Ana içeriğe geç
Lenovo ThinkPad X1 Carbon 7th Gen Back Cover Replacement
Chayton Ritter
Chayton Ritter ve 7 diğer katkıda bulunanlar
En son October 7, 2024 tarihinde güncellendi
3 - 5 dakika
Kolay
Use this guide to remove or replace the back cover on a Lenovo ThinkPad X1 Carbon 7th Gen laptop.
Before you perform this repair, be sure to completely power off and unplug your laptop. Make sure the laptop is not in standby, sleep, or hibernation mode.
Neye ihtiyacın var
Aletler
  1. Lenovo ThinkPad X1 Carbon 7th Gen Back Cover Replacement, Back cover removal: adım 1, 2 resimden 1. Lenovo ThinkPad X1 Carbon 7th Gen Back Cover Replacement, Back cover removal: adım 1, 2 resimden 2.
    • Use a Phillips #1 screwdriver to loosen the five captive screws securing the back cover.
  2. Lenovo ThinkPad X1 Carbon 7th Gen Back Cover Replacement, Insert an opening pick: adım 2, 3 resimden 1. Lenovo ThinkPad X1 Carbon 7th Gen Back Cover Replacement, Insert an opening pick: adım 2, 3 resimden 2. Lenovo ThinkPad X1 Carbon 7th Gen Back Cover Replacement, Insert an opening pick: adım 2, 3 resimden 3.
    • Insert an opening pick at a 45˚ angle between the back cover and frame near the rear middle screw.
    • Pry up on the pick to release the clips securing the back cover to the frame.
    • You will hear several clicks while prying up.
  3. Lenovo ThinkPad X1 Carbon 7th Gen Back Cover Replacement, Remove the back cover: adım 3, 3 resimden 1. Lenovo ThinkPad X1 Carbon 7th Gen Back Cover Replacement, Remove the back cover: adım 3, 3 resimden 2. Lenovo ThinkPad X1 Carbon 7th Gen Back Cover Replacement, Remove the back cover: adım 3, 3 resimden 3.
    • Lift the back cover up and remove it from the chassis.
    • You will hear several clicks while lifting up.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad X1 Carbon Answers community for help.
2 farklı kişi bu kılavuzu tamamladı.
Chayton Ritter
22.531 İtibar
105 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
9 Üyeler
11.494 adet Kılavuz yazıldı
1Rehber Yorum
Hola! gracias por el manual!
¿Dónde puedo conseguir la pieza de plástico (o pua) para soltar los clicks que fijan la tapa a presión?
JoseMa - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 21
Son 30 gün: 126
Her zaman: 4,319
