Giriş
Follow this guide to replace a dead or worn-out battery in your Samsung Galaxy S23 Ultra.
If you need to replace the screen and battery assembly (the frame, screen, and battery together as one piece), follow this guide.
Your phone's lithium-ion battery has a limited lifespan. If your phone dies quickly and doesn't hold a charge, it may be time to replace the battery.
Note: Retaining water resistance after the repair will depend on how well you reapply the adhesive, but your device will lose its IP (Ingress Protection) rating.
Neye ihtiyacın var
Heat an iOpener and apply it to the right edge of the back cover for two minutes.
While you wait for the adhesive to soften, note the following:
There's adhesive securing the back cover around the perimeter of the frame.
Apply a suction handle to the back cover, as close to the center of the right edge as possible.
Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
Insert an opening pick into the gap.
Slide the pick back and forth along the right edge to separate the adhesive.
Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
Apply a heated iOpener to the bottom edge of the back cover for two minutes.
Insert a second opening pick at the bottom right corner.
Angle the pick upward to match the curved edge and rotate it around the bottom right corner.
Slide your opening pick to the bottom left corner to separate the adhesive.
Leave the pick in the bottom left corner to prevent the adhesive from resealing.
Apply a heated iOpener to the left edge of the back cover for two minutes.
Insert a third opening pick at the bottom left corner.
Angle the pick upward to match the curved edge and rotate it around the bottom left corner.
Slide your opening pick along the left edge to separate the adhesive, stopping when you reach the power button.
Leave the pick in the left edge to prevent the adhesive from resealing.
Heat an iOpener and apply it to the top edge of the back cover for two minutes.
Insert an opening pick in the gap at the top right edge.
Angle the pick upward to match the curved edge and rotate it around the top right corner.
Slide the pick to the top left corner to separate the adhesive.
Leave the pick in to prevent the adhesive from resealing.
Insert an opening pick in the gap at the top left edge.
Angle the pick upward to match the curved edge and rotate it around the top left corner.
Slide the pick toward the bottom camera to separate through the remaining adhesive, stopping before you reach the power button.
Grab and remove the back cover.
Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
If you're using custom-cut adhesives, follow this guide.
If you're using double-sided tape, follow this guide.
Use the pointed end of a spudger to pry up and disconnect the NFC antenna press connector from the motherboard.
Repeat for the wireless charging coil press connector.
Insert an opening pick between the right edge of the wireless charging coil and the battery.
Slide the pick along the right edge to separate the adhesive.
Use a Phillips screwdriver to remove the five 3.5 mm-long screws securing the NFC antenna and charging coil.
Use a Phillips screwdriver to remove the six 3.5 mm screws securing the loudspeaker.
Insert the pointed end of your spudger between the upper right corner of the loudspeaker and the frame.
Pry up to unclip the loudspeaker from the frame.
Grab and remove the NFC, wireless charging coil, and loudspeaker from the frame.
Use your spudger to pry up and disconnect the battery press connector.
Use your spudger to pry up and disconnect the secondary interconnect cable press connector from the motherboard.
Repeat for the primary interconnect cable.
Grab and remove the interconnect cables from the frame.
Use the point of your spudger to pry up and disconnect the screen press connector from the motherboard.
Use the point of your spudger to pry up and disconnect the left 5G mmWave antenna press connector.
Use your finger to push the antenna cable away from the battery.
Use your fingers to carefully peel the large blue battery pull tab from the left side of the battery.
With one hand, fold the two upper and lower tabs out of the way of the battery and firmly hold them down against the frame.
With your free hand, grip the blue center pull tab and pull straight up with firm, steady force to fully separate the battery adhesive.
Lay the battery over the right edge of your phone.
Use your fingers to peel the battery's plastic film from the frame.
If there's any battery adhesive on the frame, use tweezers or your fingers to remove it.
If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
Orient the replacement adhesive so the clear liner is on the bottom and test-fit it into the battery recess.
Hold the battery above its recess and reconnect the press connector—this ensures proper fit and alignment.
Firmly press the battery into its recess to secure it with the adhesive.
Disconnect the battery before continuing.
To reassemble your device, follow these instructions in reverse order, starting with this step.
For optimal performance, calibrate your newly installed battery after reassembling your phone.
36 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
Perfecto todo, desde el envio, las herramientas y el paso a paso, muchas gracias y les deseo prosperidad!
So I replaced the battery and I noticed that it's capacity is slightly larger than the original. Now the back cover won't close entirely in the battery area on both sides. Not sure if I did something wrong. It's like the adhesive is not holding the cover in place.
Followed this to replace my wife's battery. Repair went great. This guide was quite good and made the process easy and worry free. Thanks a lot.
