tab and pulling away from the connector.
    • The front microphone connector is below LB back button connector, at the bottom of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  31. DualSense Edge Buttons Replacement, Disconnect the touchpad ribbon cable: adım 31, 2 resimden 1. DualSense Edge Buttons Replacement, Disconnect the touchpad ribbon cable: adım 31, 2 resimden 2.
    • Use a pair of tweezers to disconnect the touchpad ribbon cable from the motherboard by gripping the blue pull tab and pulling away from the connector.
    • This connector can be difficult to disconnect. If you grip the pull tab by the sides, as shown in the picture, squeeze just hard enough to grip the tab to avoid bending the tab and ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  32. DualSense Edge Buttons Replacement, Remove the motherboard: adım 32, 2 resimden 1. DualSense Edge Buttons Replacement, Remove the motherboard: adım 32, 2 resimden 2.
    • Insert the flat end of a spudger underneath the motherboard, below the USB-C port.
    • Use the spudger to lift the motherboard free of the small clips that secure it.
    FixBot'a Sor
    Yorum Ekle
  33. DualSense Edge Buttons Replacement: adım 33, 2 resimden 1. DualSense Edge Buttons Replacement: adım 33, 2 resimden 2.
    FixBot'a Sor
    Yorum Ekle
  34. DualSense Edge Buttons Replacement, Remove the speaker: adım 34, 2 resimden 1. DualSense Edge Buttons Replacement, Remove the speaker: adım 34, 2 resimden 2.
    • Use tweezers or your fingers to lift and remove the speaker from the center of the midframe.
    • During reassembly:
    • Check that your new speaker has a piece of foam on the back. If it doesn't, transfer the foam from the old speaker to the new one.
    • Install the speaker so the raised portion of the contact springs are to the right. If you are unsure of the correct orientation, check the motherboard and make sure the springs make contact with the posts on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  35. DualSense Edge Buttons Replacement, Remove the midframe: adım 35, 1 resimden 1.
    • Remove the five screws securing the midframe:
    • Three 6.4 mm‑long screws
    • Two 10.4 mm‑long screws
    FixBot'a Sor
    Yorum Ekle
  36. DualSense Edge Buttons Replacement: adım 36, 2 resimden 1. DualSense Edge Buttons Replacement: adım 36, 2 resimden 2.
    • Grab the vibration motor housings and lift the midframe to remove it.
    • Make sure the touchpad cable slides freely through the opening in the midframe.
    FixBot'a Sor
    Yorum Ekle
  37. DualSense Edge Buttons Replacement, Remove the create and option buttons: adım 37, 3 resimden 1. DualSense Edge Buttons Replacement, Remove the create and option buttons: adım 37, 3 resimden 2. DualSense Edge Buttons Replacement, Remove the create and option buttons: adım 37, 3 resimden 3.
    • Use tweezers or your fingers to lift and remove the Create button and the Option button.
    FixBot'a Sor
    Yorum Ekle
  38. DualSense Edge Buttons Replacement, Remove the button pads: adım 38, 3 resimden 1. DualSense Edge Buttons Replacement, Remove the button pads: adım 38, 3 resimden 2. DualSense Edge Buttons Replacement, Remove the button pads: adım 38, 3 resimden 3.
    • Use tweezers or your fingers to remove the silicone pads behind the directional buttons and the action buttons.
    • Note the orientation of the pads so you can reinstall the pads correctly.
    • During reassembly, firmly press the pads into place so the cutouts in the pads fully slot over the button housings.
    FixBot'a Sor
    Yorum Ekle
  39. DualSense Edge Buttons Replacement, Remove the springs: adım 39, 3 resimden 1. DualSense Edge Buttons Replacement, Remove the springs: adım 39, 3 resimden 2. DualSense Edge Buttons Replacement, Remove the springs: adım 39, 3 resimden 3.
    • Use angled tweezers to remove the two springs near the PS button cutout.
    FixBot'a Sor
    Yorum Ekle
  40. DualSense Edge Buttons Replacement, Remove the buttons: adım 40, 1 resimden 1.
    • Flip the front case over so the buttons fall out onto your work surface.
    • Alternatively, use tweezers to remove individual action buttons or the directional buttons.
    • During reassembly, use the alignment tabs to orient each button into its recess. Each one is keyed specifically for its recess and proper orientation.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Spencer Pennington
26.118 İtibar
127 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
10 Üyeler
18.434 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 31
Son 7 gün: 166
Son 30 gün: 749
Her zaman: 16,127
