Giriş
Use this guide to remove or replace the battery on your Xiaomi Redmi Note 8.
If your battery is swollen, take appropriate precautions.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You’ll need replacement adhesive to reattach components when reassembling the device.
Neye ihtiyacın var
Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick to the bottom right corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a second opening pick at the bottom edge of your phone.
Slide the opening pick to the bottom left corner to slice the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom left corner of your phone.
Slide the opening pick along the left edge of your phone to slice the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Carefully fold the rear glass to the right side of the phone assembly like you'd open the back cover of a book.
Use a spudger to disconnect the fingerprint reader by prying the connector straight up from its socket.
Remove the rear glass assembly.
Use screwdriver to remove the eleven screws securing the motherboard cover:
Ten 3.9 mm-long Phillips screws
One 3.4 mm-long Phillips screw
Insert the tip of an opening pick underneath the bottom left edge of the motherboard cover.
Slide the opening pick along the left edge of the motherboard cover to unhinge the plastic clips and pry it up.
Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Use a spudger to disconnect the interconnect flex cable by prying the connector straight up from its socket.
Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
Fold the display flex cable towards the charging port in order to get free access to the battery.
Repeat the previous step and fold the interconnect flex cable in direction of the charging port.
Grab the right pull-tab with a pair of tweezers or your fingers and slowly pull it away from the battery and towards the bottom edge of your phone.
Pull hard enough to maintain tension on the strip, but don't force it. Give it plenty of time to stretch and un-stick from under the battery.
Don't press down on the battery. Hold the Redmi firmly by its sides.
Keep the strip flat and unwrinkled. Try to pull evenly on the whole strip, rather than pulling mainly in the middle or on one side.
Pull at a low angle so the strip doesn't snag on the edge of the battery.
If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
Bu adımda kullanılan alet:Plastic Cards$2.99
Repeat the previous pull-tab removal procedure on the second pull-tab.
Follow the same procedure as with the previous strip: don't press down on the battery, keep the strip flat and unwrinkled, and pull at a low angle.
Wait about one minute for the alcohol solution to weaken the adhesive.
Use the flat end of an opening pick or a plastic card to gently lift the battery.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
For optimal performance, calibrate your newly installed battery after completing this guide.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
13 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Thank you very much, the steps are very useful indeed and they helped tremendously when I got stuck!
