Ana içeriğe geç
Nintendo Switch Lite Right Joystick Replacement
    • Before beginning this repair, make sure that the device is completely turned off.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
  1. Nintendo Switch Lite Right Joystick Replacement, Remove the top and bottom back panel screws: adım 2, 2 resimden 1. Nintendo Switch Lite Right Joystick Replacement, Remove the top and bottom back panel screws: adım 2, 2 resimden 2.
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the back panel:
    • Two 3.6 mm-long screws on the top of the device
    • Two 3.6 mm-long screws on the bottom of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
  2. Nintendo Switch Lite Right Joystick Replacement, Release the clips securing the back panel: adım 3, 2 resimden 1. Nintendo Switch Lite Right Joystick Replacement, Release the clips securing the back panel: adım 3, 2 resimden 2.
    • Insert an opening tool into the left speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips securing the back panel.
    • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
  3. Nintendo Switch Lite Right Joystick Replacement, Continue releasing the clips around the device: adım 4, 2 resimden 1. Nintendo Switch Lite Right Joystick Replacement, Continue releasing the clips around the device: adım 4, 2 resimden 2.
    • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
  4. Nintendo Switch Lite Right Joystick Replacement, Twist to release the clips: adım 5, 2 resimden 1. Nintendo Switch Lite Right Joystick Replacement, Twist to release the clips: adım 5, 2 resimden 2.
    • Insert an opening tool into the right speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips.
  5. Nintendo Switch Lite Right Joystick Replacement, Slide and pry around the corners: adım 6, 2 resimden 1. Nintendo Switch Lite Right Joystick Replacement, Slide and pry around the corners: adım 6, 2 resimden 2.
    • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
  6. Nintendo Switch Lite Right Joystick Replacement: adım 7, 2 resimden 1. Nintendo Switch Lite Right Joystick Replacement: adım 7, 2 resimden 2.
    • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
  7. Nintendo Switch Lite Right Joystick Replacement, Remove the back panel: adım 8, 3 resimden 1. Nintendo Switch Lite Right Joystick Replacement, Remove the back panel: adım 8, 3 resimden 2. Nintendo Switch Lite Right Joystick Replacement, Remove the back panel: adım 8, 3 resimden 3.
    • Lift the bottom edge of the back panel, opening it like a book.
    • Remove the back panel.
  8. Nintendo Switch Lite Right Joystick Replacement, Remove the shield plate: adım 9, 1 resimden 1.
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following four screws:
    • Three 3.1 mm screws
    • One 4.5 mm screw
  9. Nintendo Switch Lite Right Joystick Replacement: adım 10, 3 resimden 1. Nintendo Switch Lite Right Joystick Replacement: adım 10, 3 resimden 2. Nintendo Switch Lite Right Joystick Replacement: adım 10, 3 resimden 3.
    • Use a spudger or your fingers to lift the shield plate up and out of the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • Clean off the old thermal paste from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the heat sink before reassembly.
  10. Nintendo Switch Lite Right Joystick Replacement, Disconnect the battery: adım 11, 2 resimden 1. Nintendo Switch Lite Right Joystick Replacement, Disconnect the battery: adım 11, 2 resimden 2.
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
  11. Nintendo Switch Lite Right Joystick Replacement: adım 12, 2 resimden 1. Nintendo Switch Lite Right Joystick Replacement: adım 12, 2 resimden 2.
    • Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard.
  12. Nintendo Switch Lite Right Joystick Replacement: adım 13, 2 resimden 1. Nintendo Switch Lite Right Joystick Replacement: adım 13, 2 resimden 2.
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
  13. Nintendo Switch Lite Right Joystick Replacement, Remove the heat sink: adım 14, 1 resimden 1.
    • Use the flat end of a spudger or your fingers to carefully peel up the foam that's lightly adhered to the fan.
    • The foam only needs to be peeled back enough to clear the fan.
  14. Nintendo Switch Lite Right Joystick Replacement: adım 15, 1 resimden 1.
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
  15. Nintendo Switch Lite Right Joystick Replacement: adım 16, 3 resimden 1. Nintendo Switch Lite Right Joystick Replacement: adım 16, 3 resimden 2. Nintendo Switch Lite Right Joystick Replacement: adım 16, 3 resimden 3.
    • Use a spudger or your fingers to lift the heatsink up and off of the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
  16. Nintendo Switch Lite Right Joystick Replacement, Remove the game card reader and headphone jack: adım 17, 2 resimden 1. Nintendo Switch Lite Right Joystick Replacement, Remove the game card reader and headphone jack: adım 17, 2 resimden 2.
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the game card reader cable's ZIF connector.
  17. Nintendo Switch Lite Right Joystick Replacement: adım 18, 1 resimden 1.
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the seven 3.1 mm screws securing the game card reader and headphone jack.
  18. Nintendo Switch Lite Right Joystick Replacement: adım 19, 3 resimden 1. Nintendo Switch Lite Right Joystick Replacement: adım 19, 3 resimden 2. Nintendo Switch Lite Right Joystick Replacement: adım 19, 3 resimden 3.
    • Use a pair of tweezers or your fingers to carefully lift the game card reader and maneuver it to the left to slide the cable out of its connector.
    • Remove the game card reader and headphone jack.
  19. Nintendo Switch Lite Right Joystick Replacement, Remove the right trigger button assembly: adım 20, 1 resimden 1.
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the two 4.5 mm screws securing the right trigger button assembly to the motherboard.
  20. Nintendo Switch Lite Right Joystick Replacement: adım 21, 2 resimden 1. Nintendo Switch Lite Right Joystick Replacement: adım 21, 2 resimden 2.
    • Remove the right trigger button assembly.
  21. Nintendo Switch Lite Right Joystick Replacement: adım 22, 2 resimden 1. Nintendo Switch Lite Right Joystick Replacement: adım 22, 2 resimden 2.
    • Use a pair of tweezers or your fingers to remove the right trigger button assembly's rubber pad if it didn't stay attached to the button assembly.
  22. Nintendo Switch Lite Right Joystick Replacement, Disconnect the antenna cables: adım 23, 3 resimden 1. Nintendo Switch Lite Right Joystick Replacement, Disconnect the antenna cables: adım 23, 3 resimden 2. Nintendo Switch Lite Right Joystick Replacement, Disconnect the antenna cables: adım 23, 3 resimden 3.
    • Use the point of a spudger to pry the black antenna cable straight up out of its socket on the motherboard.
    • Repeat the same process for the white antenna cable.
  23. Nintendo Switch Lite Right Joystick Replacement, Disconnect the fan cable: adım 24, 1 resimden 1.
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
  24. Nintendo Switch Lite Right Joystick Replacement: adım 25, 2 resimden 1. Nintendo Switch Lite Right Joystick Replacement: adım 25, 2 resimden 2.
    • Use a pair of tweezers to slide out the fan cable from its connector on the motherboard.
  25. Nintendo Switch Lite Right Joystick Replacement, Disconnect the screen cable: adım 26, 2 resimden 1. Nintendo Switch Lite Right Joystick Replacement, Disconnect the screen cable: adım 26, 2 resimden 2.
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the screen cable's ZIF connector.
  26. Nintendo Switch Lite Right Joystick Replacement: adım 27, 2 resimden 1. Nintendo Switch Lite Right Joystick Replacement: adım 27, 2 resimden 2.
    • Use a pair of tweezers to slide the screen cable out of its connector on the motherboard.
  27. Nintendo Switch Lite Right Joystick Replacement, Disconnect the digitizer cable: adım 28, 2 resimden 1. Nintendo Switch Lite Right Joystick Replacement, Disconnect the digitizer cable: adım 28, 2 resimden 2.
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
  28. Nintendo Switch Lite Right Joystick Replacement: adım 29, 2 resimden 1. Nintendo Switch Lite Right Joystick Replacement: adım 29, 2 resimden 2.
    • Use a pair of tweezers to slide the digitizer cable out of its connector on the motherboard.
  29. Nintendo Switch Lite Right Joystick Replacement, Disconnect the right joystick cable: adım 30, 2 resimden 1. Nintendo Switch Lite Right Joystick Replacement, Disconnect the right joystick cable: adım 30, 2 resimden 2.
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the right joystick cable's ZIF connector.
  30. Nintendo Switch Lite Right Joystick Replacement: adım 31, 2 resimden 1. Nintendo Switch Lite Right Joystick Replacement: adım 31, 2 resimden 2.
    • Use a pair of tweezers to slide the right joystick cable out of its connector on the motherboard.
  31. Nintendo Switch Lite Right Joystick Replacement, Remove the motherboard assembly: adım 32, 1 resimden 1.
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following six screws securing the motherboard:
    • Three 4.5 mm screws
  32. Nintendo Switch Lite Right Joystick Replacement: adım 33, 3 resimden 1. Nintendo Switch Lite Right Joystick Replacement: adım 33, 3 resimden 2. Nintendo Switch Lite Right Joystick Replacement: adım 33, 3 resimden 3.
    • Insert a spudger in the gap between the frame and the motherboard and lift the motherboard up and out of its recess.
    • Remove the motherboard assembly.
  33. Nintendo Switch Lite Right Joystick Replacement, Remove the right joystick: adım 34, 1 resimden 1.
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the two 3.5 mm screws securing the joystick.
  34. Nintendo Switch Lite Right Joystick Replacement: adım 35, 2 resimden 1. Nintendo Switch Lite Right Joystick Replacement: adım 35, 2 resimden 2.
    • Use your fingers to remove the joystick.
    • There is a thin black gasket around the hole where the joystick pokes through the frame. Try not to disturb this gasket as you remove the joystick.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
44 farklı kişi bu kılavuzu tamamladı.
Craig Lloyd
30.756 İtibar
82 adet Kılavuz yazıldı
18 Comments
Not for the faint of heart and will take much longer than the indicated time. In the end bring it to a professional, as the battery does NOT come off as indicated. I now have an even more expensive repair as the battery socket came off the motherboard.
Craig Osman - Yanıt
This looked a bit daunting at first, but as you start going you get into a flow and as long as you follow the instructions slowly and carefully you shouldnt have a problem. I would say i finished in the recommended time.
Dom Swooz - Yanıt
Great guide - completed with no issues easily within the recommended time.
Abelard Snazz - Yanıt
I did not need to take out the heat sink. It’s a bit difficult. I used this guide and another to replace both buttons.
henreeg - Yanıt
What did u do so u didn’t need to remove the heat sink? I really dknt want to remove it so I don’t disturb my thermal paste and I don’t want to replace it since I it’s kind of expensive and I dknt want to spend much money doing this repair
ermhs Gpro -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 99
Son 7 gün: 625
Son 30 gün: 3,015
Her zaman: 42,676
