Ana içeriğe geç
Google Pixel 7a Wireless Charging Assembly Replacement
Clay Eickemeyer
Clay Eickemeyer ve 6 diğer katkıda bulunanlar
En son April 24, 2025 tarihinde güncellendi
30 dakika - 1 saat
Orta
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace the wireless charging assembly in your Google Pixel 7a.
The wireless charging assembly, also known as the inner housing, consists of the logic board cover and wireless charging coil.
Note: The Verizon model Google Pixel 7a (G0DZQ) has a 5G mmWave antenna. If you have this model, some photos in this guide differ, but the procedure is the same.
If your battery is swollen, take appropriate precautions.
You'll need replacement adhesive in order to complete this repair.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair will depend on how well you reapply the adhesive.
  1. Google Pixel 7a Wireless Charging Assembly Replacement, Prepare your phone for disassembly: adım 1, 2 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Prepare your phone for disassembly: adım 1, 2 resimden 2.
    • Allow your battery to drain below 25% before starting this repair. A charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone and fully power it down.
    If you purchased the iFixit kit, now is a good time to ensure you have all the parts: If you go to the kit page, and expand Kit Contents, you'll see the full list. The full list contains links to details on adhesive sets. These links are also in this guide document, in the upper right, in a scrollable window.⏎
    Newer batteries seem to come with the 1IP Torx Plus bit taped in the tray of the battery part tray (Repair Part box). It is not in the Tools, found in the Repair Tools box (if you purchased the Fix Kit).⏎
    Familiarize yourself with all the parts, including the six adhesive items. Ensure none of the components fell behind the parts tray and are left in the parts box (they are tiny adhesive tabs). The adhesive is VERY sticky. Don't remove the backing until you are ready to use, and then be prepared to lay the piece in place once ANY contact is made. Removal, even an edge, to better align an adhesive part is often not possible(!). The adhesive will stretch and bunch up.⏎
    As noted at the beginning of the guide, proper installation of the adhesive is required to maintain water resistance, but also to transfer heat correctly.
    Chris Romer - Yanıt
  2. Google Pixel 7a Wireless Charging Assembly Replacement, Soften the adhesive: adım 2, 1 resimden 1.
    • Apply a heated iOpener to the bottom edge of the rear cover for three minutes.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate to warm the rear cover.
    • Only heat the phone enough so it's just hot to the touch. Extreme heat can damage the screen, rear cover, or battery.
    If you have an IR Thermometer or Thermal Camera, you're going for 85C/185F. Even with mini heat guns, this comes up fast; just a few seconds of heat.
    Chris Romer - Yanıt
  3. Google Pixel 7a Wireless Charging Assembly Replacement, Secure an Anti-Clamp: adım 3, 3 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Secure an Anti-Clamp: adım 3, 3 resimden 2. Google Pixel 7a Wireless Charging Assembly Replacement, Secure an Anti-Clamp: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backward to unlock the Anti-Clamp's arms.
    • Slide the arms over the bottom edge of the phone, with one suction cup on the rear cover and one on the screen.
    • Squeeze the cups together to create suction.
  4. Google Pixel 7a Wireless Charging Assembly Replacement, Use the Anti-Clamp to create a gap: adım 4, 3 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Use the Anti-Clamp to create a gap: adım 4, 3 resimden 2. Google Pixel 7a Wireless Charging Assembly Replacement, Use the Anti-Clamp to create a gap: adım 4, 3 resimden 3.
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise one full turn (360 degrees), or until the suction cups begin to stretch.
    • As the cups stretch, make sure they stay aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
  5. Google Pixel 7a Wireless Charging Assembly Replacement, Insert an opening pick using the Anti-Clamp: adım 5, 1 resimden 1.
    • While the heat from an iOpener is sufficient to separate the rear cover, it might cool down while you set up the Anti-Clamp. Reheat the rear cover if you need more time to set it up.
    • Place an object under your phone so it rests level while between the Anti-Clamp's arms.
    • Wait one minute, or until the adhesive separates, for a gap to form along the bottom edge of the phone.
    • Insert an opening pick into the gap between the rear cover and the frame.
    • If the adhesive doesn't separate, twist the handle clockwise one quarter turn and wait another minute. Apply more heat with a hair dryer or heat gun if the rear cover cools down.
    • Remove the suction cups from the phone using their pull-tabs and set the Anti-Clamp aside.
  6. Google Pixel 7a Wireless Charging Assembly Replacement, Insert an opening pick using a suction handle: adım 6, 3 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Insert an opening pick using a suction handle: adım 6, 3 resimden 2. Google Pixel 7a Wireless Charging Assembly Replacement, Insert an opening pick using a suction handle: adım 6, 3 resimden 3.
    • If you've already inserted an opening pick using the Anti-Clamp, skip this step.
    • Apply a suction handle to the center of the bottom edge of the rear cover.
    • Pull up on the suction handle with a strong, steady force until a gap forms between the rear cover and frame.
    • Insert the tip of an opening pick into the gap.
    • Remove the suction handle.
  7. Google Pixel 7a Wireless Charging Assembly Replacement, Adhesive information: adım 7, 2 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Adhesive information: adım 7, 2 resimden 2.
    • The rear cover is secured with adhesive around the perimeter of the frame and near the cameras. Use this picture as a reference while you slice the adhesive.
    There is also a plastic bezel attached to the rear cover which you DO NOT want to remove. It's a very similar (temperature wise) adhesive that connects that bezel to the cover, as connects the bezel & cover to the frame, but since only the frame side adhesive is provided in the kit, you want to try not removing that bezel from the rear cover.
    Chris Romer - Yanıt
    If you did remove the rear cover bezel, while removing the rear cover, grab some T7000 glue, which has a precision application needle tip. Follow the instructions on how to apply the iFixit adhesive which you'll reach at and perimeter pieces at the end of this guide, but hold off on removing the blue tape pieces facing the cover. Make sure you know how to orient the bezel (there is a little notch ridge that goes over the USB-C power port. Clean up the bezel of adhesive, but don't remove the cover liner, which seems to stay in place even with the heat and prying that accidentally broke the bezel adhesives. Install rear cover, with loose bezel, to check you have it right.
    Remove, apply a bead of T7000 around the rear cover and then lay the bezel into that bead, carefully checking orientation. Pull your blue strips, install the cover with freshly glued bezel, and press the assembly overnight (using some clean cloths and a few books works - I used soft auto polishing microfibers and a kit of hydraulic caps).
    Chris Romer - Yanıt
  8. Google Pixel 7a Wireless Charging Assembly Replacement, Angle the opening pick: adım 8, 3 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Angle the opening pick: adım 8, 3 resimden 2. Google Pixel 7a Wireless Charging Assembly Replacement, Angle the opening pick: adım 8, 3 resimden 3.
    • Angle the opening pick upward so the tip faces away from the frame.
    • From here on, keep all opening picks angled upward while slicing until the rear cover is fully removed.
    • Slide your pick to the bottom left corner of the rear cover.
    • Leave this pick in place to prevent the adhesive from resealing.
  9. Google Pixel 7a Wireless Charging Assembly Replacement, Separate the bottom edge adhesive: adım 9, 2 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Separate the bottom edge adhesive: adım 9, 2 resimden 2.
    • Insert a second opening pick in the bottom left corner.
    • Slide the new pick to the bottom right corner of the rear cover to separate the bottom edge adhesive.
  10. Google Pixel 7a Wireless Charging Assembly Replacement, Soften the right edge adhesive: adım 10, 1 resimden 1.
    • Apply a heated iOpener to the right edge of the rear cover for two minutes.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate to warm the rear cover. Remember to not overheat the phone.
  11. Google Pixel 7a Wireless Charging Assembly Replacement, Separate the right edge adhesive: adım 11, 3 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Separate the right edge adhesive: adım 11, 3 resimden 2. Google Pixel 7a Wireless Charging Assembly Replacement, Separate the right edge adhesive: adım 11, 3 resimden 3.
    • Don't insert your pick deeper than 5 mm along the right edge to avoid damaging the wireless charging coil.
    • For a visual reference, you can measure 5 mm from the tip and mark your pick with a permanent marker.
    • Insert a third opening pick in the bottom right corner of the rear cover.
    • Slide your pick up the right edge of the rear cover to separate its adhesive. Stop when you reach the camera bar.
  12. Google Pixel 7a Wireless Charging Assembly Replacement, Soften the left edge adhesive: adım 12, 1 resimden 1.
    • Apply a heated iOpener to the left edge of the rear cover for two minutes.
  13. Google Pixel 7a Wireless Charging Assembly Replacement, Separate the left edge adhesive: adım 13, 3 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Separate the left edge adhesive: adım 13, 3 resimden 2. Google Pixel 7a Wireless Charging Assembly Replacement, Separate the left edge adhesive: adım 13, 3 resimden 3.
    • Don't insert your pick deeper than 3 mm along the left edge to avoid damaging the wireless charging coil and rear cover foam pad.
    • For a visual reference, you can measure 3 mm from the tip and mark your pick with a permanent marker.
    • Insert a fourth opening pick in the bottom left corner of the rear cover.
    • Slide your pick up the left edge of the rear cover to separate the adhesive. Stop when you reach the camera bar.
  14. Google Pixel 7a Wireless Charging Assembly Replacement, Soften the top edge adhesive: adım 14, 1 resimden 1.
    • Apply a heated iOpener to the top edge of the rear cover for two minutes.
  15. Google Pixel 7a Wireless Charging Assembly Replacement, Separate the antenna bracket adhesive: adım 15, 3 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Separate the antenna bracket adhesive: adım 15, 3 resimden 2. Google Pixel 7a Wireless Charging Assembly Replacement, Separate the antenna bracket adhesive: adım 15, 3 resimden 3.
    • There's a thick strip of adhesive along the antenna housing.
    • Insert a fifth opening pick in the top left corner of the rear cover between 8 mm and 10 mm (0.3–0.4 in) deep, or just over halfway between the tip of the pick and the iFixit logo.
    • If you can't insert the pick, start with the small gap near the camera bar from the previous pick.
    • Slide your pick halfway across the top edge to separate the antenna bracket adhesive. Stop at the halfway point along the top edge.
    This is the trickiest part, because the camera bar wants to keep the back cover from lifting. It's like a break in the leverage, of the lower part of the case. Go easy.
    Chris Romer - Yanıt
  16. Google Pixel 7a Wireless Charging Assembly Replacement, Separate the remaining top edge adhesive: adım 16, 3 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Separate the remaining top edge adhesive: adım 16, 3 resimden 2. Google Pixel 7a Wireless Charging Assembly Replacement, Separate the remaining top edge adhesive: adım 16, 3 resimden 3.
    • Pull your opening pick out to a depth of 3 mm.
    • Slide your pick to the top right corner to slice the rest of the top edge adhesive.
    • Don't insert your pick deeper than 3 mm to avoid damaging the antenna housing graphite tape.
  17. Google Pixel 7a Wireless Charging Assembly Replacement, Rotate your top edge opening picks: adım 17, 3 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Rotate your top edge opening picks: adım 17, 3 resimden 2. Google Pixel 7a Wireless Charging Assembly Replacement, Rotate your top edge opening picks: adım 17, 3 resimden 3.
    • Remember to angle your picks upward and away from the frame during this step.
    • Roll the top edge pick so its flat edge is under the rear cover.
    • Roll the picks on each side of the camera bar so their flat edges are under the camera bar.
  18. Google Pixel 7a Wireless Charging Assembly Replacement, Pry up the camera bar: adım 18, 3 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Pry up the camera bar: adım 18, 3 resimden 2. Google Pixel 7a Wireless Charging Assembly Replacement, Pry up the camera bar: adım 18, 3 resimden 3.
    • There's a long strip of adhesive securing the rear cover below the camera bar.
    • Use the opening picks under the camera bar to pry the top edge of the rear cover from the frame.
    • Pry back and forth until the camera bar loosens.
    • Be careful not to bend the rear cover. Only pry enough to loosen the adhesive near the camera bar. If the adhesive feels stubborn, rotate the rear cover side-to-side to further loosen the adhesive.
  19. Google Pixel 7a Wireless Charging Assembly Replacement, Finish separating the adhesive: adım 19, 3 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Finish separating the adhesive: adım 19, 3 resimden 2. Google Pixel 7a Wireless Charging Assembly Replacement, Finish separating the adhesive: adım 19, 3 resimden 3.
    • Slide the opening picks from the camera bar down the long edges of the rear cover to separate any adhesive that may have resealed.
  20. Google Pixel 7a Wireless Charging Assembly Replacement, Remove the rear cover: adım 20, 2 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Remove the rear cover: adım 20, 2 resimden 2.
    • Remove the rear cover.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your rear cover.
    This reassembly link, "Follow This Guide" is really important. It's a shame they did it this way, but make a note of it for when you come back through.
    Chris Romer - Yanıt
  21. Google Pixel 7a Wireless Charging Assembly Replacement, Soften the flash unit adhesive: adım 21, 2 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Soften the flash unit adhesive: adım 21, 2 resimden 2.
    • Apply a heated iOpener to the flash unit for one minute to soften the adhesive securing it to the logic board cover.
    • Alternatively, you can use a hair dryer or heat gun to warm the flash.
    • Only heat the flash so it's warm to the touch. The battery and surrounding components are susceptible to heat damage.
  22. Google Pixel 7a Wireless Charging Assembly Replacement, Separate the flash unit adhesive: adım 22, 2 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Separate the flash unit adhesive: adım 22, 2 resimden 2.
    • Be careful not to slip and tear the flash cable, as it's very fragile.
    • Slide your pick under the right edge of the flash to separate the adhesive securing it to the cover.
    Not a good place to pry as there is a little ridge blocking access to the flash unit. Just use a tweezer to slightly lift the other side of the cable, the unit comes out easily (with proper heating).
    Yong Wang - Yanıt
    Cuidado en este procedimiento, algo dañe y el flash quedo en color azul.
    Aurelio Garcia - Yanıt
  23. Google Pixel 7a Wireless Charging Assembly Replacement, Clean the logic board cover: adım 23, 3 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Clean the logic board cover: adım 23, 3 resimden 2. Google Pixel 7a Wireless Charging Assembly Replacement, Clean the logic board cover: adım 23, 3 resimden 3.
    • If the copper tape lifted away with the flash, use tweezers or your fingers to remove the black foam residue from the logic board cover.
  24. Google Pixel 7a Wireless Charging Assembly Replacement, Remove the old copper tape: adım 24, 3 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Remove the old copper tape: adım 24, 3 resimden 2. Google Pixel 7a Wireless Charging Assembly Replacement, Remove the old copper tape: adım 24, 3 resimden 3.
    • Be careful not to damage the battery with your tool during this step.
    • Apply a heated iOpener to the underside of the flash for one minute.
    • Hold the neck of the flash cable steady and use tweezers to peel and remove the copper tape from the flash unit.
    • If the copper tape stayed on the logic board cover and you have a replacement, remove the old tape now.
    It can be a little tricky applying the new copper tape. I was able to get through it by:
    - Pressing down the black adhesive on the logic board cover,
    - Lining up the new copper with the flash's backside,
    - Sandwiching them both when pressing the flash back into place.
    pinballwizard - Yanıt
    Did not find the new copper tape in my kit, and this was really confusing. Would be helpful to show the part, from the kit here.
    Chris Romer - Yanıt
    I didn't notice the replacement copper tape until I got ready to put the back cover on again. In the kit, it's attached to the same piece of plastic that has the edge adhesive.
    David Y - Yanıt
  25. Google Pixel 7a Wireless Charging Assembly Replacement, Unfasten the logic board cover: adım 25, 2 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Unfasten the logic board cover: adım 25, 2 resimden 2.
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • While the Pixel 7a uses Torx Plus screws, standard Torx drivers may still work. If your kit came with standard Torx bits, use the T2 bit to remove 1IP Torx Plus screws, and the T3 Torx bit to remove 3IP Torx Plus screws. Make sure to apply constant, downward force to prevent stripping.
    • Use a 3IP Torx Plus driver to remove the thirteen 4.3 mm screws securing the logic board cover.
    • Use a 1IP Torx Plus driver to remove the 1.5 mm screw securing the right edge of the cover.
    The T2 Torx driver that came with the tool kit does not fit. It seems a bit too large. Is this really T2 Torx?
    Yong Wang - Yanıt
    This is right. This is because the Pixel 7a uses Torx Plus screws, which are less commonly available than regular Torx bits. We're only able to provide regular Torx bits in our kits, for now. So, the bit size is slightly different to reduce the likelihood of stripping your screws out. When using the T2 bit to remove Torx Plus 1IP screws, use constant downward force to keep the bit fitting as well as possible.
    Clay Eickemeyer -
    こんにちは、1IPネジが少し舐めたので、交換しようと思っています、代替となるものはM1 1.5mmでしょうか?
    勝山ゆ う や - Yanıt
    結論から言うと、おそらくネジの専門家でも現物を見ないと判断できないので、長さ1.5mmのM1ネジを入手できるお店をご存知ならネジの現物を持っていって判断してもらうのが間違いないです。そのようなお店をご存知なくて、元々のネジが再利用できそうなら、再利用するのが正解だと思います。
    私はPixel 7aの実機を持っていないのでネジ頭の種類は画像で判断するしかないのですが、おそらく低頭ネジ(pancake head、締め付け面が平ら)か皿ネジ(flat head、締め付け面が円錐形)かと思われます。トルクスプラスの1IPネジを作っているメーカーのサイズ表を見てみましたが、低頭ネジについては太さの情報がありませんでした。皿ネジについてはM0.9とM1の2種類の記載がありました。
    仮にこの2種類のどちらかであるとしても、どちらかを判別するには専用の道具が必要になりますし、別のサイズの特注品の可能性もあります。また、自力で判別できたとしてもこのサイズのネジを扱っているのはネジの専門店だけだと思われますので、結局ネジの専門店に現物を持ち込んで相談するのが最適解になるかと思います。
    なお、トルクスプラスIPネジと普通のトルクスネジではネジ頭の溝形状が異なるので、トルクスプラスIPネジを通常のトルクスドライバーで扱おうとすると隙間ができるはずです。そもそも強い締め付け力が必要な場所でもなさそうですし、ネジの締め付けや取り外しに問題ない程度の舐め具合であれば、元々のネジを再利用するのが現実的ではないかと思います。
    なお、私はネジの専門家ではないですしPixel 7aの実機を持っているわけでもありませんので、上記の内容に問題がある可能性があることはご了承ください。また、不備を見つけた方がいらっしゃいましたら訂正していただければ幸いです。
    最後に参考資料として、トルクスプラスネジの寸法規格表を紹介しておきます。どちらも英語です。
    Weha Tools社のトルクスプラスネジ寸法一覧表
    ポップリベット・ファスナー社のトルクスプラスねじパンフレット(PDF)(サイズ表は14ページ)
    Servause -
    Can’t remove T2 screw.
    Brenda - Yanıt
    needs a T1 torx
    folbaeni - Yanıt
    It is unbelievably disingenuous to claim that the T2 Torx bit you supply fits the 1IP Torx Plus Screws. I'm sitting here with my phone half-dissembled searching Amazon to see if I can find a T1 Torx bit or a Torx Plus bit that can be delivered today. Hopefully anyone who reads this guide before buying, opens these comments and decides you aren't worth their time. I also plan to leave a review on the kit itself. I can't believe I paid $10 in shipping and waited a full week for this half-assed kit.
    Nick Hughes - Yanıt
    This si a scam, don't waste your money on this. They make you buy a hole set of tools even when the know the don't have the proper tools to get the work done! That T2 Torx IFIXIT is selling doesn't work.
    Cristian González - Yanıt
    Agree with previous comments. Included T2 bit does not even come close to fitting in the torx plus 1ip screw. Having to overnight a T1 bit in hopes it works.
    Aaron - Yanıt
    After overnighting a precision bit set, it now appears that the T2 bit included in the iFixit kit may be out of spec. The T2 bit from the Amazon bit set fit as described and allowed me to complete the fix.
    Aaron -
    Got this far just to realize the same as above. The t2 bit that comes with the kit is wayyy to large to fit this screw
    Bilal Shaikh - Yanıt
    Also chiming in here to advise that the T2 bit supplied is too large...hopefully this gets addressed!
    Elliott Marter - Yanıt
    I am another person who is Too late to read this comment :). And further I have a Torx set with a T1 and even that doesnt work on this tiny complicated screw. I will be taking this to a local shop for repair and hope for some luck.
    h a. S - Yanıt
    The provided T2 bit in the kit does not fit the screw here
    Joseph - Yanıt
    I borrowed a friends T2 bit and it fit the screw perfectly. The ifixit T2 bit was the problem here.
    Joseph -
    This is a complete rip off to advertise a one stop shop kit and then knowingly include the wrong bit, which doesn't fit the phone. What a terrible experience. I've got a disassembled phone and now have to wait to order the proper bit. Never using ifixit again. Terrible experience.
    Ludwig von Rochau - Yanıt
    I have a half disassembled phone that I can't take to work because of this t2 issue. Do not recommend
    Konrad Cichocki - Yanıt
    Read through the guide before buying the kit, but I wish I had read the comments. As mentioned by everyone else, they literally do not provide the proper tools in the battery replacement kit...
    Mikko Saavalainen - Yanıt
    Can confirm that I wasn't able to unscrew the 1LP Torx plus screw with the torx 2 bit which came with the kit. I'm stuck with a half disassembled phone :(
    Anup - Yanıt
    My kit came with a 1lP bit in the battery package, so was able to complete the battery replacement no issues.
    Graeme Watson - Yanıt
    Mine was the same.
    Chris Romer -
    I was able to use a 0.7 Allen bit( i think its Allen, not sure though) from my Mako kit to unscrew it. the screw on my phone wasn't tight thankfully so it came off rather easily but if the screw is too tight it might strip the screw so beware
    Graystar3 - Yanıt
    This needs to get fixed. Same issue as everyone else. Disassembled phone, now unable to fix it due to wrong bits included. Not very happy with ifixit.
    Sam Hoffman - Yanıt
  26. Google Pixel 7a Wireless Charging Assembly Replacement, Unclip the logic board cover: adım 26, 2 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Unclip the logic board cover: adım 26, 2 resimden 2.
    • Insert an opening pick between the bottom right corner of the logic board cover and the frame.
    • Pry up to release the clip securing the cover.
    iFixit Staff - Please provide instructions for how to secure this clip during reassembly.
    ChelseaH - Yanıt
  27. Google Pixel 7a Wireless Charging Assembly Replacement, Free the flash unit: adım 27, 3 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Free the flash unit: adım 27, 3 resimden 2. Google Pixel 7a Wireless Charging Assembly Replacement, Free the flash unit: adım 27, 3 resimden 3.
    • Slowly lift the top edge of the logic board cover and thread the flash unit through its cutout.
    • During reassembly, thread the flash through its cutout as you lower the logic board into place.
  28. Google Pixel 7a Wireless Charging Assembly Replacement, Remove the wireless charging assembly: adım 28, 2 resimden 1. Google Pixel 7a Wireless Charging Assembly Replacement, Remove the wireless charging assembly: adım 28, 2 resimden 2.
    • Remove the wireless charging assembly.
    For Step 28, during reassembly, thread the flash through its cutout as you lower the logic board into place. (This note from Step 27 should really be provided here).
    ChelseaH - Yanıt
Sonuç
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Clay Eickemeyer
82.983 İtibar
455 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
9 Üyeler
11.707 adet Kılavuz yazıldı
1Rehber Yorum
Where can you buy a new wireless charging assembly?
Teagan Bliss - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 33
Son 30 gün: 142
Her zaman: 2,866
