Ana içeriğe geç
Samsung Galaxy Watch4 Battery Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Watch4 Battery Replacement, Power down your Galaxy Watch4: adım 1, 1 resimden 1.
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. Samsung Galaxy Watch4 Battery Replacement, Unscrew the back cover: adım 2, 1 resimden 1.
    • Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws.
  3. Samsung Galaxy Watch4 Battery Replacement, Wedge open the back cover: adım 3, 2 resimden 1. Samsung Galaxy Watch4 Battery Replacement, Wedge open the back cover: adım 3, 2 resimden 2.
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
  4. Samsung Galaxy Watch4 Battery Replacement, Disconnect the sensor flex cable: adım 4, 2 resimden 1. Samsung Galaxy Watch4 Battery Replacement, Disconnect the sensor flex cable: adım 4, 2 resimden 2.
    • Lay the watch face down.
    • Carefully swing open the back cover by folding the back cover to the opposite site of the created gap.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  5. Samsung Galaxy Watch4 Battery Replacement, Remove the back cover: adım 5, 1 resimden 1.
    • Remove the back cover.
    • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
  6. Samsung Galaxy Watch4 Battery Replacement, Unscrew the motherboard: adım 6, 1 resimden 1.
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw securing the motherboard.
  7. Samsung Galaxy Watch4 Battery Replacement, Disconnect the display flex cable: adım 7, 2 resimden 1. Samsung Galaxy Watch4 Battery Replacement, Disconnect the display flex cable: adım 7, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the display flex cable.
  8. Samsung Galaxy Watch4 Battery Replacement, Disconnect the side buttons: adım 8, 2 resimden 1. Samsung Galaxy Watch4 Battery Replacement, Disconnect the side buttons: adım 8, 2 resimden 2.
    • Use a spudger to disconnect the flex cable of the crown buttons.
  9. Samsung Galaxy Watch4 Battery Replacement, Remove the motherboard: adım 9, 2 resimden 1. Samsung Galaxy Watch4 Battery Replacement, Remove the motherboard: adım 9, 2 resimden 2.
    • Use your fingers to lift the motherboard out from the watch assembly towards the bottom of the watch.
  10. Samsung Galaxy Watch4 Battery Replacement, Lever up the battery: adım 10, 2 resimden 1. Samsung Galaxy Watch4 Battery Replacement, Lever up the battery: adım 10, 2 resimden 2.
    • Place the tip of an opening pick in the small gap between the plastic frame and the battery, opposite to the display cable.
    • Carefully lever the battery up and out of its recess.
    • Don't try to remove the battery completely yet, as its connector is still adhered to the core assembly.
  11. Samsung Galaxy Watch4 Battery Replacement, Release the battery connector: adım 11, 2 resimden 1. Samsung Galaxy Watch4 Battery Replacement, Release the battery connector: adım 11, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Lift the battery up a little in order to access its glued down connector cable.
    • Use a pair of blunt tweezers to lift up the battery connector which is secured with some light adhesive.
    • You will most likely be able to re-use the adhesive to fix the new battery in place. If not replace it with double sided or pre-cut adhesive tape.
  12. Samsung Galaxy Watch4 Battery Replacement, Remove the battery: adım 12, 1 resimden 1.
    • Remove the battery.
Sonuç
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
43 farklı kişi bu kılavuzu tamamladı.
Adriana Zwink
56.777 İtibar
167 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.649 adet Kılavuz yazıldı
13Kılavuz Yorumları
Will this same battery work for the 42mm Galaxy Watch 4 Classic? Or will I need to keep searching for a replacement for that model?
geeowens - Yanıt
No! The batteries are completely different sizes.
David C -
Guide worked very well for me on the Watch4 (not classic). My battery adhesive came off during the replacement, so it was good to have gotten the adhesive card just in case.
My only note is that the Y000 Tri-point was tool small for the 2nd step. I used the Y00 Tri-point and it worked perfectly. The battery did take some effort to get out. I also used the flat edge of the plastic spudger to help lever up the corner to slide the pick in better.
Chris - Yanıt
is it still water resistant
Victor Rhebok - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 83
Son 7 gün: 606
Son 30 gün: 3,179
Her zaman: 87,155
