Giriş
Use this guide to remove or replace the screen on your Motorola Moto G7 Power.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
This procedure requires removing the glued in battery. Do not reuse the battery after it has been removed. Be sure to replace the old battery, as reusing it can create a potential safety hazard.
Some images may have visual discrepancies, such as the SIM card tray being removed from the phone. You don’t need to remove the SIM card tray for this procedure.
You’ll need some double-sided tape (such as Tesa tape) in order to adhere the replaced components.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Neye ihtiyacın var
Apply a heated iOpener or a heat gun to the bottom edge of the screen for approximately two minutes to help soften the adhesive.
Apply a suction cup to the rear cover, as close to the heated edge as possible.
Pull up on the suction cup with strong, steady force to create a gap.
Insert an opening pick into the gap you created under the rear cover.
Remove the rear cover, taking care not to damage the fingerprint sensor.
Insert the pointed end of a spudger into the divot at the top of the fingerprint sensor connector cover.
Gently pry the cover open.
Remove the cover.
Use a T5 Torx screwdriver to remove the ten screws securing the motherboard cover to the midframe:
Nine 3.5 mm screws
One 3.0 mm screw
Use the flat end of a spudger to pry up on the battery connector to disconnect it.
Apply 2-3 drops of high concentration (over 90%) isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
Insert an opening pick into the small gap between the battery and its compartment.
Remove the opening pick and insert it into the small gap on the other side of the battery. This will jiggle the battery around in its compartment, further weakening the adhesive under the battery.
Repeat the process until you can easily insert the pick into both gaps.
Insert a pick into the gap to the left of the battery and slide its tip underneath the battery.
Slide the pick along the left side of the battery to slice through the adhesive securing it to the midframe.
Once the left side of the battery begins to separate from the midframe, leave an opening pick in the gap to keep the battery slightly raised.
Apply four to five drops of isopropyl alcohol directly to the adhesive securing the battery to the midframe.
Remove the battery from the midframe.
Remove any remaining adhesive from the phone, and clean the entire area under the battery with isopropyl alcohol.
Apply a few new strips of pre-cut adhesive or Tesa tape.
Press the new battery firmly into place for 5-10 seconds.
Use a pair of tweezers to carefully peel back the black rubber tape securing the screen connector to the midframe.
Remove the screen from the midframe, taking care not to damage the screen connector cable as you pull it through the midframe cutout.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto G7 Power Answers community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
6 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I would like to change a motorola G7 power screen but I live in the Dominican Republic
