Ana içeriğe geç
Motorola Edge Screen Replacement
Neye ihtiyacın var
    1. Motorola Edge Screen Replacement, Find the SIM tray: adım 1, 1 resimden 1.
      • Find the SIM tray located at the top of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Edge Screen Replacement, Eject the SIM tray: adım 2, 2 resimden 1. Motorola Edge Screen Replacement, Eject the SIM tray: adım 2, 2 resimden 2.
      • Insert a SIM eject tool or SIM eject bit into the small hole in the SIM card tray.
      • If the tool you're using doesn't fit, don't force it. Forcing a tool may cause it to get stuck or break inside the ejection port.
      • Press to eject the tray.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola Edge Screen Replacement, Remove the SIM card tray assembly: adım 3, 3 resimden 1. Motorola Edge Screen Replacement, Remove the SIM card tray assembly: adım 3, 3 resimden 2. Motorola Edge Screen Replacement, Remove the SIM card tray assembly: adım 3, 3 resimden 3.
      • Remove the SIM card tray from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Edge Screen Replacement, Heat the bottom edge: adım 4, 1 resimden 1.
      • Completely power off your phone before you begin.
      • Heat an iOpener, then apply it along the bottom edge of the back cover for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone because the display and internal battery are both susceptible to heat damage.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Edge Screen Replacement, Separate the bottom adhesive: adım 5, 3 resimden 1. Motorola Edge Screen Replacement, Separate the bottom adhesive: adım 5, 3 resimden 2. Motorola Edge Screen Replacement, Separate the bottom adhesive: adım 5, 3 resimden 3.
      • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
      • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
      • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
      • Insert an opening pick into the gap.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola Edge Screen Replacement, Slice the bottom adhesive: adım 6, 3 resimden 1. Motorola Edge Screen Replacement, Slice the bottom adhesive: adım 6, 3 resimden 2. Motorola Edge Screen Replacement, Slice the bottom adhesive: adım 6, 3 resimden 3.
      • Slide the pick back and forth along the bottom edge to slice through the adhesive.
      • Leave the pick in to prevent the adhesive from resealing.
      FixBot'a Sor
      Yorum Ekle
    4. Motorola Edge Screen Replacement, Heat the right edge: adım 7, 1 resimden 1.
      • Apply a heated iOpener to the back cover's right edge for two minutes.
      FixBot'a Sor
      Yorum Ekle
    5. Motorola Edge Screen Replacement, Separate the corner adhesive: adım 8, 3 resimden 1. Motorola Edge Screen Replacement, Separate the corner adhesive: adım 8, 3 resimden 2. Motorola Edge Screen Replacement, Separate the corner adhesive: adım 8, 3 resimden 3.
      • Rotate the opening pick around the bottom-right corner of the phone.
      FixBot'a Sor
      Yorum Ekle
    6. Motorola Edge Screen Replacement, Separate the right adhesive: adım 9, 3 resimden 1. Motorola Edge Screen Replacement, Separate the right adhesive: adım 9, 3 resimden 2. Motorola Edge Screen Replacement, Separate the right adhesive: adım 9, 3 resimden 3.
      • Insert a new opening pick into the gap you just created.
      • Slide the pick along the right edge of the phone to separate the adhesive.
      • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
      FixBot'a Sor
      Yorum Ekle
    7. Motorola Edge Screen Replacement, Remove the back cover: adım 10, 3 resimden 1. Motorola Edge Screen Replacement, Remove the back cover: adım 10, 3 resimden 2. Motorola Edge Screen Replacement, Remove the back cover: adım 10, 3 resimden 3.
      • Remove the back cover, taking care not to damage the components inside the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Edge Screen Replacement, Remove the motherboard's screws: adım 11, 1 resimden 1.
      • Use a T5 Torx screwdriver to remove the twelve 3.4 mm-long screws securing the motherboard cover.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Edge Screen Replacement, Remove the motherboard cover: adım 12, 3 resimden 1. Motorola Edge Screen Replacement, Remove the motherboard cover: adım 12, 3 resimden 2. Motorola Edge Screen Replacement, Remove the motherboard cover: adım 12, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Use a pair of blunt tweezers or your fingers to lift up and remove the motherboard cover.
      • The motherboard cover also contains the phone's flash.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Edge Screen Replacement, Disconnect the battery cable's press connector: adım 13, 2 resimden 1. Motorola Edge Screen Replacement, Disconnect the battery cable's press connector: adım 13, 2 resimden 2.
      • Use a spudger to pry up and disconnect the battery cable's press connector from the motherboard.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Edge Screen Replacement, Remove the daughterboard's t5 screws: adım 14, 2 resimden 1. Motorola Edge Screen Replacement, Remove the daughterboard's t5 screws: adım 14, 2 resimden 2.
      • Use a T5 Torx screwdriver to remove the nine 3.4 mm screws securing the daughterboard.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Edge Screen Replacement, Remove the daughterboard cover: adım 15, 3 resimden 1. Motorola Edge Screen Replacement, Remove the daughterboard cover: adım 15, 3 resimden 2. Motorola Edge Screen Replacement, Remove the daughterboard cover: adım 15, 3 resimden 3.
      • Use a spudger to pry up the plastic daughterboard cover and disconnect it from the rest of the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Edge Screen Replacement, Disconnect the interconnect cable from the daughterboard: adım 16, 2 resimden 1. Motorola Edge Screen Replacement, Disconnect the interconnect cable from the daughterboard: adım 16, 2 resimden 2.
      • Use a spudger to pry up and disconnect the interconnect cable's press connector from the daughterboard.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Edge Screen Replacement, Disconnect the interconnect cable from the motherboard: adım 17, 2 resimden 1. Motorola Edge Screen Replacement, Disconnect the interconnect cable from the motherboard: adım 17, 2 resimden 2.
      • Use a spudger to pry up and disconnect the interconnect cable's press connector from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Edge Screen Replacement, Remove the interconnect cable: adım 18, 2 resimden 1. Motorola Edge Screen Replacement, Remove the interconnect cable: adım 18, 2 resimden 2.
      • Use your fingers to remove the interconnect cable after it has been disconnected from both the motherboard and daughterboard.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Edge Screen Replacement, Disconnect the screen ribbon cable's press connector: adım 19, 2 resimden 1. Motorola Edge Screen Replacement, Disconnect the screen ribbon cable's press connector: adım 19, 2 resimden 2.
      • Use a spudger to pry up and disconnect the screen ribbon cable's press connector from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Edge Screen Replacement, Remove the copper tape: adım 20, 3 resimden 1. Motorola Edge Screen Replacement, Remove the copper tape: adım 20, 3 resimden 2. Motorola Edge Screen Replacement, Remove the copper tape: adım 20, 3 resimden 3.
      • Use a pair of blunt tweezers to peel up and remove the copper tape covering the front camera ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Edge Screen Replacement, Remove the front camera cable's press connector: adım 21, 3 resimden 1. Motorola Edge Screen Replacement, Remove the front camera cable's press connector: adım 21, 3 resimden 2. Motorola Edge Screen Replacement, Remove the front camera cable's press connector: adım 21, 3 resimden 3.
      • Use a spudger to pry up the front camera cable's press connector and disconnect it from the motherboard.
      • Remove the front camera.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Edge Screen Replacement, Remove the wide angle camera's press connector: adım 22, 3 resimden 1. Motorola Edge Screen Replacement, Remove the wide angle camera's press connector: adım 22, 3 resimden 2. Motorola Edge Screen Replacement, Remove the wide angle camera's press connector: adım 22, 3 resimden 3.
      • Use a spudger to pry up the wide angle camera cable's press connector and disconnect it from the motherboard.
      • Remove the wide angle camera.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Edge Screen Replacement, Remove the main camera cable's press connector: adım 23, 3 resimden 1. Motorola Edge Screen Replacement, Remove the main camera cable's press connector: adım 23, 3 resimden 2. Motorola Edge Screen Replacement, Remove the main camera cable's press connector: adım 23, 3 resimden 3.
      • Use a spudger to pry up the main camera cable's press connector and disconnect it from the motherboard.
      • Remove the main camera.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Edge Screen Replacement, Remove the telephoto camera's press connector: adım 24, 3 resimden 1. Motorola Edge Screen Replacement, Remove the telephoto camera's press connector: adım 24, 3 resimden 2. Motorola Edge Screen Replacement, Remove the telephoto camera's press connector: adım 24, 3 resimden 3.
      • Use a spudger to pry up and disconnect the telephoto camera cable's press connector from the motherboard.
      • Remove the telephoto camera.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Edge Screen Replacement, Disconnect the black coaxial cable: adım 25, 2 resimden 1. Motorola Edge Screen Replacement, Disconnect the black coaxial cable: adım 25, 2 resimden 2.
      • Use a spudger to pry up the black coaxial cable and detach it from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Edge Screen Replacement, Disconnect the white coaxial cable: adım 26, 2 resimden 1. Motorola Edge Screen Replacement, Disconnect the white coaxial cable: adım 26, 2 resimden 2.
      • Use a spudger to pry up the white coaxial cable and detach it from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola Edge Screen Replacement, Remove the motherboard: adım 27, 3 resimden 1. Motorola Edge Screen Replacement, Remove the motherboard: adım 27, 3 resimden 2. Motorola Edge Screen Replacement, Remove the motherboard: adım 27, 3 resimden 3.
      • Use a spudger to pry up and remove the motherboard.
      • Make sure no cables get trapped under the motherboard during reassembly.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Edge Screen Replacement, Weaken the earpiece speaker's adhesive: adım 28, 1 resimden 1.
      • Apply a drop or two of isopropyl alcohol to weaken the adhesive securing the earpiece speaker.
      • Wait thirty seconds for the isopropyl alcohol to weaken the adhesive.
      • The adhesive is located both under the ribbon cable and under the earpiece speaker.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Edge Screen Replacement, Disconnect the earpiece speaker cable: adım 29, 3 resimden 1. Motorola Edge Screen Replacement, Disconnect the earpiece speaker cable: adım 29, 3 resimden 2. Motorola Edge Screen Replacement, Disconnect the earpiece speaker cable: adım 29, 3 resimden 3.
      • Use an opening pick to disconnect the earpiece speaker cable from the midframe.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola Edge Screen Replacement, Remove the earpiece speaker: adım 30, 3 resimden 1. Motorola Edge Screen Replacement, Remove the earpiece speaker: adım 30, 3 resimden 2. Motorola Edge Screen Replacement, Remove the earpiece speaker: adım 30, 3 resimden 3.
      • Pry at the edge of the earpiece speaker with a spudger to detach it from the frame.
      • If there's any alcohol solution remaining in the phone, carefully wipe it off with a lint-free cloth or allow it to air dry before installing the earpiece speaker.
      • During reassembly, follow this guide if you are using a pre-cut adhesive card to reinstall the earpiece speaker.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Edge Screen Replacement, Disconnect the fingerprint sensor cable's press connector: adım 31, 2 resimden 1. Motorola Edge Screen Replacement, Disconnect the fingerprint sensor cable's press connector: adım 31, 2 resimden 2.
      • Use a spudger to pry up the fingerprint sensor cable's press connector and disconnect it from the daughterboard.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Edge Screen Replacement, Remove the daughterboard screw: adım 32, 2 resimden 1. Motorola Edge Screen Replacement, Remove the daughterboard screw: adım 32, 2 resimden 2.
      • Use a T5 Torx screwdriver to remove the single 3.2 mm screw securing the daughterboard.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola Edge Screen Replacement, Disconnect the black coaxial cable: adım 33, 2 resimden 1. Motorola Edge Screen Replacement, Disconnect the black coaxial cable: adım 33, 2 resimden 2.
      • Use a spudger to pry up the black coaxial cable and detach it from the daughterboard.
      FixBot'a Sor
      Yorum Ekle
    4. Motorola Edge Screen Replacement, Disconnect the white coaxial cable: adım 34, 2 resimden 1. Motorola Edge Screen Replacement, Disconnect the white coaxial cable: adım 34, 2 resimden 2.
      • Use a spudger to pry up the white coaxial cable and disconnect it from the daughterboard.
      FixBot'a Sor
      Yorum Ekle
    5. Motorola Edge Screen Replacement, Remove the daughterboard: adım 35, 3 resimden 1. Motorola Edge Screen Replacement, Remove the daughterboard: adım 35, 3 resimden 2. Motorola Edge Screen Replacement, Remove the daughterboard: adım 35, 3 resimden 3.
      • Use a spudger to pry up and separate the daughterboard from the rest of the phone.
      • When removing and replacing the daughterboard, be careful not to damage any of the cables that attach to it.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Edge Screen Replacement, Weaken the vibrator's adhesive: adım 36, 1 resimden 1.
      • Use a drop or two of isopropyl alcohol to weaken the adhesive attaching the vibrator to the phone's frame.
      • Wait thirty seconds for the isopropyl alcohol to weaken the adhesive under the vibrator.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Edge Screen Replacement, Detach the vibrator's ribbon cable: adım 37, 3 resimden 1. Motorola Edge Screen Replacement, Detach the vibrator's ribbon cable: adım 37, 3 resimden 2. Motorola Edge Screen Replacement, Detach the vibrator's ribbon cable: adım 37, 3 resimden 3.
      • Use an opening pick to carefully separate the vibrator's ribbon cable from the frame of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola Edge Screen Replacement, Remove the vibrator: adım 38, 3 resimden 1. Motorola Edge Screen Replacement, Remove the vibrator: adım 38, 3 resimden 2. Motorola Edge Screen Replacement, Remove the vibrator: adım 38, 3 resimden 3.
      • Use a spudger to carefully separate and remove the vibrator.
      • If there's any alcohol solution remaining in the phone, carefully wipe it off with a lint-free cloth or allow it to air dry before installing the vibrator.
      • During reassembly, follow this guide if you are using a pre-cut adhesive card to reinstall the vibrator.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Edge Screen Replacement, Wedge a spudger behind the microphone gasket: adım 39, 3 resimden 1. Motorola Edge Screen Replacement, Wedge a spudger behind the microphone gasket: adım 39, 3 resimden 2. Motorola Edge Screen Replacement, Wedge a spudger behind the microphone gasket: adım 39, 3 resimden 3.
      • Insert the pointed end of a spudger behind the red microphone gasket at the top of the midframe.
      • There is a small hole in the microphone gasket. You can gently place the spudger in the hole to help remove the gasket from the midframe.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Edge Screen Replacement, Remove the microphone gasket: adım 40, 1 resimden 1.
      • Use a spudger to dislodge and remove the red microphone gasket from the top of the midframe.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola Edge Screen Replacement, Wedge a spudger behind the microphone gasket: adım 41, 3 resimden 1. Motorola Edge Screen Replacement, Wedge a spudger behind the microphone gasket: adım 41, 3 resimden 2. Motorola Edge Screen Replacement, Wedge a spudger behind the microphone gasket: adım 41, 3 resimden 3.
      • Insert the pointed end of a spudger behind the red microphone gasket at the bottom of the midframe.
      FixBot'a Sor
      Yorum Ekle
    4. Motorola Edge Screen Replacement, Remove the microphone gasket: adım 42, 3 resimden 1. Motorola Edge Screen Replacement, Remove the microphone gasket: adım 42, 3 resimden 2. Motorola Edge Screen Replacement, Remove the microphone gasket: adım 42, 3 resimden 3.
      • Insert the pointed end of a spudger behind the microphone gasket at the bottom of the midframe.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Edge Screen Replacement, Weaken the battery's adhesive: adım 43, 1 resimden 1.
      • Heat an iOpener and place it on the screen for two minutes in order to loosen the adhesive on the battery.
      • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola Edge Screen Replacement, Create a gap between the battery and the frame: adım 44, 2 resimden 1. Motorola Edge Screen Replacement, Create a gap between the battery and the frame: adım 44, 2 resimden 2.
      • Wedge the pointed end of an opening pick between the right side of the battery and the midframe.
      • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
      • Be careful not to damage the screen's ribbon cable, which is located underneath the battery.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola Edge Screen Replacement, Switch to a plastic card: adım 45, 3 resimden 1. Motorola Edge Screen Replacement, Switch to a plastic card: adım 45, 3 resimden 2. Motorola Edge Screen Replacement, Switch to a plastic card: adım 45, 3 resimden 3.
      Plastic Cards
      $2.99
      • After making a gap between the battery and the frame, replace the opening pick with a plastic card.
      • A plastic card will help ensure that the battery is not bent or damaged while being removed.
      FixBot'a Sor
      Yorum Ekle
    4. Motorola Edge Screen Replacement, Cut through the battery's adhesive: adım 46, 3 resimden 1. Motorola Edge Screen Replacement, Cut through the battery's adhesive: adım 46, 3 resimden 2. Motorola Edge Screen Replacement, Cut through the battery's adhesive: adım 46, 3 resimden 3.
      • Carefully slide a plastic card underneath the battery to cut through the adhesive.
      FixBot'a Sor
      Yorum Ekle
    5. Motorola Edge Screen Replacement, Remove the battery: adım 47, 3 resimden 1. Motorola Edge Screen Replacement, Remove the battery: adım 47, 3 resimden 2. Motorola Edge Screen Replacement, Remove the battery: adım 47, 3 resimden 3.
      • Slide a plastic card under the battery, then carefully lift the battery up until the adhesive is loose enough to remove the battery.
      FixBot'a Sor
      Yorum Ekle
    6. Motorola Edge Screen Replacement: adım 48, 3 resimden 1. Motorola Edge Screen Replacement: adım 48, 3 resimden 2. Motorola Edge Screen Replacement: adım 48, 3 resimden 3.
      • Separate and remove the battery from the midframe.
      • If the battery is deformed, dented, or damaged in any way, don't reinstall it. Reinstalling a damaged battery is a potential safety hazard. Replace it with a new one.
      • During reassembly, follow this guide if you are using a pre-cut adhesive card to reinstall the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola Edge Screen Replacement, Replace the screen assembly: adım 49, 1 resimden 1.
      • The remainder of the components in the phone are included in the screen assembly. You can now re-assemble your device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
2 farklı kişi bu kılavuzu tamamladı.
Jennifer Berg
2.869 İtibar
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 64
Son 30 gün: 211
Her zaman: 11,554
