Ana içeriğe geç
Roku 4 Motherboard Replacement
Bradley Rains
Bradley Rains ve 5 diğer katkıda bulunanlar
En son May 31, 2018 tarihinde güncellendi
20 dakika
Zor
Öne Çıkan Öğrenci Kılavuzu
The motherboard is a piece of circuitry that serves as the device's circuit board. The primary internal parts of the Roku 4 are all attached to the motherboard. This disassembly guide will serve as the core to further internal disassembly, as you will be able to fix other parts from here.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Roku 4 Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Place the Roku 4 face-down on a table. The rubber sticker should be facing you.
  2. Roku 4 Motherboard Replacement: adım 2, 1 resimden 1.
    • Starting at one corner of the device, pull the rubber sticker back toward the opposite corner of the device carefully to reveal the underlying screws.
    • Completely remove the rubber sticker to reveal the underlying screws on the device.
    • Place the rubber sticker facing up on the table to preserve its adhesiveness. It will be needed to reassemble the device.
  3. Roku 4 Motherboard Replacement: adım 3, 1 resimden 1.
    • Turn the Phillips PH1 screwdriver counterclockwise to unscrew all 4 of the 12.0 mm screws.
    • Store the screws in a safe place, such as on a magnetic project mat, so they do not get lost before reassembly.
  4. Roku 4 Motherboard Replacement: adım 4, 2 resimden 1. Roku 4 Motherboard Replacement: adım 4, 2 resimden 2.
    • Turn the device over so you can see the "4" on the top cover.
  5. Roku 4 Motherboard Replacement: adım 5, 2 resimden 1. Roku 4 Motherboard Replacement: adım 5, 2 resimden 2.
    • Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device and create a gap.
    • Prying open the device is quite difficult and requires a large amount of force. Use caution to avoid breaking the device or hurting yourself.
  6. Roku 4 Motherboard Replacement: adım 6, 1 resimden 1.
    • After you have created a gap large enough to fit your fingers between, gently lift up the top cover to open the device and reveal the motherboard.
    • The motherboard should still be attached to the underside of the top cover by a red wire, a blue wire, and a black wire.
  7. Roku 4 Motherboard Replacement: adım 7, 3 resimden 1. Roku 4 Motherboard Replacement: adım 7, 3 resimden 2. Roku 4 Motherboard Replacement: adım 7, 3 resimden 3.
    • To begin removing the motherboard from the plastic casing, pinch the black plastic clip and gently pull upward.
    • Once you feel the motherboard begin to loosen from the plastic casing, pull it upward to remove it completely.
  8. Roku 4 Motherboard Replacement: adım 8, 3 resimden 1. Roku 4 Motherboard Replacement: adım 8, 3 resimden 2. Roku 4 Motherboard Replacement: adım 8, 3 resimden 3.
    • Peel back the black adhesive strip that attaches the blue wire to the motherboard.
    • Repeat this step for the strip that attaches the black and red wires to the motherboard.
  9. Roku 4 Motherboard Replacement: adım 9, 3 resimden 1. Roku 4 Motherboard Replacement: adım 9, 3 resimden 2. Roku 4 Motherboard Replacement: adım 9, 3 resimden 3.
    • Using a soldering iron, desolder the blue, red, and black wires from the motherboard.
    • Consult iFixit's Soldering Skills guide to safely use the soldering iron.
    • The motherboard should now be completely disconnected from the top cover of the device.
Sonuç
Follow these steps in the reverse order to reassemble your device.
7 farklı kişi bu kılavuzu tamamladı.
Bradley Rains
163 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team S5-G4, Williams Spring 2017 Baylor, Team S5-G4, Williams Spring 2017 üyesi
BU-WILLIAMS-S17S5G4
3 Üyeler
4 adet Kılavuz yazıldı
4 Yorum
Thank you, have you upgraded to a new 2019 Ultra model yet?
Allan Landwer - Yanıt
Soldering the fan to the mobo is a suck move. However, they used a good quality bearing-less fan.
smbrannon - Yanıt
Can you gve me areson? will it suck out the perfomance?
Kind-hearted, spirited Man -
Because it makes replacing the motherboard more difficult. For a few cents more, they could have placed a small connector inline between the fan and motherboard, making disconnecting the fan and top case really easy.
Bob Reed - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 19
Son 30 gün: 38
Her zaman: 5,661
