Ana içeriğe geç
Google Pixel 8a Battery Replacement
Neye ihtiyacın var
  1. Google Pixel 8a Battery Replacement, Prepare your Pixel for disassembly: adım 1, 3 resimden 1. Google Pixel 8a Battery Replacement, Prepare your Pixel for disassembly: adım 1, 3 resimden 2. Google Pixel 8a Battery Replacement, Prepare your Pixel for disassembly: adım 1, 3 resimden 3.
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Google Pixel 8a Battery Replacement, Adhesive information: adım 2, 3 resimden 1. Google Pixel 8a Battery Replacement, Adhesive information: adım 2, 3 resimden 2. Google Pixel 8a Battery Replacement, Adhesive information: adım 2, 3 resimden 3.
    • The back cover is secured with adhesive around the perimeter and near the cameras. To avoid damaging your phone's internals, note the following:
    • Unless stated otherwise, don't insert your tool more than 3 mm (the width of your opening tool's flat section) around the edges.
    • Don't insert your tool under the edges of the camera bump.
  3. Google Pixel 8a Battery Replacement, Insert an opening tool: adım 3, 3 resimden 1. Google Pixel 8a Battery Replacement, Insert an opening tool: adım 3, 3 resimden 2. Google Pixel 8a Battery Replacement, Insert an opening tool: adım 3, 3 resimden 3.
    • Your opening tool has a flat end and a curved end. During the opening procedure, use the flat end and angle it so the tool's sharp edge points upward.
    • Insert the edge of an opening tool between the back cover and the frame, starting with a sharp corner of the tool to help separate the adhesive.
  4. Google Pixel 8a Battery Replacement, Separate the perimeter adhesive: adım 4, 3 resimden 1. Google Pixel 8a Battery Replacement, Separate the perimeter adhesive: adım 4, 3 resimden 2. Google Pixel 8a Battery Replacement, Separate the perimeter adhesive: adım 4, 3 resimden 3.
    • Slide your opening tool along the bottom edge to separate the adhesive securing the back cover.
  5. Google Pixel 8a Battery Replacement: adım 5, 3 resimden 1. Google Pixel 8a Battery Replacement: adım 5, 3 resimden 2. Google Pixel 8a Battery Replacement: adım 5, 3 resimden 3.
    • Slide your opening tool around the bottom right corner and up the right edge, stopping at the bottom of the camera bump.
    • Remove your opening tool from under the back cover.
  6. Google Pixel 8a Battery Replacement: adım 6, 3 resimden 1. Google Pixel 8a Battery Replacement: adım 6, 3 resimden 2. Google Pixel 8a Battery Replacement: adım 6, 3 resimden 3.
    • Insert your opening tool under the top right corner of the back cover, just above the camera bump.
    • Slide your opening tool along the top edge, stopping at the top left corner just above the camera bump.
  7. Google Pixel 8a Battery Replacement: adım 7, 3 resimden 1. Google Pixel 8a Battery Replacement: adım 7, 3 resimden 2. Google Pixel 8a Battery Replacement: adım 7, 3 resimden 3.
    • Insert your opening tool under the left edge of the back cover, just below the camera bump.
    • Slide your opening tool down the left edge to separate the adhesive.
  8. Google Pixel 8a Battery Replacement, Separate the camera bump adhesive: adım 8, 3 resimden 1. Google Pixel 8a Battery Replacement, Separate the camera bump adhesive: adım 8, 3 resimden 2. Google Pixel 8a Battery Replacement, Separate the camera bump adhesive: adım 8, 3 resimden 3.
    • A strip of adhesive above the camera bump secures the top edge of the back cover.
    • Insert an opening pick under the top left corner of the back cover until the tip is close to the top edge of the camera bump.
    • You can insert the opening pick more than 3 mm along the top edge.
    • Slide the pick to the right, stopping when you reach the right edge of the cameras.
  9. Google Pixel 8a Battery Replacement: adım 9, 3 resimden 1. Google Pixel 8a Battery Replacement: adım 9, 3 resimden 2. Google Pixel 8a Battery Replacement: adım 9, 3 resimden 3.
    • A final strip of adhesive below the camera bump secures the back cover.
    • Insert the flat edge of an opening pick under the back cover, just below the camera bump.
    • Insert a second opening pick in the same spot on the other side.
  10. Google Pixel 8a Battery Replacement: adım 10, 3 resimden 1. Google Pixel 8a Battery Replacement: adım 10, 3 resimden 2. Google Pixel 8a Battery Replacement: adım 10, 3 resimden 3.
    • Pry up simultaneously with both picks and apply constant pressure to separate the final piece of adhesive securing the back cover.
    • Be careful not to bend the back cover. If the adhesive feels stubborn, rotate the cover side-to-side to further loosen the adhesive.
    • If the adhesive isn't separating, you can lightly heat the back cover just below the camera bump with a hair dryer or iOpener to soften the adhesive.
  11. Google Pixel 8a Battery Replacement, Remove the back cover: adım 11, 2 resimden 1. Google Pixel 8a Battery Replacement, Remove the back cover: adım 11, 2 resimden 2.
    • Remove the back cover.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your back cover.
  12. Google Pixel 8a Battery Replacement, Separate the flash unit: adım 12, 2 resimden 1. Google Pixel 8a Battery Replacement, Separate the flash unit: adım 12, 2 resimden 2.
    • Use a hair dryer to heat the flash unit to soften the adhesive securing it to the logic board cover.
    • Alternatively, you can use an iOpener or heat gun to warm the flash.
    • Only heat the flash so it's warm to the touch. The battery and surrounding components are susceptible to heat damage.
  13. Google Pixel 8a Battery Replacement: adım 13, 3 resimden 1. Google Pixel 8a Battery Replacement: adım 13, 3 resimden 2. Google Pixel 8a Battery Replacement: adım 13, 3 resimden 3.
    • Slide your pick under the top edge of the flash and lift to separate the adhesive securing it to the cover.
    • Be careful not to slip and tear the flash cable, as it's very fragile.
    • During reassembly, follow this guide to replace the flash adhesives.
  14. Google Pixel 8a Battery Replacement, Unclip the logic board cover: adım 14, 2 resimden 1. Google Pixel 8a Battery Replacement, Unclip the logic board cover: adım 14, 2 resimden 2.
    Bu adımda kullanılan alet:
    FixMat
    $36.95
    • While the Pixel 8a uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP screwdriver to remove the 15 screws securing the logic board cover:
    • Thirteen 4.3 mm‑long screws
    • Two 1.9 mm‑long screws
  15. Google Pixel 8a Battery Replacement: adım 15, 3 resimden 1. Google Pixel 8a Battery Replacement: adım 15, 3 resimden 2. Google Pixel 8a Battery Replacement: adım 15, 3 resimden 3.
    • Be very careful not to damage the spring contacts around your phone's perimeter. Only insert your tool where instructed.
    • Insert an opening pick under the bottom right corner of the logic board cover and pry up to release the clip.
    • Insert the tip of a spudger under the notch near the top right corner of the logic board cover (just below the screw hole) and pry up to release the clip.
  16. Google Pixel 8a Battery Replacement: adım 16, 3 resimden 1. Google Pixel 8a Battery Replacement: adım 16, 3 resimden 2. Google Pixel 8a Battery Replacement: adım 16, 3 resimden 3.
    • Slowly lift the top edge of the logic board cover and thread the flash unit through its cutout.
    • During reassembly, thread the flash through its cutout as you lower the logic board cover into place.
  17. Google Pixel 8a Battery Replacement, Remove the wireless charging assembly: adım 17, 2 resimden 1. Google Pixel 8a Battery Replacement, Remove the wireless charging assembly: adım 17, 2 resimden 2.
    • Remove the logic board cover (which has the wireless charging coil connected to it).
  18. Google Pixel 8a Battery Replacement, Disconnect the battery: adım 18, 3 resimden 1. Google Pixel 8a Battery Replacement, Disconnect the battery: adım 18, 3 resimden 2. Google Pixel 8a Battery Replacement, Disconnect the battery: adım 18, 3 resimden 3.
    • Use a pair of tweezers or your fingers to remove the metal cover on the right edge of your phone.
    • During reassembly, place the upper left corner of the cover under the hook on the logic board before laying it into place.
  19. Google Pixel 8a Battery Replacement: adım 19, 1 resimden 1.
    • This guide was shot with the Verizon model (G8HHN) Google Pixel 8a, which has an extra cable and connector for the 5G mmWave antenna (just to the left of the battery connector). If you have the non-mmWave model, just skip any steps that mention the antenna cable.
  20. Google Pixel 8a Battery Replacement: adım 20, 3 resimden 1. Google Pixel 8a Battery Replacement: adım 20, 3 resimden 2. Google Pixel 8a Battery Replacement: adım 20, 3 resimden 3.
    • Insert the flat end of a spudger under the right edge of the battery press connector and pry straight up to disconnect it.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
    • To prevent damaging the surface mounted components around the battery and 5G mmWave connectors, only pry where instructed.
  21. Google Pixel 8a Battery Replacement, Disconnect the 5G mmWave antenna: adım 21, 2 resimden 1. Google Pixel 8a Battery Replacement, Disconnect the 5G mmWave antenna: adım 21, 2 resimden 2.
    • Insert the point of a spudger under the bottom edge of the 5G mmWave antenna press connector and pry straight up to disconnect it.
  22. Google Pixel 8a Battery Replacement, Move the cables: adım 22, 3 resimden 1. Google Pixel 8a Battery Replacement, Move the cables: adım 22, 3 resimden 2. Google Pixel 8a Battery Replacement, Move the cables: adım 22, 3 resimden 3.
    • Move the battery and 5G mmWave cables out of the way of the battery.
  23. Google Pixel 8a Battery Replacement: adım 23, 2 resimden 1. Google Pixel 8a Battery Replacement: adım 23, 2 resimden 2.
    • Gently move the graphite sheet out of the way of the battery.
  24. Google Pixel 8a Battery Replacement: adım 24, 2 resimden 1. Google Pixel 8a Battery Replacement: adım 24, 2 resimden 2.
    • Gently fold the side button tab over the left edge of your phone, so it's out of the way of the battery.
  25. Google Pixel 8a Battery Replacement, Heat the battery adhesive: adım 25, 1 resimden 1.
    • Two strips of adhesive secure the battery in its recess.
    • Flip your phone over and use a hair dryer, heat gun, or hot plate to evenly heat the screen until the entire frame is warm to the touch.
    • Be careful not to overheat the screen, as it's susceptible to heat damage. Don't concentrate the heat in any one spot.
  26. Google Pixel 8a Battery Replacement, Pry up the battery: adım 26, 2 resimden 1. Google Pixel 8a Battery Replacement, Pry up the battery: adım 26, 2 resimden 2.
    • Insert the flat end of an opening pick between the left edge of the battery and the frame.
  27. Google Pixel 8a Battery Replacement: adım 27, 3 resimden 1. Google Pixel 8a Battery Replacement: adım 27, 3 resimden 2. Google Pixel 8a Battery Replacement: adım 27, 3 resimden 3.
    • Take care not to deform or puncture the battery—a damaged battery is a potential safety hazard.
    • Firmly secure the frame with one hand, and use your free hand to pry up the battery with the opening pick. Keep steady pressure on the pick for one minute.
    • If you're having trouble, try using a plastic card or two picks side by side to get more leverage.
    • If the battery really isn't budging, apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the left edge of the battery, elevate the left edge of your phone, and wait one minute for the adhesive to soften.
    • Once the adhesive begins to separate, slide your pick deeper under the battery and continue prying it up.
  28. Google Pixel 8a Battery Replacement, Remove the battery: adım 28, 3 resimden 1. Google Pixel 8a Battery Replacement, Remove the battery: adım 28, 3 resimden 2. Google Pixel 8a Battery Replacement, Remove the battery: adım 28, 3 resimden 3.
    • Use your opening pick to lift the battery, separating any remaining adhesive.
    • Remove the battery.
  29. Google Pixel 8a Battery Replacement, Reassembly instructions: adım 29, 3 resimden 1. Google Pixel 8a Battery Replacement, Reassembly instructions: adım 29, 3 resimden 2. Google Pixel 8a Battery Replacement, Reassembly instructions: adım 29, 3 resimden 3.
    • The next three steps show how to apply new adhesive and install your replacement battery.
    • Use the flat end of your spudger to scrape an edge of the old adhesive into a ball large enough to grip with a pair of tweezers.
    • Use tweezers or your fingers to peel and remove the old adhesive from the frame.
    • Apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to any adhesive residue and wipe it with a lint-free or microfiber cloth.
  30. Google Pixel 8a Battery Replacement: adım 30, 3 resimden 1. Google Pixel 8a Battery Replacement: adım 30, 3 resimden 2. Google Pixel 8a Battery Replacement: adım 30, 3 resimden 3.
    Tesa 61395 Tape
    $2.99
    • If your battery comes with adhesive pre-installed, remove its adhesive liners and skip this step.
    • Peel the large, clear liner from the two battery adhesive strips.
    • Alternatively, you can use strips of thin, double-sided tape to secure the battery.
    • Apply the strips to the battery recess, so the longer strip is on the left side.
    • Firmly press down along the length of both strips to secure the adhesive to the frame.
    • Remove the remaining blue liner from the strips.
  31. Google Pixel 8a Battery Replacement: adım 31, 3 resimden 1. Google Pixel 8a Battery Replacement: adım 31, 3 resimden 2. Google Pixel 8a Battery Replacement: adım 31, 3 resimden 3.
    • Lay the battery into its recess and firmly press it into place, making sure the side button tab doesn't get stuck between the battery and frame.
Sonuç
To reassemble your device, follow these instructions in reverse order starting from this step.
Calibrate your newly installed battery after completing this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Spencer Day
96.225 İtibar
662 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 32
Son 7 gün: 257
Son 30 gün: 1,109
Her zaman: 10,973
