Ana içeriğe geç
Razer Kishi Trigger Replacement
Neye ihtiyacın var
  1. Razer Kishi Trigger Replacement, Remove the screws: adım 1, 1 resimden 1.
    • The opening process is the same on both sides. For simplicity, this guide shows only the right-side opening process. Unscrew whichever side you wish to open and work on.
    • For the right side, remove the five Y0 screws securing the right side of the controller.
    • Four 9.2 mm screws
    • One 7.2 mm screw
    • If you wish to open the left side, remove the five Y0 screws securing the left side of the controller.
    • One 7.2 mm screw
  2. Razer Kishi Trigger Replacement, Release the bottom edge clips: adım 2, 3 resimden 1. Razer Kishi Trigger Replacement, Release the bottom edge clips: adım 2, 3 resimden 2. Razer Kishi Trigger Replacement, Release the bottom edge clips: adım 2, 3 resimden 3.
    • Both cases are held together by plastic clips.
    • Insert an opening pick in the seam between the top and bottom case, at the bottom left corner of the controller.
    • With the pick still in the seam, slide it along the bottom edge to the bottom right corner to loosen the plastic clips.
  3. Razer Kishi Trigger Replacement, Release the side edge clips: adım 3, 2 resimden 1. Razer Kishi Trigger Replacement, Release the side edge clips: adım 3, 2 resimden 2.
    • Slide the opening pick along the right edge to loosen the plastic clips.
  4. Razer Kishi Trigger Replacement, Release the top edge clips: adım 4, 2 resimden 1. Razer Kishi Trigger Replacement, Release the top edge clips: adım 4, 2 resimden 2.
    • Slide the opening pick along the top edge to loosen the remaining plastic clips.
    • Don't try to remove the top side yet, the case is still connected to the board.
  5. Razer Kishi Trigger Replacement: adım 5, 3 resimden 1. Razer Kishi Trigger Replacement: adım 5, 3 resimden 2. Razer Kishi Trigger Replacement: adım 5, 3 resimden 3.
    • Carefully lift the top side and unfold it to the right, like a book.
  6. Razer Kishi Trigger Replacement, Disconnect the interconnect cable: adım 6, 3 resimden 1. Razer Kishi Trigger Replacement, Disconnect the interconnect cable: adım 6, 3 resimden 2. Razer Kishi Trigger Replacement, Disconnect the interconnect cable: adım 6, 3 resimden 3.
    • Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
    • Pull the cable out of the socket.
  7. Razer Kishi Trigger Replacement, Remove the screws: adım 7, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the two 4.4 mm-long screws securing the trigger board.
  8. Razer Kishi Trigger Replacement, Remove the breakout board: adım 8, 3 resimden 1. Razer Kishi Trigger Replacement, Remove the breakout board: adım 8, 3 resimden 2. Razer Kishi Trigger Replacement, Remove the breakout board: adım 8, 3 resimden 3.
    • The breakout board is plugged in. When removing breakout board, it is important to pull it straight out to avoid bending the connectors.
    • Remove the breakout board by lifting it straight up, away from the controller.
  9. Razer Kishi Trigger Replacement, Remove the screws: adım 9, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the two 7.0 mm-long screws securing the trigger.
  10. Razer Kishi Trigger Replacement, Remove the trigger: adım 10, 2 resimden 1. Razer Kishi Trigger Replacement, Remove the trigger: adım 10, 2 resimden 2.
    • Remove the shoulder trigger.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Adriana Zwink
56.077 İtibar
167 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.416 adet Kılavuz yazıldı
6 Yorum
Thankyou so much my trigger slipped out and this was extremely helpfull ??
Julian Nicholes - Yanıt
Hola donde puedo conseguir las partes de repuesto?
WALTER GUERRA -
THANK YOU VERY MUCH! My R2 trigger got removed and its hinge is cracked, just super glued it but I have no idea how to fix it. Thanks to this guide, I returned it easy with no damages. (Took 15 minutes on a newbie like me)
RaceRider102 - Yanıt
Excelente.... ¡ Y donde consigo el repuesto?
WALTER GUERRA -
During reassembly, when snapping the outer shell together test the R2 button. If it won't move it's likely because the tab on the end got pushed to the outside of the case. Pop it back open and push the R2 button in as you snap it back together in that area.
JM Palacios - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 4,065
