Ana içeriğe geç
Google Pixel 6 Fingerprint Reader Replacement
Dominik Schnabelrauch
Dominik Schnabelrauch ve 8 diğer katkıda bulunanlar
En son July 18, 2024 tarihinde güncellendi
25 - 40 dakika
Orta
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace the fingerprint reader in your Google Pixel 6.
If you replace the fingerprint reader in the Pixel 6 or switch it between two different displays, you need to recalibrate it to maintain its functionality.
Warning: The replacement of the fingerprint reader in the Google Pixel 6 is not complicated, but the screen can get damaged very easily during the removal procedure.
Caution: The Pixel 6 contains class 1 lasers. Disassembly could result in exposure to invisible infrared laser emissions.
Retaining water resistance after the repair will depend on how well you reapply the adhesive, but your device will lose its IP (Ingress Protection) rating.
You’ll need replacement adhesive to reattach components when reassembling the device.
Note: Replacement fingerprint sensors are not available for sale on iFixit or from Google.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. Google Pixel 6 Fingerprint Reader Replacement, Safety precautions: adım 1, 2 resimden 1. Google Pixel 6 Fingerprint Reader Replacement, Safety precautions: adım 1, 2 resimden 2.
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
    If I cannot use my screen, how do I power it off?
    Craig Joseph Van Vliet - Yanıt
    I was thinking the same. Could let the battery run down.
    Jack Adrian Zappa - Yanıt
    You can turn the Smartphone off via the boot menue. Push the on/off-button plus the volume up button at the same time. Once the smartphones goes off to restart, hold the volume down button. The smartphone will boot and you can select between recovery mode and other options. You will find the option turn off, which you can select then with the buttons on the side.
    Jonas R. - Yanıt
    This is only helpful if you can read your screen. I have a black screen and over 60% battery. It will take days to drain the battery. I need to power it off.
    William Maine -
  2. Google Pixel 6 Fingerprint Reader Replacement, Anti-Clamp instructions: adım 2, 3 resimden 1. Google Pixel 6 Fingerprint Reader Replacement, Anti-Clamp instructions: adım 2, 3 resimden 2. Google Pixel 6 Fingerprint Reader Replacement, Anti-Clamp instructions: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your phone.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. Google Pixel 6 Fingerprint Reader Replacement: adım 3, 3 resimden 1. Google Pixel 6 Fingerprint Reader Replacement: adım 3, 3 resimden 2. Google Pixel 6 Fingerprint Reader Replacement: adım 3, 3 resimden 3.
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  4. Google Pixel 6 Fingerprint Reader Replacement: adım 4, 3 resimden 1. Google Pixel 6 Fingerprint Reader Replacement: adım 4, 3 resimden 2. Google Pixel 6 Fingerprint Reader Replacement: adım 4, 3 resimden 3.
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the phone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  5. Google Pixel 6 Fingerprint Reader Replacement, Loosen the display adhesive: adım 5, 1 resimden 1.
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least three minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    what area of the phone do i apply it to?
    middle, edges, diagonal?
    johnathandoe - Yanıt
    Only on the edges.
    bogdan dobrin -
  6. Google Pixel 6 Fingerprint Reader Replacement, Insert an opening pick: adım 6, 3 resimden 1. Google Pixel 6 Fingerprint Reader Replacement, Insert an opening pick: adım 6, 3 resimden 2. Google Pixel 6 Fingerprint Reader Replacement, Insert an opening pick: adım 6, 3 resimden 3.
    • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction handle to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction handle to the screen.
    • Lift the screen, including its safety frame, with the suction handle to create a small gap between the screen and the phone assembly.
    • Insert an opening pick into the gap between the screen frame and the phone assembly.
    • Make sure to insert your opening pick in the right position to avoid separating the screen from its safety frame instead of the phone assembly.
    • Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  7. Google Pixel 6 Fingerprint Reader Replacement, Slice the adhesive: adım 7, 2 resimden 1. Google Pixel 6 Fingerprint Reader Replacement, Slice the adhesive: adım 7, 2 resimden 2.
    • Insert a second opening pick at the bottom edge and slide it to the bottom left corner of the screen to slice the adhesive.
  8. Google Pixel 6 Fingerprint Reader Replacement: adım 8, 3 resimden 1. Google Pixel 6 Fingerprint Reader Replacement: adım 8, 3 resimden 2. Google Pixel 6 Fingerprint Reader Replacement: adım 8, 3 resimden 3.
    • The screen of the Google Pixel 6 is not only held in place by adhesive but also small plastic clips. If your opening pick gets blocked during the screen removal procedure, it means you inserted your pick too deep underneath the screen. Only insert the tip of the opening pick (3-4 mm) when slicing the display adhesive.
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  9. Google Pixel 6 Fingerprint Reader Replacement: adım 9, 3 resimden 1. Google Pixel 6 Fingerprint Reader Replacement: adım 9, 3 resimden 2. Google Pixel 6 Fingerprint Reader Replacement: adım 9, 3 resimden 3.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • When you slice near the front facing camera, insert only the tip of the opening pick (2-3 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  10. Google Pixel 6 Fingerprint Reader Replacement: adım 10, 2 resimden 1. Google Pixel 6 Fingerprint Reader Replacement: adım 10, 2 resimden 2.
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
    • Do not try to remove the display all the way yet, the screen is still connected to the phone assembly.
  11. Google Pixel 6 Fingerprint Reader Replacement, Open up the phone assembly: adım 11, 3 resimden 1. Google Pixel 6 Fingerprint Reader Replacement, Open up the phone assembly: adım 11, 3 resimden 2. Google Pixel 6 Fingerprint Reader Replacement, Open up the phone assembly: adım 11, 3 resimden 3.
    • Avoid straining the display cable during the following procedure.
    • Carefully open the right side of the screen to the left side of the phone assembly like you would open a book.
  12. Google Pixel 6 Fingerprint Reader Replacement, Remove the display cable bracket: adım 12, 3 resimden 1. Google Pixel 6 Fingerprint Reader Replacement, Remove the display cable bracket: adım 12, 3 resimden 2. Google Pixel 6 Fingerprint Reader Replacement, Remove the display cable bracket: adım 12, 3 resimden 3.
    • Use a pair of tweezers to carefully unhinge and remove the metal bracket sitting on top of the display cable connector.
    • Make sure to keep this component to reinstall it during reassembly.
    Don't be afraid to bend that clip. I had to bend mine to around 90 degrees.
    Thank you very much for the information
    Carlos López (España - Spain) -
    Don't forget to put the bracket back on during reassembly!
    I only realised I had forgotten to reattach it when I was putting the tools away and saw the bracket on the desk... both halves are already glued together so far too late for me. Let's hope it doesn't come loose or I'll be meticulously scraping off all that glue again lol
    Sam Hobbs - Yanıt
    The absolute same thing happened to me...! I just saw it laying around on the table after cleaning up... Did you experience any issues so far? Not keen on opening it up again eager haha.
    Milkiman -
    Any chance someone has an update on how bad it is to just go on and use the phone without that bracket?
    Leilin -
    My bracket was a little bit stuck. I bent the tab on the left side to 90 degrees, as Jack mentioned. Then I folded the bracket with my finger to the right side and then upwards. When reinstalling, you can bend the bent tab back to its original position.
    Alessio - Yanıt
  13. Google Pixel 6 Fingerprint Reader Replacement, Disconnect the display cable: adım 13, 2 resimden 1. Google Pixel 6 Fingerprint Reader Replacement, Disconnect the display cable: adım 13, 2 resimden 2.
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
  14. Google Pixel 6 Fingerprint Reader Replacement, Remove the screen: adım 14, 1 resimden 1.
    • Remove the screen.
    • During reassembly:
    • If you replaced the screen, check the front-facing camera hole on the screen and remove any remaining protective liners in it.
    • Remember to reinstall the display cable bracket.
    • This is a good point to test your phone before sealing it up. Temporarily connect your screen, power on your phone, and make sure it works as expected. Before continuing with reassembly, power off your phone and disconnect the screen.
    • Follow this guide if you're using custom-cut adhesives for your device.
    • Follow this guide if you're using a pre-cut adhesive card.
    • If you're installing a new screen, follow this guide to calibrate the fingerprint sensor.
    Has the issue with the fingerprint not working after screen replacement been sorted?
    [deleted] - Yanıt
    I bought the repair kit that included the adhesive & fingerprint module. If that's what you bought as well, you will have to use the google repair tool. https://pixelrepair.withgoogle.com/udfps. I had to manually download the google usb drivers & install them on Windows 11 because the phone wasn't being detected by the pixel repair tool.
    Kwame Bailey -
    Hello, fingerprint does'nt work now.... any tips ? thank !
    willy kedziora - Yanıt
    I had the screen on my 6A replaced at a U-BreakiFix got home fingerprint reader does not work. It says enrollment not complete. Go to your repair facility. I guess they must have some magic that makes it work again due to security issues
    Lynne Ayers - Yanıt
    Great directions, would be helpful to have a section on Google Pixel 6 Display Adhesive - Genuine
    Troy O'Connor - Yanıt
    This guide is clear and easy to follow. The other one where you actually replace the screen and put the new adhesive is much less easy to follow, and takes much more time to complete because you have to remove all traces of the old adhesive. I used GooGone and a 2mm flat head screwdriver as a scraping tool and it worked well.
    The fingerprint reader was not working after the upgrade, but I got it to work by visiting https://pixelrepair.withgoogle.com/udfps and since I'm using Ubuntu, I had to run those two commands:
    sudo usermod -aG plugdev $LOGNAME
    sudo apt-get install android-sdk-platform-tools-common
    And then reboot my computer before my phone could be connected. I rebooted my phone manually after the upgrade and all was working normally. In fact, the new fingerprint sensor works better than the one I got before. The new one is actually usable.
    My Pixel 6 is like new! (except perhaps for the water resistance)
    Francois Lord - Yanıt
    Great tips! I wish I had thought of Goo Gone. By far the longest part of the procedure was cleaning out the old adhesive, and using alcohol swabs (including a few spares on hand) was slow and not very effective.
    After Chrome on ubuntu was unhappy with recognizing my phone I had to resort to using a Mac, but I would prefer your solution.
    Gary Smith -
    Alternate solution, without installing anything:
    Determine the USB bus and device ID of your phone.
    lsusb
    Assuming, the bus ID is '004', and the device ID is '001', temporary allow access to this USB device for all users.
    chmod 0777 /dev/bus/usb/004/001
    Thomas -
    Easy enough and excellent guide! Thank you!
    Jason - Yanıt
    The guide was very helpful, but could be improved somewhat. I made the mistake of removing the screen without the bracket & didn't realize until I had attached the adhesive & tried to put the new screen on. So I had to remove the adhesive & the bracket before the new screen would fit, since it has it's own bracket. Another tip would be to include the instructions for getting the fingerprint module to work. Including https://pixelrepair.withgoogle.com/udfps & downloading & installing the google usb driver.
    Kwame Bailey - Yanıt
    I agree that the guide was good. To be more clear, after the screen is completly installed you have go here https://pixelrepair.withgoogle.com/udfps to fix your fingerprint sensor, but my phone was not recognized by the utility when you plug it in Fast Boot Mode. This requires the usb drivers to be installed on the computer. Go here to download the usb https://developer.android.com/studio/run... Once you have the drivers you will have to go to device manager and you will see your Pixel 6 with a exclamation point on it. Right click on the Pixel 6 and select update drivers. Now browse to the folder that you extracted your drivers to that you just downloaded. This will fix the pixel 6 to be recognized by the utility. Now run the utiltity, and just make sure you reboot your phone when the utiltiy is done and it should be fixed.
    Wedge Fike - Yanıt
    Just finished a screen replacement on my pixel 6. Everything was pretty straight forward and the instructions and guide was really clear. Scraping all the old tape/glue and making sure I get every last piece out of the phone was the most time consuming part, but totally doable in the end. Using something like goo gone or lighter fluid helps greatly in dissolving the tape residue and the include plastic scraper tool helped scraping every single last piece of goop off the phone.
    Had a little scare with the fingerprint scanner not working even after following the guide and calibrating the fingerprint scanner through google's website. I did it on a win11 computer at first, but thought I would use another computer with win10 to see if that made any difference. Fortunately that worked and my phone is back to 100% working again.
    Lawrence Chan - Yanıt
    Thank you very much, worked as expected! Had also to recalibrate fingerprint censor AND then reboot the phone manually.
    For Ubuntu, you have to add some udev rules or use some other trick to make Chrome/Chromium access your USB devices.
    Alexis Le - Yanıt
    Never explains how to snap the bracket of the new phone screen onto the device. Incomplete.
    Orlowski Sal - Yanıt
  15. Google Pixel 6 Fingerprint Reader Replacement, Open the ZIF connector: adım 15, 2 resimden 1. Google Pixel 6 Fingerprint Reader Replacement, Open the ZIF connector: adım 15, 2 resimden 2.
    • If you replace the fingerprint reader in the Pixel 6 or switch it between two different displays you need recalibrate it to maintain its functionality.
    • Use one arm of a pair of tweezers to carefully open the ZIF connector at the rear side of the screen.
  16. Google Pixel 6 Fingerprint Reader Replacement, Disconnect the fingerprint reader: adım 16, 2 resimden 1. Google Pixel 6 Fingerprint Reader Replacement, Disconnect the fingerprint reader: adım 16, 2 resimden 2.
    • Use a pair of tweezers to disconnect the fingerprint reader by pulling its cable out of the ZIF connector.
  17. Google Pixel 6 Fingerprint Reader Replacement, Loosen the fingerprint reader adhesive: adım 17, 1 resimden 1.
    • Apply a heated iOpener to the screen where the fingerprint reader is located to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
  18. Google Pixel 6 Fingerprint Reader Replacement, Separate the fingerprint reader from the screen: adım 18, 3 resimden 1. Google Pixel 6 Fingerprint Reader Replacement, Separate the fingerprint reader from the screen: adım 18, 3 resimden 2. Google Pixel 6 Fingerprint Reader Replacement, Separate the fingerprint reader from the screen: adım 18, 3 resimden 3.
    • Carefully slide an opening pick underneath the fingerprint reader cable to slice its adhesive.
    • Be very gentle during this procedure. Too much force might damage the display. If the adhesive is hard to cut, reapply your iOpener for another minute to loosen it.
    • Be careful not to overheat the screen—the display is susceptible to heat damage.
    • Use your opening pick to separate the fingerprint reader from the screen.
  19. Google Pixel 6 Fingerprint Reader Replacement, Remove the fingerprint reader: adım 19, 2 resimden 1. Google Pixel 6 Fingerprint Reader Replacement, Remove the fingerprint reader: adım 19, 2 resimden 2.
    • Use a pair of tweezers or your fingers to carefully remove the fingerprint reader.
    • Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Sonuç
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
11 farklı kişi bu kılavuzu tamamladı.
231.870 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.806 adet Kılavuz yazıldı
5Kılavuz Yorumları
Will you ever sell a fingerprint replacement part?
bara soleiman - Yanıt
Great guide! Using very little alcohol after heating the display can help loosen up the adhesive holding the fingerprint scanner.
Aashish Shrestha - Yanıt
I am looking at this gide right now because I would like to know how to calibrate my fingerprint after I swap one of your screen on my phone
DWIGHT PR - Yanıt
This is incomplete. It STOPS 1/2 THROUGH!!!!!
This guide stops at removal of the original part. NO WHERE DOES IT GET TO REASSEMBLY or CALIBRATION!!!
John Kłaczyński - Yanıt
Reassembly is literally all the steps but backwards and the calibration program is listed at the top of the article.
RX149 Dragoon -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 72
Son 30 gün: 331
Her zaman: 12,695
