Ana içeriğe geç
Google Pixel 7 Screen Replacement
Dominik Schnabelrauch
Dominik Schnabelrauch ve 5 diğer katkıda bulunanlar
En son March 26, 2025 tarihinde güncellendi
30 - 45 dakika
Orta
Öne Çıkan Kılavuzlar
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace the screen for your Google Pixel 7.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Caution: The Pixel 7 contains class 1 lasers. Disassembly could result in exposure to invisible infrared laser emissions.
Your new replacement screen should come with the fingerprint reader already attached. If not, you will need to reinstall the original fingerprint reader to your new replacement screen and recalibrate the reader to maintain its functionality.
Retaining water resistance after the repair will depend on how well you reapply the adhesive, but your device will lose its IP (Ingress Protection) rating.
You'll need replacement adhesive in order to complete this repair.
Neye ihtiyacın var
Tamir Seti
Bu kit, bu kılavuzu tamamlamak için gereken tüm parçaları ve araçları içerir.
Parçalar
Aletler
Daha fazlasını göster…
  1. Google Pixel 7 Screen Replacement, Safety precautions: adım 1, 2 resimden 1. Google Pixel 7 Screen Replacement, Safety precautions: adım 1, 2 resimden 2.
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
    i replaced my pixel 7 screen, I noticed that my proximity sensor is no longer working, I have tried to calibrate it using 3rd part apps and it ddisnt work,i tried using developer settings to switch the proximity sensor and i also updated my android version...all these didnt work
    Ian - Yanıt
    If you can't power down your device because the screen is cracked (in my case, the AMOLED didn't light up at all anymore) and the touch is broken, you can also press power, volume up, and volume down all at the same time for 20-30 seconds. This will actually power off the phone, and not restart it (for that, you would hold the power button and volume up for a while).
    Max - Yanıt
  2. Google Pixel 7 Screen Replacement, Screen removal information: adım 2, 3 resimden 1. Google Pixel 7 Screen Replacement, Screen removal information: adım 2, 3 resimden 2. Google Pixel 7 Screen Replacement, Screen removal information: adım 2, 3 resimden 3.
    • The screen of the Google Pixel 7 is held in place by a safety frame of plastic clips and adhesive.
    • During the removal procedure, make sure to insert your opening picks under the safety frame to avoid separating it from the screen.
    • Only insert the pick up to ~3.5 mm during the removal procedure to avoid damaging the internals and to avoid interfering with the plastic clips.
    • There are several plastic clips around the whole screen. In case your opening pick gets blocked during the screen removal procedure it means you inserted your pick too deep underneath the screen.
    I accidentally removed the screen from the safety frame. Thankfully, this wasn't a big issue since my screen was broken anyway. In that case, you can still easily pop up the frame, and carefully remove the remaining glue with some pliers afterward.
    Max - Yanıt
    "During the removal procedure, make sure to insert your opening picks in the right position"
    But then don't share what that position is, or even how to start.
    Great way to start the guide. Fills me with so much confidence in doing a $150 repair.
    Off tonyoutube to find someone who did q better job at a guide.
    HA Halleman - Yanıt
    Hi there! I apologize that the instructions were not clear. I have updated the guide to clarify where the right place to insert the opening picks.
    Alex Diaz-Kokaisl -
  3. Google Pixel 7 Screen Replacement, Anti-Clamp instructions: adım 3, 3 resimden 1. Google Pixel 7 Screen Replacement, Anti-Clamp instructions: adım 3, 3 resimden 2. Google Pixel 7 Screen Replacement, Anti-Clamp instructions: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your phone.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. Google Pixel 7 Screen Replacement: adım 4, 3 resimden 1. Google Pixel 7 Screen Replacement: adım 4, 3 resimden 2. Google Pixel 7 Screen Replacement: adım 4, 3 resimden 3.
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. Google Pixel 7 Screen Replacement: adım 5, 3 resimden 1. Google Pixel 7 Screen Replacement: adım 5, 3 resimden 2. Google Pixel 7 Screen Replacement: adım 5, 3 resimden 3.
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the phone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  6. Google Pixel 7 Screen Replacement, Loosen the display adhesive: adım 6, 1 resimden 1.
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device. The edge should feel slightly too hot to the touch.
    This guide is a bit all over the place. Most of the previous pictures show the iOpener being placed on the left side first (with the device having the camera facing upwards)
    However this pictures shows placing the iOpener on the right side. Does it matter? Is there a best practice side to pry first?
    Zachary (Zach) - Yanıt
    I left my iOpener on the phone for a out 5 or more minutes, but the bag should have been hotter I think (I put it in the microwave about 35 seconds, 30 is recommended starting amount). I highly suggest making sure the phone is well heated before taking the screen off because I think that is the only way to make the adhesive easier to get off. I spent probably 30-45 minutes just scraping off adhesive with the tweezers.
    Samuel Y - Yanıt
  7. Google Pixel 7 Screen Replacement, Insert an opening pick: adım 7, 3 resimden 1. Google Pixel 7 Screen Replacement, Insert an opening pick: adım 7, 3 resimden 2. Google Pixel 7 Screen Replacement, Insert an opening pick: adım 7, 3 resimden 3.
    • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Lift the screen including its safety frame with the suction handle to create a small gap between the screen and the phone assembly.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the bottom edge and try again.
    • Insert an opening pick into the gap.
    If you're having trouble getting the first pick in, try a different hand position than what is shown. Grip the suction cup's handle with your index finger, and keep your thumb and middle finger on either side of the screen. Choose a forgiving surface underneath in case you slip. Then hold firmly and keep it stable (no need to really push down). Just be prying it open deliberately and evenly. Then take your pick and use gentle prodding, experimenting with your angle and pressure, feel around. That should be all you need to get in.
    Orin Zebest - Yanıt
  8. Google Pixel 7 Screen Replacement, Prevent damage to your phone: adım 8, 2 resimden 1. Google Pixel 7 Screen Replacement, Prevent damage to your phone: adım 8, 2 resimden 2.
    • To avoid damaging your phone, don't insert your pick more than ~2.5 mm as you separate the screen adhesive. Note the following areas:
    • The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
    • There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
  9. Google Pixel 7 Screen Replacement, Slice the bottom edge adhesive: adım 9, 2 resimden 1. Google Pixel 7 Screen Replacement, Slice the bottom edge adhesive: adım 9, 2 resimden 2.
    • Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  10. Google Pixel 7 Screen Replacement: adım 10, 2 resimden 1. Google Pixel 7 Screen Replacement: adım 10, 2 resimden 2.
    • Insert a second opening pick at the bottom edge and slide it to the bottom left corner of the screen to slice the adhesive.
  11. Google Pixel 7 Screen Replacement, Release the left clips: adım 11, 3 resimden 1. Google Pixel 7 Screen Replacement, Release the left clips: adım 11, 3 resimden 2. Google Pixel 7 Screen Replacement, Release the left clips: adım 11, 3 resimden 3.
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive and to release the plastic clips.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  12. Google Pixel 7 Screen Replacement, Slice the top edge adhesive: adım 12, 3 resimden 1. Google Pixel 7 Screen Replacement, Slice the top edge adhesive: adım 12, 3 resimden 2. Google Pixel 7 Screen Replacement, Slice the top edge adhesive: adım 12, 3 resimden 3.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • When you slice near the front facing camera, insert only the tip of the opening pick (~2.5 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    This is the only slice that makes me nervous. Never had a problem, but yeah... extra care because of the camera.
    Orin Zebest - Yanıt
  13. Google Pixel 7 Screen Replacement, Release the right clips: adım 13, 3 resimden 1. Google Pixel 7 Screen Replacement, Release the right clips: adım 13, 3 resimden 2. Google Pixel 7 Screen Replacement, Release the right clips: adım 13, 3 resimden 3.
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive and release the right plastic clips.
    • Do not try to remove the display all the way yet, the screen is still connected to the phone assembly by a flex cable.
  14. Google Pixel 7 Screen Replacement, Open up the phone assembly: adım 14, 3 resimden 1. Google Pixel 7 Screen Replacement, Open up the phone assembly: adım 14, 3 resimden 2. Google Pixel 7 Screen Replacement, Open up the phone assembly: adım 14, 3 resimden 3.
    • Lift the right edge of the screen up and towards the left side of the device, like opening a book.
    • Don't twist the screen or move it too far away from the frame to avoid straining or damaging the flex cable.
    • Rest the screen upside down and parallel to the frame before continuing.
    The adhesive still sticking to the screen might trip you up... don't let it pull the screen in weird ways. Just pick that stuff off and the screen sits perfectly next to the phone, as pictured.
    Orin Zebest - Yanıt
  15. Google Pixel 7 Screen Replacement, Release the display cable bracket: adım 15, 2 resimden 1. Google Pixel 7 Screen Replacement, Release the display cable bracket: adım 15, 2 resimden 2.
    • The display cable bracket sits tightly and requires some force to release it.
    • Insert one arm of a pair of tweezers into the opening at the upper end of the display cable bracket.
    • Push the bracket inwards and pry up to release it.
    The way this piece is wedged in there can be a difficult to imagine, so you may need to apply force at a different angle than you expect. I bent mine a few times, but just bent it back into shape with no issue.
    Orin Zebest - Yanıt
    This was a pain to get out! Felt like I was going to rip the whole cable out. But it popped out eventually.
    Alex Thengvall - Yanıt
  16. Google Pixel 7 Screen Replacement, Remove the display cable bracket: adım 16, 2 resimden 1. Google Pixel 7 Screen Replacement, Remove the display cable bracket: adım 16, 2 resimden 2.
    • Use a pair of tweezers to remove the display cable bracket by pulling it from underneath the midframe and in direction of the cameras.
    I forgot to replace this the first time. It's not a dealbreaker (phone works fine without it), but if you ever open your phone again you must be super-extra careful -- nothing is securing the connection.
    Orin Zebest - Yanıt
    I bent the top of the bracket backwards by accident, but it released easier this way. Then I just bent the bracket back before putting it back.
    Also, make sure you add the adhesive before plugging the new screen in.
    Samuel Y - Yanıt
  17. Google Pixel 7 Screen Replacement, Disconnect the display cable: adım 17, 2 resimden 1. Google Pixel 7 Screen Replacement, Disconnect the display cable: adım 17, 2 resimden 2.
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Getting the press connector aligned properly is a very fiddly task and impossible without a light touch and several tries. My only advice is to take a break if you get frustrated. There's no 'click' or anything to help you notice that you've got it right. But when you do, it'll just... fit. And you'll probably think, "wait I did it? oh, not as hard as it sounded. just took awhile."
    Orin Zebest - Yanıt
    Beware! I tried using the forceps instead of my finger and I ended up tearing into the ribbon cable. So be careful and use your finger if possible. I wouldn't use a sharp tool like I did. There are a couple Youtube videos that probably can help if you search "pixel 7 screen replacement". Sadly I didn't do that first.
    Alex Thengvall -
    Be careful not to hit any circuitry or jumpers in the process. They are so tiny that I did and now sound doesn't work on my bottom speaker. There's a YouTube video on this topic. Take your time!
    Louie Popov - Yanıt
  18. Google Pixel 7 Screen Replacement, Screen information: adım 18, 1 resimden 1.
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
  19. Google Pixel 7 Screen Replacement, Separate the screen from the phone assembly: adım 19, 3 resimden 1. Google Pixel 7 Screen Replacement, Separate the screen from the phone assembly: adım 19, 3 resimden 2. Google Pixel 7 Screen Replacement, Separate the screen from the phone assembly: adım 19, 3 resimden 3.
    • Remove the screen.
    • During reassembly:
    • If you replaced your screen, check the front-facing camera hole and the sensor cutout on your replacement screen, and remove any remaining liners.
    • Check the frame for deformed grounding springs that stick straight up. These spring contacts should rise at a shallow angle. Use your finger to gently bend any deformed springs downward.
    • Remember to reinstall the display cable bracket.
    • This is a good point to test your phone before sealing it up. Temporarily connect your screen, power on your phone, and make sure it works as expected. Before continuing with reassembly, power off your phone and disconnect the screen.
    • Follow this guide if you're using custom-cut adhesives for your device. Otherwise, follow this guide in case you're using a pre-cut adhesive card.
    • If you're installing a new screen, follow this guide to calibrate the fingerprint sensor.
    It was much easier to remove the adhesive after the phone cooled down completely.
    Lacey E - Yanıt
    That's super strange. There's certainly a middle ground of not being too hot, but I've done this job 3 times now, I can really tell if it needs a little more warmth.
    Orin Zebest -
    IMO this really needs some kind of jig to align the new adhesive. It is nigh on impossible IMO to align properly, and you'll end up with bunched-up sections of stretched adhesive all over the place. It is beyond frustrating, after taking ones time and being so careful.
    It seems that it should be possible to cut the plastic backing that the new adhesive comes on into a shape that would fit in the phone, and index it on some of the existing pins by making accurate holes. That might at least make it possible to get all of the new adhesive in a useful place.
    Otherwise pretty good. Thank you to the people who have taken the time to put this together.
    David B - Yanıt
    How to unlock the fingerprint sensor ?
    Why is there no adhesive with the display.
    It's not very consumer friendly if you need to buy everything seperate
    paul E - Yanıt
    Was there a solution to unlocking the fingerprint sensor? I have the same issue.
    Marian -
    Before putting the new screen, remove the black and not so visible black plastic frame under the surrounding scotch. Otherwise you cannot put the new screen, this black and surrounding plastic is also on the new screen with it's claws.
    Ratinox - Yanıt
    I would have liked to know I had to put the adhesive card before connecting the new screen (which took me 15mn just to connect the wire to the motherboard) because the flat cable makes it very hard to do so...
    Otherwise, tutorial is good, although it misses the fingerprint sensor recalibration as said in other comments
    Gael Rottier - Yanıt
    I agree, i wish there was an adhesive tutorial, I messed mine up and lost half the adhesive :(
    William Best -
    When testing the new screen, it DID work previously. Now it does not. What could be wrong? Did I break a pin? How can I troubleshoot further?
    David Gannaway - Yanıt
    That display cable was tricky wish I had a guide I found a dependable way in the end by moving the screen to the right of the port. but wow that was frustrating. Also wish I had realized I didn't remove the digitizer and only removed the adhesive before wasting the only adhesive I ordered for the new screen.
    Simon B - Yanıt
Sonuç
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 7 answers community for help.
88 farklı kişi bu kılavuzu tamamladı.
231.783 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.797 adet Kılavuz yazıldı
47Kılavuz Yorumları
This guide was excellent. And the most tedious bit of the repair was removing the remaining adhesive before installing the new screen. Very easy repair for anyone with some patience.
If the fingerprint unlock does not work after this, you may get a message on the lock screen indicating that you need to go to a google website to fix it.
What you actually need to do is:
o Install the Google USB driver for Windows from here: https://developer.android.com/studio/run...
o Put your phone in fast-boot (turn off, then turn on while holding volume down)
o Connect the Pixel to your PC
o Using chrome, visit this site, which will reset the fingerprint reader: https://pixelrepair.withgoogle.com/udfps
I had to reboot twice after this to actually get it to work, but it's all good now.
bradappel - Yanıt
Thank you for this. Since the message on the phone is unhelpfull, this info should really be added to the manual.
Vincent van Leijden -
Thank you! No driver needed on a Mac (as it says at the first link.) Just go to the withgoogle pixelrepair page and follow the instructions. Worked on the first restart for me.
Chris K. -
Ohhh thank you so much for this, I was about to give up on the fingerprint reader ha
Joshua Chandler -
The above instructions are not complete. These are the full instructions that work for me:
1.Before you turn your phone off, go to the developer options and enable USB debugging.
Go to: Settings, About phone then tap Build number 7 times.
2. Go here Get the Google USB Driver | Android Developers and download the google USB zip file (this is for windows BTW)
3. Unzip however you want it
4. Open the folder usb_Driver and rightclick "android_winusb" and install
5. To make sure it installed, connect your pixel (with USB debugging still enabled) to your PC and open "device manager". You should see "Android Devices > Android Composite ADB Interface".
6. Disconnect pixel from PC
7. Go here Google Fingerprint Calibration website and follow the instructions.
Filip Lou - Yanıt
Thank you so much. This has worked for me :)
Robot Dog -
Thank you for the extra help. Bradapple pointed me in the right direction and you guided me in for the landing... so to speak. 😏
Already Sanchez -
I did all that but when connecting my computer the monitor shows "Unsupported device
To use this tool, your device must be a Pixel 3, 3 XL, 3a, 3a XL, 4, 4 XL, 4a, 4a (5G), 5, 5a, 6, 6 Pro, 6a, 7, 7 Pro, 7a, Tablet." That is very confusing because I have the Google Pixel 7.
Cedric Willi -
OMG thank you so much for this information, i've spent such a long time on various forums and threads, i even talked to google support they said factory reset would work.. no one mentioned the developer options and enabling USB debugging. Thanks again this finally worked!
Mitchell Rogers -
thanks so much. I think these steps should have been included in the guide. it doesn't seem like the system lets you do a straight swap without it (which makes sense given it is an important security feature)
Jesse Kohn -
Can I use a used screen and still have fingerprint scanning work or can it only be calibrated once?
Joseph Miller -
I found attaching the press cable the most difficult, it eventually went in after a few hours trying on and off, but I couldn't tell you why. Once that was done everything was easy
Sam Rutland - Yanıt
Yes i agree, this was fiddly and I was very worried about breaking pins.. though for me it was 10mins, not hours :(
Jesse Kohn -
I actually cut the old one off the damaged screen to see how it fits mechanically (i.e. does is 'click' inot position or is the connection only secured when the retainer clip is reinserted. It turns out that a little 'click' inot position is needed. David G
David Griffiths -
Really good guide. Had some trouble with the removal of the display cable branket and the adhesive, but after an hour in the end, the screen turnee on. Also had to reinstall the fingerscanner….
Steffan Juel Højgaard Jensen - Yanıt
guys my screen turn on but the touchscreen doesnt work, can anyone tell what do wrong?
ewdor gutierrez - Yanıt
I have the same problem, did you solve it somehow?
Борис Міндер -
How to order the parts if im outside of shipping region, im in indonesia
Kristian Harjanto Abarja - Yanıt
Great quality kit. I underestimated how fiddly cleaning off the old adhesive would be but otherwise this was straightforward and there were some really good pointers for things to watch out along the way. Glad I took the time to do this as now my screen is perfectly readable again. A couple of lessons learnt from me: 1/ impressed at how quickly the microwave heat pack gets super hot. one application was enough for me to get the screen off. 2/ The clips along the outside edges are very fragile.. be very careful when cleaning out the adhesive. 3/ Speaking of adhesive cleaning/removal.. I understimated this step. It took a looong time. Take breaks if getting tired/frustrated. Probably spent over an hour just on this step. Maybe more heat would have helped, but I was worried about damaging components 3/ As others have mentioned there are issues with the fingerprint sensor post install, the instructions above worked perfectly for me re/ windows driver, developer mode, google software update tool.
Jesse Kohn - Yanıt
I followed this guide to open the phone and try to fix my broken glass: not screen, glass only. I decided to post here some advices.
Resources:
- This guide
- Video on how to open and apply OCA Glass
- Video on how to apply OCA without machines
Where I bought things and what I used?
- IFixIt Pro Tech Toolkit
- Glass replacement with OCA
- Molybdenum string
- Isopropyl alcohol
- Heat Gun / Hairdryer
Advices:
- you need to have something that will hold your screen still. It will move a lot, adhesive is strong as hell
- do not apply too much heat: if it's hot to touch, probably is too much (max 80°C)
- make sure to have A LOT of time, a LOT of patience and a LOT of molybdenum
- do not push on the internal screen and its components: go against glass, not the "LCD"
- screen-frame adhesive cannot be reused, you need a new one
At this point I need to tell you that I failed and ordered a new screen from iFixIt.
I managed to get half of the work done, but then my string started to eat the internal screen :(
Marcin Pabich - Yanıt
Should I remove the thin blue backing off(has what look like serial number stickers on it) the new screen before install? Thanks
Chris Vann - Yanıt
When installing a replacement screen be sure to remove the black plastic cover that obscures the selfie camera hole, otherwise you won't be able to take selfies!
Josh - Yanıt
I didn't notice this cover when closing it up, so it didn't want to close at the top edge. Still doesn't close snugly, and the front camera doesn't work now, but idk if it's worth trying to get the screen off again and risk breaking the new display. T_T It would have been helpful to have some information on what to remove from the new screen in the article.
Hitch -
Update, a few minutes later: I was able to fix it! The adhesive was fresh enough that a little heat was enough for me to get just the top edge open enough to slip in a pair of tweezers and remove the covering. Camera is now functioning.
Hitch -
Thank you Hitch!
I encountered the same situation and could solve it just as you did.
mikg -
how important is it to put the display cable bracket back on?? I forgot then sealed up
Kyle Walker - Yanıt
Hi Kyle,
The display cable bracket with the piece of foam holds the connector in place. Without it, the connector just holds with a little friction and is likely to come off by vibration or shock. Your mileage may vary. At least you know how to fix it, should it come off. Keep the bracket in a safe place.
What I do not know is, if there is a possibility for electrical damage on the screen or the mainboard, should the connector not come off completely, leaving just some contacts connected. But given the low currents, damage seems not very likely. At least in my experience, these things are relatively robust.
mikg -
Hello! Does anyone know if it is possible not to change the whole screen of the phone but somehow to reattach the upper glass only? My problem is that the screen itself is fine but the glass goes off a bit in the left upper corner and now there's a several mm whole in between the glass and the screen. Is it possible somehow to fix it without changing the whole screen? Thanks a lot for your replies!
Lily - Yanıt
The replacement screen isn't sitting flush with the phone. What have I missed?
Thanks
Jon Smith - Yanıt
Hi Jon,
If it is on the top, you likely didn't remove the cover that obscures the selfie camera, which will prevent you from taking selfies too (see comments above). Happened to me and solved it, like Hitch described.
Other possibilities include incomplete cleaning of the old adhesive, torn application of the new adhesive or having some other 'body' lodged between frame and screen.
Best of luck!
mikg -
le tuto est genial tout fonctionne merciiiiiiii
Moi Tusauraspas - Yanıt
Having issues with the proximity sensor after replacing display. Screen no longer turns off when against face on calls, nor does flip to shh work. I checked for all protective films, nothing present (looked just like the original display and even just like what's pictured above). What do I need to do?!
Kyle Walker - Yanıt
I have used iFixit guides to repair phones/tablets numerous times over the years, and this is yet another thorough, well put together guide that led to another successful repair.
One thing to pay attention to is the additional hyperlinks/steps needed to reinstall the fingerprint sensor and follow them carefully. For anyone who hasn't messed around with installing custom ROMs on phones/tablets, this might seem a bit daunting, but it's just a matter of following the steps carefully and you should be able to get it done - make sure that you are using the Chrome browser too - I wasn't able to get this to work with Firefox.
One last note on the Pixel 7 driver installation if you're on Windows and have already downloaded the driver - make sure to extract it somewhere easy to find (like the Downloads folder). In Device Manager, Pixel 7 was located under "Universal Serial Bus devices". Once you're ready to select the file to install, you only need to select the folder - it will install the correct driver file.
Christopher Ingram - Yanıt
Just did this! I appreciate the guide! If I had to write a caution to anybody below are things I think I could have done better.
-I put the pick in too deep and bent a spring
-I rushed myself to remove the adhesive, hindsight I should have some solvent or brake cleaner and a wooden toothpicks
- I rushed to try and put the adhesive on, it felt like I took my time but I didn't.... #hindshight...
Allan Whitney - Yanıt
Hi, Im from Ecuador and my Google Pixel 7 has a broken screen. There's no place here that sells the screen and can fix it. Do you really recommend that I buy the screen or buy another phone?
Dome Niama - Yanıt
Just replaced the screen. All was good, including the fingerprint sensor (for that you have to go through the steps outlined in many other comments, and use a good USB cable) but what's missing from this guide is the part on how fix the adhesive, which is quite critical and delicate. I recommend this video, also from iFixit (even if it's for the Pro version the steps are the same): https://www.youtube.com/watch?v=Uag55fu5...
Sergio Nalin - Yanıt
Moin, ich versuche bei euch mein Glück.
Ich suche ein defektes aber noch funktionierendes Display für ein Goggle Pixel 7. Es wird nur zur Datenrettung benötigt, weil meins komplett schwarz ist nach einem Wasserschaden. So das ich den Datenmodus aktivieren kann.
Vielleicht habt ihr noch nicht alle entsorgt.
MfG R. Gierth
ragie@freenet.de
Ralf Gierth - Yanıt
This mainly worked and i was able to extract the data from the phone. However after glueing in the new screen it is not seamless woth the housing and standing out like almost 1mm. It looks like the screen did not fit into the inner clamps and is now only attached by the glue. Any ideas?
Patrick - Yanıt
Moin zusammen,
mein Google Pixel 7 hat einen Wasserschaden erlitten und funktionierte danach nicht mehr. Ich habe es zur Reparatur gegeben, aber es wurde nur gereinigt und unrepariert zurückgegeben.
Ich habe dann herausgefunden, dass offenbar nur das Display defekt ist – alles andere scheint zu funktionieren. Ich habe eine Maus und Tastatur per USB angeschlossen und mich über die Microsoft Smartphone-Link-App mit Screenshots behelfen können. Mit TalkBack konnte ich die Eingaben besser verstehen und bin zu dem Schluss gekommen, dass bis auf das Display alles funktioniert (es gibt nur kleinere Darstellungsfehler, wahrscheinlich durch das defekte Display).
Jetzt überlege ich, ob es sich lohnt, das Display selbst zu tauschen. Hat jemand Erfahrungen damit oder würdet ihr eher empfehlen, sich ein neues Gerät zu kaufen?
Vielen Dank schon mal für eure Hilfe!
Jakob
Jakob Ströhlein - Yanıt
I took off the old screen and replaced it with my new screen, yet it still doesn't display. It has life (vibrates and can do things I think). This was the same issue with the old screen, and I thought replacing screens would work. Any suggestions?
Matthew - Yanıt
Great guide! The most annoying part was removing the old screen adhesive, so make sure to have some isopropyl alcohol on hand for a repair – only a sad little wipe is provided in iFixit's kit. Other than that, everything else went as intended.
Marat Ismailov - Yanıt
I was apprehensive to begin with but the kit is really helpful. Some patience, common sense and work is all that is needed. Just like other posts, scraping off the old adhesive was the most time consuming step. And fingerprint calibration is super easy - just takes a couple minutes and it is done.
One more thing I want to add is that it is easy to miss the adhesive fixing steps in this tutorial - there is a small link which takes you to a different page. I kind of missed it and ripped out the entire adhesive before applying on the phone. It is clearly shown in the video tutorial though.
Rakesh S - Yanıt
Thanks to this guide and ifixit in general, I do not need to purchase a new phone! I was worried when my phone had signs of water damage/screen failure; but took the screen off and had a more knowladgeable friend take a look and say the internals were fine.
The money spent on the fixit kit was reasonable but a bit nervewracking because there was no guarantee the phone would work, but ifixit does accept returns and I do value repairability so I decided to go for it.
This guide was excellent and helped with being able to safely take the screen off without puncturing anything. The trickiest part was removing and adding the adhesive. I do wish the guide went into a bit more depth as far as re-assembly; specifically tips on applying the adhesive. But the linked guide was good at giving general directions and the included strip was well designed.
10/10 would recommend.
I do not currently have the fingerprint reader working; I have a modified version of android flashed on my phone so am not sure how to proceed there.
projectproxy - Yanıt
Worked like a charm, it even made my fingerprint reader work better after having to calibrate it twice. My only gripe is that the inserting of the screen is almost impossible, I spent a good hour at least just trying to press this connector in. After looking on YouTube for a bit to see how others do it I attempted to kind of approach it from the side and let the connector "roll" onto the other connector. After which I was able to press it in.
Tijmen - Yanıt
Just wanted to post this in case anyone had trouble with the fingerprint sensor calibration. Specifically ending up in a rescue mode boot loop after a failed attempt to connect to the phone in fastboot mode.
I'm not sure what happened but when using the pixelrepair tool it would detect the phone but kept coming back with an error "unable to connect". It was late on a weeknight so I decided I'd try again the following day and just use a PIN for a day. After rebooting, the phone booted into rescue mode, I did a force reboot (pwr+vol_up) and the same happened again. Did another force reboot but then pressed vol_down to enter fastboot, selected "start" and it went back to rescue mode again. Tried everything to get the phone to reboot into the OS to no avail. I couldnt even access the Android recovery menu. I ended up having to connect it to my computer again and use the "ADB reboot" command to get it to boot the OS.
After this the pixelrepair tool compleated the fingerprint sensor calibration properly.
Curtis Murphy - Yanıt
Hi - Since following the instructions and replacing the screen, the finger scanner is not working. Any solution? David G
David Griffiths - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 122
Son 7 gün: 855
Son 30 gün: 3,903
Her zaman: 104,613
