Ana içeriğe geç
OnePlus Nord 2 5G Battery Replacement
Neye ihtiyacın var
  1. OnePlus Nord 2 5G Battery Replacement, Loosen the rear glass: adım 1, 1 resimden 1.
    • Prepare an iOpener and apply it to the rear glass for at least three minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. OnePlus Nord 2 5G Battery Replacement, Insert an iFlex: adım 2, 3 resimden 1. OnePlus Nord 2 5G Battery Replacement, Insert an iFlex: adım 2, 3 resimden 2. OnePlus Nord 2 5G Battery Replacement, Insert an iFlex: adım 2, 3 resimden 3.
    • Due to its surface, no suction tool will hold onto the phone's rear glass. A thin slicing tool is required to create a gap between the rear glass and the midframe.
    • Insert an iFlex into the seam between the rear glass and the midframe at the bottom edge of the phone to create a gap. This may require some force.
    • Leave the iFlex in place to prevent the adhesive from resealing.
  3. OnePlus Nord 2 5G Battery Replacement, Insert an opening pick: adım 3, 3 resimden 1. OnePlus Nord 2 5G Battery Replacement, Insert an opening pick: adım 3, 3 resimden 2. OnePlus Nord 2 5G Battery Replacement, Insert an opening pick: adım 3, 3 resimden 3.
    • Insert an opening pick into the gap you created with the iFlex.
    • Remove the iFlex.
  4. OnePlus Nord 2 5G Battery Replacement, Slice the bottom edge adhesive: adım 4, 2 resimden 1. OnePlus Nord 2 5G Battery Replacement, Slice the bottom edge adhesive: adım 4, 2 resimden 2.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  5. OnePlus Nord 2 5G Battery Replacement: adım 5, 2 resimden 1. OnePlus Nord 2 5G Battery Replacement: adım 5, 2 resimden 2.
    • Insert a second opening pick at the bottom right corner of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  6. OnePlus Nord 2 5G Battery Replacement, Slice the left edge adhesive: adım 6, 3 resimden 1. OnePlus Nord 2 5G Battery Replacement, Slice the left edge adhesive: adım 6, 3 resimden 2. OnePlus Nord 2 5G Battery Replacement, Slice the left edge adhesive: adım 6, 3 resimden 3.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  7. OnePlus Nord 2 5G Battery Replacement, Slice the top edge adhesive: adım 7, 2 resimden 1. OnePlus Nord 2 5G Battery Replacement, Slice the top edge adhesive: adım 7, 2 resimden 2.
    • Insert a fourth opening pick underneath the top left corner of the rear glass.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  8. OnePlus Nord 2 5G Battery Replacement, Slice the right edge adhesive: adım 8, 3 resimden 1. OnePlus Nord 2 5G Battery Replacement, Slice the right edge adhesive: adım 8, 3 resimden 2. OnePlus Nord 2 5G Battery Replacement, Slice the right edge adhesive: adım 8, 3 resimden 3.
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the back cover to slice the remaining adhesive.
  9. OnePlus Nord 2 5G Battery Replacement, Remove the back cover: adım 9, 2 resimden 1. OnePlus Nord 2 5G Battery Replacement, Remove the back cover: adım 9, 2 resimden 2.
    • Remove the back cover.
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  10. OnePlus Nord 2 5G Battery Replacement, Remove the connector bracket: adım 10, 2 resimden 1. OnePlus Nord 2 5G Battery Replacement, Remove the connector bracket: adım 10, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use a pair of tweezers to remove the metal bracket covering the flash assembly connector.
  11. OnePlus Nord 2 5G Battery Replacement, Disconnect the flash assembly: adım 11, 2 resimden 1. OnePlus Nord 2 5G Battery Replacement, Disconnect the flash assembly: adım 11, 2 resimden 2.
    • Use the point of a spudger to disconnect the flash assembly cable by prying the connector straight up from its socket.
  12. OnePlus Nord 2 5G Battery Replacement, Unfasten the motherboard cover: adım 12, 1 resimden 1.
    • Use a Phillips screwdriver to remove the nine 3.8 mm-long screws securing the motherboard cover.
  13. OnePlus Nord 2 5G Battery Replacement, Pry up the motherboard cover: adım 13, 3 resimden 1. OnePlus Nord 2 5G Battery Replacement, Pry up the motherboard cover: adım 13, 3 resimden 2. OnePlus Nord 2 5G Battery Replacement, Pry up the motherboard cover: adım 13, 3 resimden 3.
    • The motherboard cover is held in place by plastic clips.
    • Insert an opening pick underneath the bottom right edge of the motherboard cover.
    • Twist the opening pick sideways release the plastic clips and to pry up the motherboard cover.
  14. OnePlus Nord 2 5G Battery Replacement, Remove the motherboard cover: adım 14, 2 resimden 1. OnePlus Nord 2 5G Battery Replacement, Remove the motherboard cover: adım 14, 2 resimden 2.
    • Remove the motherboard cover.
  15. OnePlus Nord 2 5G Battery Replacement, Disconnect the battery cable: adım 15, 2 resimden 1. OnePlus Nord 2 5G Battery Replacement, Disconnect the battery cable: adım 15, 2 resimden 2.
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  16. OnePlus Nord 2 5G Battery Replacement, Unfasten the daughterboard cover: adım 16, 1 resimden 1.
    • Removing the daughterboard cover isn't mandatory to replace the battery. However, doing so reduces the risk of damaging surrounding components.
    • Use a Phillips screwdriver to remove the six 3.8 mm-long screws securing the daugtherboard cover.
  17. OnePlus Nord 2 5G Battery Replacement, Pry up the daughterboard cover: adım 17, 2 resimden 1. OnePlus Nord 2 5G Battery Replacement, Pry up the daughterboard cover: adım 17, 2 resimden 2.
    • Insert the point of a spudger underneath the top right edge of the daughterboard cover.
    • Pry upwards to loosen the daughterboard cover.
    • Don't try to remove the daughterboard cover all the way yet. It's still adhered to the loudspeaker.
  18. OnePlus Nord 2 5G Battery Replacement, Remove the daughterboard cover: adım 18, 3 resimden 1. OnePlus Nord 2 5G Battery Replacement, Remove the daughterboard cover: adım 18, 3 resimden 2. OnePlus Nord 2 5G Battery Replacement, Remove the daughterboard cover: adım 18, 3 resimden 3.
    • Fold the daughterboard cover to the left like you would open the front cover of a book.
    • Carefully peel the black tape off of the loudspeaker.
    • Remove the daughterboard cover.
  19. OnePlus Nord 2 5G Battery Replacement, Peel up the right pull tab: adım 19, 2 resimden 1. OnePlus Nord 2 5G Battery Replacement, Peel up the right pull tab: adım 19, 2 resimden 2.
    Satın Al
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Use a pair of blunt nose tweezers or your fingers to peel the right pull tab off the battery.
  20. OnePlus Nord 2 5G Battery Replacement, Lift the right half of the battery: adım 20, 2 resimden 1. OnePlus Nord 2 5G Battery Replacement, Lift the right half of the battery: adım 20, 2 resimden 2.
    • Grab and lift the right pull-tab to remove the first half of the battery from its recess.
    • Don't try to remove the battery all the way yet. The left half is still adhered to the midframe.
    • If you're having trouble lifting the battery out of its recess, apply a heated iOpener to the screen for two minutes to loosen the battery adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    • Only apply heat to the screen to prevent the battery from overheating.
  21. OnePlus Nord 2 5G Battery Replacement, Peel up the left pull tab: adım 21, 2 resimden 1. OnePlus Nord 2 5G Battery Replacement, Peel up the left pull tab: adım 21, 2 resimden 2.
    • Use a pair of blunt nose tweezers or your fingers to peel the left pull tab off the battery.
  22. OnePlus Nord 2 5G Battery Replacement, Lift the left half of the battery: adım 22, 2 resimden 1. OnePlus Nord 2 5G Battery Replacement, Lift the left half of the battery: adım 22, 2 resimden 2.
    • Grab and lift the left pull-tab to remove the second half of the battery from its recess.
  23. OnePlus Nord 2 5G Battery Replacement, Remove the battery: adım 23, 3 resimden 1. OnePlus Nord 2 5G Battery Replacement, Remove the battery: adım 23, 3 resimden 2. OnePlus Nord 2 5G Battery Replacement, Remove the battery: adım 23, 3 resimden 3.
    • Peel the battery from any remaining adhesive and remove it.
    • Don't reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
    • During reassembly, temporarily reconnect the battery to the motherboard before you press it into place to ensure correct alignment. Disconnect the battery after it's seated.
Sonuç
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our OnePlus Nord 2 5G answers community for help.
3 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
205.169 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.430 adet Kılavuz yazıldı
Bir Yorum
Hi. Please tell me, what is the name of the original battery for the nord2 model? Which battery should I change to?
Peter - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 101
Son 30 gün: 479
Her zaman: 5,163
