Ana içeriğe geç
Google Pixel 5a Motherboard Replacement
Neye ihtiyacın var
  1. Google Pixel 5a Motherboard Replacement, Eject the SIM card tray: adım 1, 3 resimden 1. Google Pixel 5a Motherboard Replacement, Eject the SIM card tray: adım 1, 3 resimden 2. Google Pixel 5a Motherboard Replacement, Eject the SIM card tray: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    SIM Card Eject Tool
    $2.99
    • Insert a SIM card eject tool into the small hole on the right side edge of the frame.
    • A standard SIM card eject tool may be too wide for the job. Don't force the tool in—use a small paperclip, or a properly sized tool, like the SIM eject bit.
    • Press firmly until you feel the SIM card tray pop out.
    • Remove the SIM card tray from the phone.
    My sim car tray broken inside my mobile
    jaikumawat431 - Yanıt
    Any option to take out from my mobile
  2. Google Pixel 5a Motherboard Replacement, Precautionary notes: adım 2, 2 resimden 1. Google Pixel 5a Motherboard Replacement, Precautionary notes: adım 2, 2 resimden 2.
    • Be sure to turn off your device before you begin the repair.
    • You'll need to pry the screen up to remove it from the phone. Read the following notes carefully before proceeding.
    • Take note of the two seams on the edge of the phone:
    • Screen seam: This seam separates the screen from the rest of the phone. Do not pry at this seam.
    • Bezel seam: This is where the plastic bezel designed to protect the screen meets the frame. It's held in place by plastic clips. This is where you should pry.
    This will be clear if you examine your replacement part first.
    bcling - Yanıt
    True, but one may be disassembling the device prior to receiving their replacement 😉
    Niels Klassen -
    I'm not sure why it's recommended to pry at the bezel seam. I followed this guide but the bezel that's held in by clips, provides some additional housing for the front facing camera as well as the ear-speaker grille. I ended up separating the old screen from the bezel and putting the bezel back into the phone first, before installing the replacement screen.
    Kevin Kim - Yanıt
    My replacement screen did not come with the bezel, and I had to remove it from the old screen. I didn't notice this until i attempted to replace the screen. Be sure to look at your replacement screen prior to reassembly. It will save you some heartache. All was good though and the phone is working.
    jak ll - Yanıt
    1. "Be sure to turn off your device before you begin the repair". Kind of tough to do if you are replacing the screen because it is blank and you can't tell what is going on or select a "Power Off" option.
    2. To power off the phone, would be good to have instructions to disconnect the battery once the screen is disconnected from the rest of the phone.
    BlueNGray - Yanıt
  3. Google Pixel 5a Motherboard Replacement, Heat the right edge of the screen: adım 3, 1 resimden 1.
    • Apply a heated iOpener to the right edge of the display for one minute to soften the adhesive.
    • Depending on the strength of your device's adhesive, you may need to reapply the iOpener multiple times in order to weaken it enough.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Use the full length of the iOpener to soften the adhesive on the right edge and top or bottom. My repair required three applications of the iOpener.
    bcling - Yanıt
    I needed about 4 applications of the iOpener before the adhesive was weakened enough to stick the opening pick in.
    Ibukunoluwa Amusan - Yanıt
    Do you have to wait 10 minutes between each application?
    Joey -
    I heated the iopener twice for 30sec (weak microwave) then applied for a couple minutes without success. Then reheated iopener for 30 more sec. Then used the blue tool supplied in kit to help push down on bezzle and that did the trick to separate enough to get the picks in.
    Ilya Pittel - Yanıt
    While I appreciate that iFixit gives you everything required for the repair in a kit, I gave up on the iOpener after 2 applications and went for the heat gun. I have a Porter Cable heat gun (PC1500HG), kept it on a medium-low heat about an inch away and was able to get around the entire screen edge more quickly. After that, I was able to use the supplied opening picks and suction cup pretty easily.
    jb_ne - Yanıt
    Has anyone used a hair dryer? How long to safely apply the hair dryer?
    It Was A Dark & Stormy Phone - Yanıt
    I heated the iOpener twice at 30 seconds each and let it sit on the first long edge for 10-15 minutes (while watching TV). This seemed to soften the adhesive and I was able to insert the blue picks without much trouble using the suction cup. Patience is the key. I reheated the iOpener for another 30 seconds and that was enough to soften the top and bottom edge, about 8-10 minutes on each edge. There was enough heat left in the iOpener to soften the last long edge, another 6-8 minutes.
    Chuck Pietro - Yanıt
  4. Google Pixel 5a Motherboard Replacement, Bezel removal note: adım 4, 2 resimden 1. Google Pixel 5a Motherboard Replacement, Bezel removal note: adım 4, 2 resimden 2.
    • To remove the screen, you'll need to insert opening picks in between the black clips that secure the bezel to the midframe.
    • Note the optimal points of entry before proceeding.
    Use an old credit card or hotel key card to provide additional thickness and leverage to pop the bezel off.
    bcling - Yanıt
    This may seem like a no-brainer but I held the new screen against my broken phone and used a pencil to mark where each blue pick would go.
    Determined, but distracted - Yanıt
    This is a great idea! Thanks for posting it!
    Eric M -
    They did not send the 6 opening picks with the repair kit
    hema v - Yanıt
    Actually, they did send the picks, they were in the iopener. I successfully changed the screen
    hema v - Yanıt
  5. Google Pixel 5a Motherboard Replacement, Create a gap between the bezel and midframe: adım 5, 2 resimden 1. Google Pixel 5a Motherboard Replacement, Create a gap between the bezel and midframe: adım 5, 2 resimden 2.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Place a suction cup as close to the right edge of the screen as possible.
    • Lift the suction cup with a strong steady force until a small gap forms between the bezel and midframe.
    Do we use the suction cup before inserting the picks? After applying the I opener 3 plus times, I am having difficulty removing the broken screen. Any tips?
    William Maniss - Yanıt
    This was the most difficult part. What really helped was putting a piece of packing tape on the screen. It has to be wider than the suction cup. If there is any hint of a crack where the suction cup is located, it will not stick. I had to warm the right side and the top a couple of times to get the screen to give a little bit. It will only give just a little bit and you have to to slide the pick in with more force than I was comfortable with.. It really would help to have a third hand to hold the phone, pull the suction cup and the other to slide the pick in. I had to use my ring finger to apply force to the suction cup and with the same hand slide the pick between the phone and the screen. After this step it was easy peasy!
    Dustin Ashberry - Yanıt
    Agree this was the hardest part. I heated the right edge of the phone multiple times with the iOpener before the glue was soft enough to flex. My screen only had a crack, was not shattered. I had to wet the suction cup to get it to hold strong enough to pull up to open a gap to insert the pick. Once the first pick was in, heating the other edges and moving around the phone was fairly easy.
    Lisa McManis - Yanıt
    The screen itself has a large lip that makes it harder to insert the picks. what worked for me was pulling up the screen just enough to insert the pick slightly. next I rotated the pick towards the phone and pushed it down (the phones chassis has a bezel that will catch the tip so you can use a bit more force). Once the pick is inserted like that you can rotate away from the phone, pulling up the screen easily.
    Mason Tate - Yanıt
    Ended up using Gorilla tape on the screen, a more powerful suction cup from a windshield phone mount, moving it back 1/2 inch from the edge so the tape wouldn't peel from the edge when I pulled.
    Scott Chaney - Yanıt
    You definitely need a third hand to get the pick in, have someone nearby to help if possible.
    This is the step that requires the most energy.
    This was by far the most difficult part of the repair hands down. I heated the phone several times before the adhesive softened enough to stick a pick in
    Niels Klassen - Yanıt
    I was unable to use the technique shown here to lift up the edge. I used the iOpener and suction cup multiple times without being able to lift the edge even a little (might be a testament to my own physical weakness, though, haha). I ended up running a razor blade along the bezel seam until I was able to wiggle it in and then slowly wedge the picks in.
    Mary in CA - Yanıt
    This took me an 1.5 hrs. Just keep re-heating and re-applying the iOpener, and using your spudger to open it up. Don't give up! You got this!
    ccc - Yanıt
    My screen was beyond destroyed. I had it covered with tape and the suction cup wouldn't stick. I just let the iOpener rest on the edge nice and long and between the blue picks and my thumbnails I was able to get in there just fine. I did get a small crack in the bezel at one point but this was a spot where all the glass had come off. It didn't matter since this screen and bezel weren't going back on. If I had needed to keep the screen and bezel in good shape, I could have.
  6. Google Pixel 5a Motherboard Replacement, Insert an opening pick: adım 6, 2 resimden 1. Google Pixel 5a Motherboard Replacement, Insert an opening pick: adım 6, 2 resimden 2.
    • The bezel is connected to the midframe by a series of plastic clips which can be detached by inserting an opening pick at points all along the seam.
    • Insert the tip of an opening pick into the bezel seam about 4-5 cm from the bottom of the phone.
    Angling the opening pick downward helped with the initial opening
    barely_diy - Yanıt
    Probably easier to just use the opening tool instead of the opening picks. Also you may need to use the iopener (the bag you microwave) in the other 3 sides as well . After these tips it will be a breeze to open. Cheers!
    Froilan Rivero - Yanıt
  7. Google Pixel 5a Motherboard Replacement: adım 7, 2 resimden 1. Google Pixel 5a Motherboard Replacement: adım 7, 2 resimden 2.
    • Insert the tip of an opening pick into the bezel seam about 3-4 cm from the top of the phone.
  8. Google Pixel 5a Motherboard Replacement: adım 8, 2 resimden 1. Google Pixel 5a Motherboard Replacement: adım 8, 2 resimden 2.
    • Insert the tip of an opening pick into the bezel seam at the top of the phone.
    • If this step proves difficult, slide the pick along the top right corner of the phone until there is enough of a gap at the top for the opening pick.
  9. Google Pixel 5a Motherboard Replacement: adım 9, 2 resimden 1. Google Pixel 5a Motherboard Replacement: adım 9, 2 resimden 2.
    • Insert the tip of an opening pick into the bezel seam at the bottom of the phone.
    • If this step proves difficult, slide the pick along bottom right corner of the phone until there is enough of a gap at the bottom for the opening pick.
  10. Google Pixel 5a Motherboard Replacement: adım 10, 2 resimden 1. Google Pixel 5a Motherboard Replacement: adım 10, 2 resimden 2.
    • Insert the tip of an opening pick into the bezel seam on the left side of the phone, about 2 cm from the bottom of the phone.
  11. Google Pixel 5a Motherboard Replacement: adım 11, 2 resimden 1. Google Pixel 5a Motherboard Replacement: adım 11, 2 resimden 2.
    • Insert the tip of an opening pick into the bezel seam about 3-4 cm below the front-facing camera.
  12. Google Pixel 5a Motherboard Replacement: adım 12, 3 resimden 1. Google Pixel 5a Motherboard Replacement: adım 12, 3 resimden 2. Google Pixel 5a Motherboard Replacement: adım 12, 3 resimden 3.
    • Be sure to detach all the clips. Slice through any remaining adhesive with an opening pick.
    • Open the device from the right side like a book.
  13. Google Pixel 5a Motherboard Replacement: adım 13, 1 resimden 1.
    Magnetic Project Mat
    $19.95
    • Use a T3 Torx driver to remove the 4.6 mm-long screw securing the screen connector bracket.
    There is just this one screw.
    bcling - Yanıt
    One screw - super easy in that regard!
    My screw was a T4 not a T3.
    Jason Russell - Yanıt
  14. Google Pixel 5a Motherboard Replacement, Remove the connector bracket: adım 14, 2 resimden 1. Google Pixel 5a Motherboard Replacement, Remove the connector bracket: adım 14, 2 resimden 2.
    • Use a pair of tweezers to remove the screen connector bracket.
  15. Google Pixel 5a Motherboard Replacement, Remove the screen: adım 15, 2 resimden 1. Google Pixel 5a Motherboard Replacement, Remove the screen: adım 15, 2 resimden 2.
    • Use the tip of a spudger to pry up and disconnect the screen flex cable.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    This was the most tedious part for me when reassembling. I used the gold colored corners on the board to line up the connector. Also, I recommend using your finger and not the spudger for pressing down when you reattach (even if you don't have small hands); this helps you feel the slight click when it's in place.
    Additionally, you can use the suction cup as a sort of kickstand so you have enough ribbon cable to work with (because there's not a lot.)
    Lol No - Yanıt
    Just successfully completed my screen replacement & agree with the comments above. This guide would be improved if there was a close-up picture showing the gold alignment marks. Sorry, I would have posted a picture of this myself, but my phone was being operated on at the time. LoL
    CRAIG MCKAY - Yanıt
    Operation success! Had some trouble when disconnecting and removing the old screen because I didn't know how much range I had when opening it up like a book. Ended up bending the connector on the old screen and bent the connector on the motherboard a little. Be very careful when opening up the screen while the screen is still attached to the frame. Only open it up like 30 degrees at first to see what the cable is doing and how much slack you have.
    This led to me trying to straighten out the pins on the motherboard connector for like 3 painstaking hours because every time I tried to insert the new connector by clicking down on one side at a time it kept popping up on the opposite end and shifting up/down a little bit. Assumed the pins were still misaligned with the screen connector and eventually got frustrated enough to just push down the connector in the middle, which explicitly contradicts the instructions. The connector still popped off with some light pressure but I just put the bracket on & it all works!
    A Husk - Yanıt
    Reattaching the cable was definitely the hardest part. I've only done this once before but that time there was a much more tangible sensation when all was attached. No matter how carefully I lined things up inside the golden corners it just didn't seem to be clicking as expected. I finally thought I got it so I put the metal cover back and hoped for the best.
    Bonus fun - the "remove this last" plastic that covered the pre-cut adhesive came up with the blue plastic sheet, so I was working around exposed adhesive. I kept a piece of stiff plastic over that and tried not let the phone get glued back together and in the end it worked.
    I wish I'd got a 2nd sheet of adhesive in case once reassembled it turned out the little pins had not connected well enough - I didn't know if it would be ok to start it up again before actually pressing things together. Would that have messed with the calibration? Would be nice to know if I coud have tested the connection and then squeezed it all shut.
    Yes, the attaching of the cable is the hardest part. Mine never really stayed , so I did what the determined person before me did: Put the metal part on top and hope for the best.
    I used my fingers to tell if it was on top and also made sure that the square was aligned with the gold corners on the phone.
    You definitely need a second person to hold a light and the screen while you do everything. I couldn’t have finished otherwise.
    It works!!!! I’m so happy 😀 Good luck!
    First time doing this - Yanıt
    Got it connected, saw my screen for a couple of seconds clear as day, then when I went to put it back together and the screen blacked out....lightly flashing I gently brought it around the edges to snap them together and the last one by the camera had a little bit of a harder time... 😭
    Jen - Yanıt
  16. Google Pixel 5a Motherboard Replacement, Screen information: adım 16, 1 resimden 1.
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
  17. Google Pixel 5a Motherboard Replacement: adım 17, 1 resimden 1.
    • Remove the screen from the phone.
    • During reassembly:
    • If you replaced the screen, check the screen's front-facing camera hole and remove any protective liners covering it.
    • Remember to reinstall the screen connector bracket.
    • If you are using a custom-cut adhesive, follow this guide to correctly apply new screen adhesive.
    • If you are using Tesa tape to reattach the screen, follow this guide.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
    The ribbon connector is a little tricky to attach to the pcb. Just be patient with the spudger and it will connect. The precut adhesive strip is such a nice touch for finishing the project.
    I also struggled with the ribbon connector. Be patient. It is hard to see the alignment so is done by feel and some outline guides on the pcb. I plugged in the new screen, tested by powering up the phone, then unplugged the screen to install the pre-cut adhesive. There were no instructions with the pre-cut adhesive sheet. First remove EVERY trace of old adhesive. I used the spudger plus isopropyl alcohol on a lint free wipe. Once the old glue was gone, I aligned the pre-cut adhesive with the clear plastic side down, folded down about 1", confirmed my alignment, then pulled on the clear plastic and secured as I removed the clear liner. Then I removed the large blue plastic liner, then there was a very small blue pull tab that exposed the top sticky side of the adhesive. Carefully pull on that to removed. Be sure to re-install the metal latch and screw over the ribbon connector before snapping the screen back onto the phone. I forgot it and had to re-open the phone. Face-palm!
    Custom cut adhesive is great. No instructions.
    Do not reattach the ribbon cable before applying the adhesive.
    Check the alignment of the adhesive with the clear plastic down.
    Carefully remove the clear plastic. This can be done all at once or gradually starting at the bottom of the phone.
    Apply the adhesive starting at the bottom of the phone pressing the adhesive in place and rechecking alignment as you go.
    Once the adhesive is in place, press the adhesive down again.
    Remove the blue plastic using the tabs at the top and down each side.
    Reattach the display cable by pressing the connector down from one side and then the other. The alignment of the connector is difficult since it is not visible, but starting at one side makes alignment easier.
    Reinstall the connector retaining plate and screw.
    Remove lens and connector tape from the top of the new screen
    Reinstall the screen and press down firmly on all of the edges making sure there are no gaps around the bezel.
    Power on without touching the screen to calibrate.
    craig potts - Yanıt
    Precut adhesive is installed in 3 steps:
    1. Place adhesive before attaching cable. Remove clear plastic from adhesive and align with phone. Place adhesive onto phone using camera hole as starting point. Make sure blue plastic is properly aligned with edge of phone around entire perimeter
    2. Once adhesive is aligned and fully on, remove blue plastic starting from top right corner. A rectangular tab there can be lifted and used to remove blue plastic. Thin blue plastic strip will remain on adhesive after removing blue sheet. Leave it on to prevent damaging adhesive while screen is being installed
    3. Attach screen cable and retaining clip. Remove thin blue plastic strip starting from bottom. Two tabs there can be used to get started. Align and attach screen
    When attaching cable, hold screen perpendicular to phone with screen facing bottom charging port. This will give the cable more slack to work with. Two corner outlines are printed next to the plug on the phone that can be used to help with cable alignment
    barely_diy - Yanıt
    The display connector's snaps are quite weak and will come undone easily. The connector's bracket seems to be the only thing keeps it in place. Try to get the connector to snap in as best you can (as others have said it's about feel) then install the bracket to lock it down. Lastly, the ribbon cable is fragile but it can be gently bent to help with installation. I bent mine outwards around 120 degrees and had no issues.
    Mason Tate - Yanıt
    Remember after the cable retainer plate but before the screen is laid down, peel the proximity sensor protective film, and the tiny red tab on the camera peephole protective film.
    Then you can start to pull a little bit on the thin blue strip tab so it hangs out, rest the screen clips in position but do not push down.
    This will leave enough gap for you to now fully pull out the thin strip. Then click the screen down.
    I had a bit of a scare, during 1st power on test screen just showed snow, super long pressed to turn it back off but there was no feedback to tell me it had done so. Un&re-plugged screen and got a bigger scare when it wouldn't turn on. Insanely super long press and it did come on to a normal boot sequence and a beautiful screen.
    Stephen Cass - Yanıt
    The process went smoothly for me. The only thing I failed to realize is there is actually two pieces of protection over the camera hole. There was a piece of masking tape AND a clear red cover. I didn't like the idea of my phone taking red pictures so I had to disassemble and remove this red cover. The phone was far too easy to disassemble a second time which made me wonder if the adhesive I applied was doing it's job. I decided to heat the parameter with a hair dryer the second time I put the screen in.
    Joshua Morris - Yanıt
    Thank you! This is so important! You saved me a headache.
    ccc -
    Is there any reason why a screen replacement on a pixel 5a would result in lost encryption keys? Specifically, I am curious about the Titan M security chip. I know that it will not release encryption keys if it detects certain hardware modifications. Would a new screen be one of the hardware modifications flagged by the Titan M?
    Jacob - Yanıt
    Attaching the new ribbon connector was an absolute nightmare. After trying for almost an hour, I had to pay a mobile phone repairperson to fix it. Even he struggled with it and asked if I had the correct screen.
    I also want to echo what someone else said: make sure you remove the plastic with the red flap from the front facing camera lens on the new screen. There are two temp adhesives to remove for that one.
    ccc - Yanıt
    Very grateful for the comments to remove both camera lens covers before assembly! Luckily the 2nd one being red made me wonder if something was wrong, but it's really not super obvious that the red part should be removed. I had to really get down in the window hole to remove it
    There were instructions for the adhesive, they just have a separate link for that.
    So the outline is:
    1. Use the iopener to loosen the adhesive
    2. Using the given tools, pry on the right and remove the old screen with bezel
    3. Disconnect the old screen, save the screw and guard
    4. Remove the old adhesive
    5. Clean
    6. Place the custom adhesive ( line it up with the front cam), align and attach
    7. Remove the front part of the custom adhesive
    8. Connect the new screen ( remove any needless taping) and test.
    9. Put the guard and screw back
    10. Close project
    hema v - Yanıt
    I didn't spot the protector on the camera. So now I have no selfie camera. I don't even see this step in their guides. 😟
    Brit inCali - Yanıt
    All the tips here were great.
    Peeling off the old glue and cleaning was more difficult than expected. I needed to use about 7 q-tips with alcohol and scrubbing.
    No issues reconnecting the display after reading the tips here.
    One thing: when peeling off the old glue, there was a small part made of plastic that came with it. I think it is part of the phone (but maybe not?).
    Anyone know what this is: https://imgur.com/a/PxRaPwa
    repair-dude - Yanıt
    I had this problem in a different way - after attaching the new screen and trying to put it in place, i found a spot where the new screen refused to get re-seated. Thankfully, I was doing things very gingerly, so I didn't crack the screen trying to force it closed. Turned out this same piece of plastic was in the way, and it just fell out. I suspect its part of one of the screen holding clips that broke while removing the damaged screen. Once I removed it, the new screen seated itself without a problem.
    Learning - be careful while seating the new screen - if something isn't going back in, don't try to force it, just check if there is a small piece of plastic in the way.
    In general - great guide for fixing the screen.
    Only caveat - the iOpener method didn't work for me. Used a hairblower instead. One side at a time - first right side, then top, then bottom (no particular reason for order of top vs bottom), then the left side.
    Vinay Pydah -
    I changed the screen, it seems like it worked for a minute or so - as the "charging battery" icon showed up on the screen upon pressing the power button.
    The screen show the icon one more time later as I was checking the charging status - then on the 3rd time looking at the screen, it turned black and started flickering a dew patterns.
    Since then, the screen not working anymore (flicker every seconds looking like it almost start up while flashing a few random pixel at the bottom).
    I reopened and double checked but everything looks fine, I tried to disconnect and re-attach, it did not help.
    It looks like a bigger issue that a dead screen on my side. I read about a similar issue (newly changed screen died almost immediately) a while back when my daughter' Pixel 5a died as well.
    Marc - Yanıt
    I was struggling to reattach the ribbon connector, but then I used one of those magnifying lamp lights and it made it significantly easier to complete that step. It also helped with guiding the tiny screw back into the hole that attaches the bracket. If you can get access to one of those lamps, it is worth the effort. Like many other people previously mentioned, try to be patient and take your time with the repair. Lastly, I turned on the screen to test it before I reattached it and it worked fine, but then after I had put the phone completely back together, just like another person said, the screen was completely pixelated not displaying anything. I was worried that I had done something incorrectly and I was going to need to take apart the phone again, but I turned the phone off and on and it fixed the problem. Good luck everyone with fixing your phone!
    Joey Barcelona - Yanıt
  18. Google Pixel 5a Motherboard Replacement, Remove the screws: adım 18, 1 resimden 1.
    • Use a T3 Torx driver to remove six of the screws securing the midframe to the motherboard:
    • Four 4.6 mm screws
    • One 4.0 mm screw
    • One 2.0 mm screw
    • Since a few of these screws have different lengths, keep track of each screw and be sure to reinstall them in their proper places.
    One of the 4.6mm screws in this step is different. The one closest to the graphite sheet has a different color head and is smaller.
    John Peterson - Yanıt
  19. Google Pixel 5a Motherboard Replacement, Remove the black plastic cover: adım 19, 2 resimden 1. Google Pixel 5a Motherboard Replacement, Remove the black plastic cover: adım 19, 2 resimden 2.
    • Use the pointed end of a spudger to pry up on the black plastic cover at the bottom left of the phone.
  20. Google Pixel 5a Motherboard Replacement: adım 20, 2 resimden 1. Google Pixel 5a Motherboard Replacement: adım 20, 2 resimden 2.
    • Slide the pointed end of the spudger left until the plastic cover is completely separated from the midframe.
    • Remove the plastic cover from the midframe.
  21. Google Pixel 5a Motherboard Replacement: adım 21, 3 resimden 1. Google Pixel 5a Motherboard Replacement: adım 21, 3 resimden 2. Google Pixel 5a Motherboard Replacement: adım 21, 3 resimden 3.
    • Use a pair of tweezers to slightly peel back the tape concealing the two screws securing the charging port bracket.
  22. Google Pixel 5a Motherboard Replacement, Remove the remaining screws: adım 22, 1 resimden 1.
    • Use a T3 Torx driver to remove the remaining four screws securing the midframe to the motherboard:
    • Three 4.6 mm screws
    • One 4.0 mm screw
  23. Google Pixel 5a Motherboard Replacement: adım 23, 2 resimden 1. Google Pixel 5a Motherboard Replacement: adım 23, 2 resimden 2.
    • Use a spudger or a pair of tweezers to peel back the tape securing the charging port bracket to the speaker assembly.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
  24. Google Pixel 5a Motherboard Replacement: adım 24, 3 resimden 1. Google Pixel 5a Motherboard Replacement: adım 24, 3 resimden 2. Google Pixel 5a Motherboard Replacement: adım 24, 3 resimden 3.
    • Use a blunt pair of tweezers, or your fingers, to carefully peel back the graphite sheet covering the battery.
    • Be careful not to accidentally puncture or otherwise damage the battery when gripping the graphite sheet.
  25. Google Pixel 5a Motherboard Replacement, Detach the midframe: adım 25, 2 resimden 1. Google Pixel 5a Motherboard Replacement, Detach the midframe: adım 25, 2 resimden 2.
    • Insert the pointed end of a spudger under the top right corner of the midframe.
    • There is a black plastic clip at the top of the midframe that secures it to the top of the frame. To detach it, use the spudger to pull the midframe down and then pry up.
  26. Google Pixel 5a Motherboard Replacement, Remove the midframe: adım 26, 2 resimden 1. Google Pixel 5a Motherboard Replacement, Remove the midframe: adım 26, 2 resimden 2.
    • Remove the midframe.
  27. Google Pixel 5a Motherboard Replacement, Replace the plastic bits: adım 27, 3 resimden 1. Google Pixel 5a Motherboard Replacement, Replace the plastic bits: adım 27, 3 resimden 2. Google Pixel 5a Motherboard Replacement, Replace the plastic bits: adım 27, 3 resimden 3.
    • There are two small plastic bits that help hold the midframe in place. Take care not to misplace them, as without the midframe to hold them in place, they are very easy to lose.
    • Be sure to place these back into their respective corners before replacing the midframe when reassembling your device.
    Mine has neither of these pieces. They're not lost, they were just never there.
    Sean - Yanıt
  28. Google Pixel 5a Motherboard Replacement, Disconnect the battery: adım 28, 2 resimden 1. Google Pixel 5a Motherboard Replacement, Disconnect the battery: adım 28, 2 resimden 2.
    • Use the flat end of a spudger to pry up on the battery connector to disconnect it.
  29. Google Pixel 5a Motherboard Replacement, Remove the 16 MP Ultrawide camera: adım 29, 3 resimden 1. Google Pixel 5a Motherboard Replacement, Remove the 16 MP Ultrawide camera: adım 29, 3 resimden 2. Google Pixel 5a Motherboard Replacement, Remove the 16 MP Ultrawide camera: adım 29, 3 resimden 3.
    • Use the flat end of a spudger to pry up on the 16 MP Ultrawide camera's connector to disconnect it.
    • Remove the 16 MP Ultrawide camera.
  30. Google Pixel 5a Motherboard Replacement, Remove the 12.2 MP Wide-Angle camera: adım 30, 3 resimden 1. Google Pixel 5a Motherboard Replacement, Remove the 12.2 MP Wide-Angle camera: adım 30, 3 resimden 2. Google Pixel 5a Motherboard Replacement, Remove the 12.2 MP Wide-Angle camera: adım 30, 3 resimden 3.
    • Use the flat end of a spudger to pry up on the 12.2 MP Wide-Angle camera's connector to disconnect it.
    • Remove the 12.2 MP Wide-Angle camera.
  31. Google Pixel 5a Motherboard Replacement, Disconnect the headphone jack: adım 31, 2 resimden 1. Google Pixel 5a Motherboard Replacement, Disconnect the headphone jack: adım 31, 2 resimden 2.
    • Use the pointed end of a spudger to pry up on the headphone jack connector to disconnect it.
  32. Google Pixel 5a Motherboard Replacement, Remove the headphone jack: adım 32, 3 resimden 1. Google Pixel 5a Motherboard Replacement, Remove the headphone jack: adım 32, 3 resimden 2. Google Pixel 5a Motherboard Replacement, Remove the headphone jack: adım 32, 3 resimden 3.
    • Use the flat end of a spudger to pry up on the headphone to pop it out of its socket.
    • Remove the headphone jack.
  33. Google Pixel 5a Motherboard Replacement, Disconnect the fingerprint sensor cable: adım 33, 2 resimden 1. Google Pixel 5a Motherboard Replacement, Disconnect the fingerprint sensor cable: adım 33, 2 resimden 2.
    • Use the flat end of a spudger to pry up on the fingerprint sensor connector to disconnect it.
  34. Google Pixel 5a Motherboard Replacement, Disconnect the camera flash cable: adım 34, 2 resimden 1. Google Pixel 5a Motherboard Replacement, Disconnect the camera flash cable: adım 34, 2 resimden 2.
    • Use the flat end of a spudger to pry up on the camera flash connector to disconnect it.
  35. Google Pixel 5a Motherboard Replacement, Remove the motherboard screws: adım 35, 1 resimden 1.
    • Use a T3 Torx driver to remove the three 2.9 mm screws securing the motherboard to the frame.
  36. Google Pixel 5a Motherboard Replacement: adım 36, 2 resimden 1. Google Pixel 5a Motherboard Replacement: adım 36, 2 resimden 2.
    • Insert the flat end of a spudger under the top right corner of the motherboard to lift it from the frame.
    • The SIM card tray also secures the motherboard to the frame, so double-check that it has been removed before this step.
  37. Google Pixel 5a Motherboard Replacement: adım 37, 2 resimden 1. Google Pixel 5a Motherboard Replacement: adım 37, 2 resimden 2.
    • Insert the flat end of a spudger under the top left corner of the motherboard to lift it from the frame.
  38. Google Pixel 5a Motherboard Replacement: adım 38, 2 resimden 1. Google Pixel 5a Motherboard Replacement: adım 38, 2 resimden 2.
    • Insert the pointed end of a spudger under the the screw slot to the top right of the speaker assembly to dislodge it from the frame.
    • Be careful not to deform the battery when prying at the speaker assembly.
  39. Google Pixel 5a Motherboard Replacement, Remove the motherboard: adım 39, 1 resimden 1.
    • Remove the motherboard and speaker assembly.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 5a Answers community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
6 farklı kişi bu kılavuzu tamamladı.
Clay Kim
11.230 İtibar
21 adet Kılavuz yazıldı
3Kılavuz Yorumları
Is the storage part of the mother board? Just wondering if I make this repair, if I will lose all my data.
Seth Cardoza - Yanıt
yes, the storage is part of the SoC so you probably couldnt replace it without putting the SoC on the new motherboard (its probably soldered and cant be easily removed)
goofy goober -
In step 24 it's better to pry midframe from the bottom so don't break the tab at the top. Similarly, when assembling, slide the top first and then align the bottom.
darth0s - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 38
Son 30 gün: 212
Her zaman: 12,907
