Ana içeriğe geç
Google Pixel 4 Flash Assembly Replacement
Neye ihtiyacın var
  1. Google Pixel 4 Flash Assembly Replacement, Remove the SIM card tray: adım 1, 3 resimden 1. Google Pixel 4 Flash Assembly Replacement, Remove the SIM card tray: adım 1, 3 resimden 2. Google Pixel 4 Flash Assembly Replacement, Remove the SIM card tray: adım 1, 3 resimden 3.
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the left edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
  2. Google Pixel 4 Flash Assembly Replacement, Heat the back panel glass: adım 2, 1 resimden 1.
    • Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Google Pixel 4 Flash Assembly Replacement, Apply a suction cup: adım 3, 2 resimden 1. Google Pixel 4 Flash Assembly Replacement, Apply a suction cup: adım 3, 2 resimden 2.
    • Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
  4. Google Pixel 4 Flash Assembly Replacement, Insert an opening pick: adım 4, 2 resimden 1. Google Pixel 4 Flash Assembly Replacement, Insert an opening pick: adım 4, 2 resimden 2.
    • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  5. Google Pixel 4 Flash Assembly Replacement, Begin to slice the adhesive: adım 5, 3 resimden 1. Google Pixel 4 Flash Assembly Replacement, Begin to slice the adhesive: adım 5, 3 resimden 2. Google Pixel 4 Flash Assembly Replacement, Begin to slice the adhesive: adım 5, 3 resimden 3.
    • Slide the opening pick across the bottom towards the left corner to slice the adhesive.
    • With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  6. Google Pixel 4 Flash Assembly Replacement, Slice the lefthand-side adhesive: adım 6, 1 resimden 1.
    • Prepare an iOpener and apply it on the left edge of the phone for one minute.
  7. Google Pixel 4 Flash Assembly Replacement: adım 7, 2 resimden 1. Google Pixel 4 Flash Assembly Replacement: adım 7, 2 resimden 2.
    • Insert a second opening pick underneath the back panel directly over the charge port.
    • Slide the opening pick to the bottom left corner of the phone.
  8. Google Pixel 4 Flash Assembly Replacement: adım 8, 2 resimden 1. Google Pixel 4 Flash Assembly Replacement: adım 8, 2 resimden 2.
    • Slide the opening pick around the bottom left corner and across the left side of the phone to slice the adhesive.
    • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
    • Stop when you reach the top left corner, near the camera, and leave the pick inserted.
  9. Google Pixel 4 Flash Assembly Replacement, Slice righthand-side adhesive: adım 9, 1 resimden 1.
    • Prepare an iOpener and apply it on the right edge of the phone for one minute.
  10. Google Pixel 4 Flash Assembly Replacement: adım 10, 3 resimden 1. Google Pixel 4 Flash Assembly Replacement: adım 10, 3 resimden 2. Google Pixel 4 Flash Assembly Replacement: adım 10, 3 resimden 3.
    • With the first two opening picks still in place, insert a third pick on the lower part of the righthand side.
    • Slide the opening pick up towards the top of the phone, slicing the right side's adhesive.
    • Stop when you reach the top right corner, and leave the pick inserted.
  11. Google Pixel 4 Flash Assembly Replacement, Slice the top-side adhesive: adım 11, 2 resimden 1. Google Pixel 4 Flash Assembly Replacement, Slice the top-side adhesive: adım 11, 2 resimden 2.
    • Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
  12. Google Pixel 4 Flash Assembly Replacement, Lift up the back panel: adım 12, 3 resimden 1. Google Pixel 4 Flash Assembly Replacement, Lift up the back panel: adım 12, 3 resimden 2. Google Pixel 4 Flash Assembly Replacement, Lift up the back panel: adım 12, 3 resimden 3.
    • Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
    • Do not try to pull the panel all the way off yet, as it is still connected to the phone.
  13. Google Pixel 4 Flash Assembly Replacement: adım 13, 2 resimden 1. Google Pixel 4 Flash Assembly Replacement: adım 13, 2 resimden 2.
    • Continue swinging open the back panel until you can rest it on the left edge the phone, being careful not to put any stress on the attached ribbon cable.
    • During reassembly, this is a good point to power on your phone and test all functions before re-sealing the back panel. Be sure to power your phone back down completely before you continue working.
  14. Google Pixel 4 Flash Assembly Replacement, Disconnect the battery: adım 14, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Remove the five T3 Torx screws securing the battery connector shield:
    • Four 4.0 mm screws
    • One 2.1 mm screw
  15. Google Pixel 4 Flash Assembly Replacement: adım 15, 2 resimden 1. Google Pixel 4 Flash Assembly Replacement: adım 15, 2 resimden 2.
    • Use a pair of tweezers to remove the battery connector shield.
  16. Google Pixel 4 Flash Assembly Replacement: adım 16, 2 resimden 1. Google Pixel 4 Flash Assembly Replacement: adım 16, 2 resimden 2.
    • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
    • Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. Google Pixel 4 Flash Assembly Replacement: adım 17, 2 resimden 1. Google Pixel 4 Flash Assembly Replacement: adım 17, 2 resimden 2.
    • Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs.
  18. Google Pixel 4 Flash Assembly Replacement, Disconnect the back panel connector: adım 18, 1 resimden 1.
    • Use a T3 Torx driver to remove the two 4 mm screws securing the back panel connector cover.
  19. Google Pixel 4 Flash Assembly Replacement: adım 19, 2 resimden 1. Google Pixel 4 Flash Assembly Replacement: adım 19, 2 resimden 2.
    • Use a pair of tweezers to remove the back panel connector cover.
  20. Google Pixel 4 Flash Assembly Replacement: adım 20, 2 resimden 1. Google Pixel 4 Flash Assembly Replacement: adım 20, 2 resimden 2.
    • Using the pointed end of a spudger, pry up and disconnect the back panel connector.
  21. Google Pixel 4 Flash Assembly Replacement, Remove the back panel: adım 21, 1 resimden 1.
    • Remove the back panel.
    • During reassembly, follow this guide to install custom-cut adhesives for your device.
    • Follow this guide if you are using a pre-cut adhesive card.
  22. Google Pixel 4 Flash Assembly Replacement, Peel off the graphite adhesive layer: adım 22, 1 resimden 1.
    • The LED flash module is secured to the back panel underneath a graphite adhesive layer which will need to be removed.
    • Use tweezers on one of the bottom corners to pull up the adhesive enough to grab it with your fingers.
  23. Google Pixel 4 Flash Assembly Replacement: adım 23, 2 resimden 1. Google Pixel 4 Flash Assembly Replacement: adım 23, 2 resimden 2.
    • Peel back the graphite adhesive layer to expose the wireless charging coil, NFC pads, and LED flash module.
    • Completely remove the graphite adhesive layer.
  24. Google Pixel 4 Flash Assembly Replacement: adım 24, 3 resimden 1. Google Pixel 4 Flash Assembly Replacement: adım 24, 3 resimden 2. Google Pixel 4 Flash Assembly Replacement: adım 24, 3 resimden 3.
    • All sections of the flash module are secured to the back panel with some light adhesive.
    • Use a pair of tweezers to gently pry up and peel back the spectral and flicker sensor portion of the flash module.
  25. Google Pixel 4 Flash Assembly Replacement: adım 25, 2 resimden 1. Google Pixel 4 Flash Assembly Replacement: adım 25, 2 resimden 2.
    • Use a pair of tweezers or the pointed end of a spudger to peel up the back panel's microphone.
    • Before you install a replacement LED flash module, check the microphone's adhesive gasket:
    • If it is in good condition, you can re-use the gasket. Make sure that the gasket does not cover the hole.
    • If the gasket is pulled out of place, remove it and replace the adhesive with a pre-cut strip or Tesa tape.
  26. Google Pixel 4 Flash Assembly Replacement: adım 26, 3 resimden 1. Google Pixel 4 Flash Assembly Replacement: adım 26, 3 resimden 2. Google Pixel 4 Flash Assembly Replacement: adım 26, 3 resimden 3.
    • Pull the LED flash housing out of its hole on the back panel.
    • Remove the flash module.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
2 farklı kişi bu kılavuzu tamamladı.
Carsten Frauenheim
136.963 İtibar
371 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 51
Her zaman: 2,340
