Ana içeriğe geç
SteelSeries Nimbus+ Controller Battery Replacement
Neye ihtiyacın var
  1. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the phone mount: adım 1, 2 resimden 1. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the phone mount: adım 1, 2 resimden 2.
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
    FixBot'a Sor
    Yorum Ekle
  2. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the sticker: adım 2, 1 resimden 1.
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
    FixBot'a Sor
    Yorum Ekle
  3. SteelSeries Nimbus+ Controller Battery  Replacement, Unscrew the back cover: adım 3, 1 resimden 1.
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
    FixBot'a Sor
    Yorum Ekle
  4. SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: adım 4, 2 resimden 1. SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: adım 4, 2 resimden 2.
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
    FixBot'a Sor
    Yorum Ekle
  5. SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: adım 5, 2 resimden 1. SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: adım 5, 2 resimden 2.
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
    FixBot'a Sor
    Yorum Ekle
  6. SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: adım 6, 2 resimden 1. SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: adım 6, 2 resimden 2.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
    FixBot'a Sor
    Yorum Ekle
  7. SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: adım 7, 2 resimden 1. SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: adım 7, 2 resimden 2.
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
    FixBot'a Sor
    Yorum Ekle
  8. SteelSeries Nimbus+ Controller Battery  Replacement, Unfold the back cover assembly: adım 8, 3 resimden 1. SteelSeries Nimbus+ Controller Battery  Replacement, Unfold the back cover assembly: adım 8, 3 resimden 2. SteelSeries Nimbus+ Controller Battery  Replacement, Unfold the back cover assembly: adım 8, 3 resimden 3.
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
    FixBot'a Sor
    Yorum Ekle
  9. SteelSeries Nimbus+ Controller Battery  Replacement, Disconnect the battery cable: adım 9, 3 resimden 1. SteelSeries Nimbus+ Controller Battery  Replacement, Disconnect the battery cable: adım 9, 3 resimden 2. SteelSeries Nimbus+ Controller Battery  Replacement, Disconnect the battery cable: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
    FixBot'a Sor
    Yorum Ekle
  10. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the back cover assembly: adım 10, 1 resimden 1.
    • Remove the back cover assembly.
    FixBot'a Sor
    Yorum Ekle
  11. SteelSeries Nimbus+ Controller Battery  Replacement, Pry up the battery: adım 11, 2 resimden 1. SteelSeries Nimbus+ Controller Battery  Replacement, Pry up the battery: adım 11, 2 resimden 2.
    • The battery is held in place by mild adhesive.
    • Insert the edge of an opening pick into the gap between the battery and the back cover assembly.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Use the opening pick to carefully pry up the battery and loosen the adhesive.
    FixBot'a Sor
    Yorum Ekle
  12. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the battery: adım 12, 1 resimden 1.
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Make sure to align the battery and the back cover of the controller correctly during reassembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
For optimal performance, calibrate your newly installed battery after completing this guide.
Bir başkası bu kılavuzu tamamladı.
Adriana Zwink
67.401 İtibar
167 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
26.514 adet Kılavuz yazıldı
1Rehber Yorum
Useless directions. The battery has 3 connectors. What is the mode? Where can you buy it? Polarity? If you have one with the right voltage and amps; but has two connectors what's do you do?
All this so-called repair guide says is: "This is how you open the case". Fantastic and then what???
Baldy - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 50
Her zaman: 2,291
