Giriş
Follow this guide to replace the screen assembly for the Samsung Galaxy S20. The display glass, OLED panel, and digitizer comprise the screen assembly and will need to be replaced together.
Note: Some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires you to transplant all of your phone's internals and install a new battery. Make sure you have the correct part before starting this guide.
There is a significant chance that you may break the unreinforced and fragile display panel during this procedure. If you plan on reusing the screen assembly, be sure to apply plenty of heat and be extremely careful during the prying stage.
You'll need replacement adhesive in order to complete this repair.
Neye ihtiyacın var
Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
Insert the point of an opening pick into the gap.
Apply a heated iOpener to the left edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
Apply a heated iOpener to the right edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
Apply a heated iOpener to the top edge of the back cover for two minutes.
Gradually slide the pick from the right edge of the device around the top right corner.
Continue slicing along the top edge all the way to the top left corner to fully separate the back cover adhesive.
Bu adımda kullanılan alet:Tweezers$4.99
Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
Remove the back cover.
This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
If you're using custom-cut adhesives, follow this guide.
If you're using double-sided tape, follow this guide.
Bu adımda kullanılan alet:Magnetic Project Mat$19.95
Use a Phillips #00 screwdriver to remove the five 4 mm-long screws securing the motherboard bracket.
Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the plastic midframe.
Gently peel the wireless charging coil away from the device.
Remove the wireless charging coil.
Use a spudger to pry up and disconnect the battery connector.
Use a Phillips #00 screwdriver to remove the five 4 mm-long screws securing the loudspeaker and lower midframe.
Insert the point of a spudger or a pair of tweezers into the notch in the top left corner of the midframe and pry up to release the clips holding it in place.
Remove the loudspeaker and lower midframe.
Use a spudger to pry up and disconnect the display cable.
The adhesive surrounding the long edges of the device is thin and will only require you to insert the pick 5 mm to separate.
Note that along the top edge of the phone, the adhesive runs significantly farther from the device's edge. You will need to insert your pick deeper here to fully seperate the adhesive.
Heat an iOpener and apply it to the top edge of the display for two minutes.
Apply a suction cup to the display glass, as close to the center of the top edge as possible.
Pull on the suction cup with strong, steady force to create a gap between the display glass and the frame.
Insert the point of an opening pick into the gap in the center of the earpiece speaker notch, working it downwards underneath the display.
Leave your pick in the seam to prevent the adhesive from reasealing.
Apply high concentration (over 90%) isopropyl alcohol behind the display as close to the clear adhesive (marked red) as possible.
Tilt the device as you apply the alcohol to help it penetrate the adhesive underneath the lower portion of the display.
After you apply the alcohol, continue tilting the bottom of the phone down for two to three minutes to help the alcohol penetrate further.
Use tweezers to remove any remaining adhesive from the frame.
Use isopropyl alcohol and a lint-free cloth to thoroughly clean the frame's surface and prepare it for new adhesive. Wipe in one direction to avoid smearing.
After you've completed the repair, follow this guide to test your repair.
Repair didn’t go as planned? Check out our Answers community or review our S20 black screen and S20 touchscreen unresponsive wikis for troubleshooting help.
38 farklı kişi bu kılavuzu tamamladı.
7Kılavuz Yorumları
Is there no connector for the loudspeaker? Just reviewing the guide before I do a repair but I do not see anything or any connector for the loudspeaker.
Bonjour ou trouver cet écran svp je ne le trouve pas sur le site merci
I see you remove the old adhesive. Is there new adhesive strip in the "new screen" pack for when you put the phone back together again?
Where can i buy the parts needed?
Hi Rick Moore, We do offer the replacement part in our store—check it out here: Samsung Galaxy S20 Screen. Unfortunately, the Fix Kit (which includes both the part and all the necessary tools and adhesives) is currently out of stock. We’re working hard to restock it as soon as possible!
