Ana içeriğe geç
Razer Kishi Trigger Replacement
Adriana Zwink
Adriana Zwink ve 2 diğer katkıda bulunanlar
En son October 23, 2024 tarihinde güncellendi
10 - 20 dakika
Orta
Use this guide to replace the trigger on your Razer Kishi.
Both controller sides of the Razer Kishi are almost identical in construction. The process of replacing the triggers are almost identical on both sides, so in this guide we only show the right side.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Razer Kishi Trigger Replacement, Remove the screws: adım 1, 1 resimden 1.
    • The opening process is the same on both sides. For simplicity, this guide shows only the right-side opening process. Unscrew whichever side you wish to open and work on.
    • For the right side, remove the five Y0 screws securing the right side of the controller.
    • Four 9.2 mm screws
    • One 7.2 mm screw
    • If you wish to open the left side, remove the five Y0 screws securing the left side of the controller.
    • One 7.2 mm screw
  2. Razer Kishi Trigger Replacement, Release the bottom edge clips: adım 2, 3 resimden 1. Razer Kishi Trigger Replacement, Release the bottom edge clips: adım 2, 3 resimden 2. Razer Kishi Trigger Replacement, Release the bottom edge clips: adım 2, 3 resimden 3.
    • Both cases are held together by plastic clips.
    • Insert an opening pick in the seam between the top and bottom case, at the bottom left corner of the controller.
    • With the pick still in the seam, slide it along the bottom edge to the bottom right corner to loosen the plastic clips.
  3. Razer Kishi Trigger Replacement, Release the side edge clips: adım 3, 2 resimden 1. Razer Kishi Trigger Replacement, Release the side edge clips: adım 3, 2 resimden 2.
    • Slide the opening pick along the right edge to loosen the plastic clips.
  4. Razer Kishi Trigger Replacement, Release the top edge clips: adım 4, 2 resimden 1. Razer Kishi Trigger Replacement, Release the top edge clips: adım 4, 2 resimden 2.
    • Slide the opening pick along the top edge to loosen the remaining plastic clips.
    • Don't try to remove the top side yet, the case is still connected to the board.
  5. Razer Kishi Trigger Replacement: adım 5, 3 resimden 1. Razer Kishi Trigger Replacement: adım 5, 3 resimden 2. Razer Kishi Trigger Replacement: adım 5, 3 resimden 3.
    • Carefully lift the top side and unfold it to the right, like a book.
  6. Razer Kishi Trigger Replacement, Disconnect the interconnect cable: adım 6, 3 resimden 1. Razer Kishi Trigger Replacement, Disconnect the interconnect cable: adım 6, 3 resimden 2. Razer Kishi Trigger Replacement, Disconnect the interconnect cable: adım 6, 3 resimden 3.
    • Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
    • Pull the cable out of the socket.
  7. Razer Kishi Trigger Replacement, Remove the screws: adım 7, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the two 4.4 mm-long screws securing the trigger board.
    Phillips #00 on mine.
    Model no. RZ06-0290
    also listed: GV190
    Stephen Marshall - Yanıt
    This step is not essential and risks misaligning the rotary knobs from their tracks as well as losing or contaminating the lubricant. You can leave the breakout board attached to the trigger and remove them together. When the trigger screws are out, lift the whole assembly together, being very careful to lift it straight out to avoid bending the jumper pins.
  8. Razer Kishi Trigger Replacement, Remove the breakout board: adım 8, 3 resimden 1. Razer Kishi Trigger Replacement, Remove the breakout board: adım 8, 3 resimden 2. Razer Kishi Trigger Replacement, Remove the breakout board: adım 8, 3 resimden 3.
    • The breakout board is plugged in. When removing breakout board, it is important to pull it straight out to avoid bending the connectors.
    • Remove the breakout board by lifting it straight up, away from the controller.
    When reassembling this piece, ensure that the breakout board's rotating peg is aligned with the neutral position of the joystick. To do this on the left trigger:
    1. Flip the breakout board over so that the rotating peg is facing you and position it such that the 3 jumper pins are in the top right (and the text is right-side-up.
    2. Carefully rotate the peg until it faces North-East, at just about a 45 degree angle from the horizontal. Move it in whatever direction requires the shortest travel to arrive at this point. Be wary of the lubricant which coats this part and try not to remove much.
    On the right trigger, this process is the same but mirrored. Align with pins in top left and point peg to the North-West at 45 degrees.
    Do you sell R2 button, mine is broken. If so kindly WhatsApp my number 0717709004
    IAN KELLY OTIENO - Yanıt
  9. Razer Kishi Trigger Replacement, Remove the screws: adım 9, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the two 7.0 mm-long screws securing the trigger.
    These are #00 screws on mine
    JM Palacios - Yanıt
    These screws have a very shallow angle for the inner Phillips drive, making them feel very easy to strip. For these, a Phillips #1 actually provided the most positive fit. Test a few tips just to be sure.
  10. Razer Kishi Trigger Replacement, Remove the trigger: adım 10, 2 resimden 1. Razer Kishi Trigger Replacement, Remove the trigger: adım 10, 2 resimden 2.
    • Remove the shoulder trigger.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Adriana Zwink
56.089 İtibar
167 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.418 adet Kılavuz yazıldı
6 Yorum
Thankyou so much my trigger slipped out and this was extremely helpfull ??
Julian Nicholes - Yanıt
Hola donde puedo conseguir las partes de repuesto?
WALTER GUERRA -
THANK YOU VERY MUCH! My R2 trigger got removed and its hinge is cracked, just super glued it but I have no idea how to fix it. Thanks to this guide, I returned it easy with no damages. (Took 15 minutes on a newbie like me)
RaceRider102 - Yanıt
Excelente.... ¡ Y donde consigo el repuesto?
WALTER GUERRA -
During reassembly, when snapping the outer shell together test the R2 button. If it won't move it's likely because the tab on the end got pushed to the outside of the case. Pop it back open and push the R2 button in as you snap it back together in that area.
JM Palacios - Yanıt
Where can I get R2 replacement buttons?
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 4,068
